[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #1820
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1820/changes&gt;
Changes:
[ridethepenguin] [GEOS-7086] Make sure when namespace is deleted, associated workspace is deleted as well
[...truncated 3989 lines...]
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.06.2015 @ 12:14:53 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 24-giu-2015 12:24
[INFO] [GitCommitIdMojo] build.build.time = 24.06.2015 @ 12:42:21 CEST
[INFO] [GitCommitIdMojo] build.branch = 3245f0f68a7910085b908f45c07905432194d9cd
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3245f0f
[INFO] [GitCommitIdMojo] build.commit.id = 3245f0f68a7910085b908f45c07905432194d9cd
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1119 from ridethepenguin/master
[GEOS-7086] Make sure if namespace is deleted, associated workspace is deleted too
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 41 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/gwc/target/classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfoImpl.java:[27,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfo.java:[14,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[161,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[1205,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\ConfigurableBlobStore.java:[548,51] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\ConfigurableBlobStore.java:[563,51] error: cannot find symbol
[INFO] 6 errors
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.535s]
[INFO] Core Platform Module .............................. SUCCESS [19.859s]
[INFO] Open Web Service Module ........................... SUCCESS [15.459s]
[INFO] Main Module ....................................... SUCCESS [3:46.014s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.967s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.836s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.057s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.352s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:02.463s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.841s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.355s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:02.987s]
[INFO] Web Map Service Module ............................ SUCCESS [4:14.203s]
[INFO] KML support for GeoServer ......................... SUCCESS [53.194s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [6.084s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 18:03.077s
[INFO] Finished at: Wed Jun 24 12:42:26 CEST 2015
[INFO] Final Memory: 55M/384M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1821/&gt;
