See <http://ares.opengeo.org/jenkins/job/geoserver-master/1834/>
[...truncated 13801 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 016217e
[INFO] [GitCommitIdMojo] build.commit.id = 016217e12988c84a525458941933ca96b2a40ded
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1233 from DenisCarriere/patch-1
Removed repeating instructions
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1233 from DenisCarriere/patch-1
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 03.10.2015 @ 14:06:19 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 05-Oct-2015 21:26
[INFO] [GitCommitIdMojo] build.build.time = 05.10.2015 @ 21:49:44 UTC
[INFO] [GitCommitIdMojo] build.branch = 016217e12988c84a525458941933ca96b2a40ded
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.83 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] build.build.time = 05.10.2015 @ 21:49:46 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.177s]
[INFO] Core Platform Module .............................. SUCCESS [15.487s]
[INFO] Open Web Service Module ........................... SUCCESS [20.508s]
[INFO] Main Module ....................................... SUCCESS [2:35.868s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.303s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.287s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:54.217s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.572s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.568s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.139s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:49.442s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:15.821s]
[INFO] Web Map Service Module ............................ SUCCESS [4:06.882s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:26.678s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:24.522s]
[INFO] REST Support Module ............................... SUCCESS [41.273s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:33.129s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.535s]
[INFO] Core UI Module .................................... FAILURE [2.306s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.359s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.271s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.403s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.728s]
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.599s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.827s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.573s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.579s]
[INFO] ImageMap Output Format ............................ SUCCESS [23.013s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.623s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.093s]
[INFO] OGR parent ........................................ SUCCESS [0.457s]
[INFO] OGR CORE .......................................... SUCCESS [4.282s]
[INFO] OGR WFS ........................................... SUCCESS [25.334s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.437s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:11.243s]
[INFO] OGR WPS ........................................... SUCCESS [30.407s]
[INFO] Excel Output Format ............................... SUCCESS [42.964s]
[INFO] Chart external graphics support ................... SUCCESS [1.132s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.484s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.217s]
[INFO] OWS request flow controller ....................... SUCCESS [29.486s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [37.717s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.837s]
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.646s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [47.143s]
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.603s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.141s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.281s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:39.805s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.361s]
[INFO] DXF WFS output format ............................. SUCCESS [37.376s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [27.139s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.418s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.016s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.518s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.613s]
[INFO] Importer Core Module .............................. SUCCESS [1:58.878s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:39.067s]
[INFO] Importer Berkley DB Persistence Module ............ FAILURE [2.644s]
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:15.635s (Wall Clock)
[INFO] Finished at: Mon Oct 05 21:49:46 UTC 2015
[INFO] Final Memory: 69M/211M
[ERROR] Failed to execute goal on project gs-web-core: Could not resolve dependencies for project org.geoserver.web:gs-web-core:jar:2.9-SNAPSHOT: Failed to collect dependencies for [org.apache.wicket:wicket:jar:1.4.12 (compile), org.apache.wicket:wicket-extensions:jar:1.4.12 (compile), org.apache.wicket:wicket-spring:jar:1.4.12 (compile), org.wicketstuff:htmlvalidator:jar:1.2 (compile), org.slf4j:slf4j-log4j12:jar:1.7.10 (compile), log4j:log4j:jar:1.2.14 (compile), org.geoserver:gs-main:jar:2.9-SNAPSHOT (compile), org.geoserver:gs-platform:jar:2.9-SNAPSHOT (compile), org.geoserver:gs-main:jar:tests:2.9-SNAPSHOT (test), com.mockrunner:mockrunner:jar:0.3.6 (test), org.mortbay.jetty:jetty:jar:6.1.8 (test), org.geotools:gt-coverage:jar:15-SNAPSHOT (compile), org.geotools:gt-data:jar:15-SNAPSHOT (compile), org.geotools:gt-shapefile:jar:15-SNAPSHOT (compile), org.geotools.jdbc:gt-jdbc-postgis:jar:15-SNAPSHOT (compile), org.geotools:gt-wfs-ng:jar:15-SNAPSHOT (compile), org.geotools:gt-jdbc:jar:15-SNAPSHOT (compile), org.geotools:gt-metadata:jar:15-SNAPSHOT (compile), org.geotools:gt-arcgrid:jar:15-SNAPSHOT (compile), org.geotools:gt-geotiff:jar:15-SNAPSHOT (compile), org.geotools:gt-gtopo30:jar:15-SNAPSHOT (compile), org.geotools:gt-image:jar:15-SNAPSHOT (compile), org.springframework.security:spring-security-web:jar:3.1.0.RELEASE (compile), org.bouncycastle:bcprov-jdk14:jar:1.46 (compile), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:15-SNAPSHOT (compile), org.geotools:gt-main:jar:15-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]: Failed to read artifact descriptor for org.wicketstuff:htmlvalidator:jar:1.2: Could not transfer artifact org.wicketstuff:htmlvalidator:pom:1.2 from/to boundlessgeo (https://boundless.artifactoryonline.com/boundless/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR] Failed to execute goal on project gs-importer-bdb: Could not resolve dependencies for project org.geoserver.importer:gs-importer-bdb:jar:2.9-SNAPSHOT: Failed to collect dependencies for [org.geoserver.importer:gs-importer-core:jar:2.9-SNAPSHOT (compile), com.sleepycat:je:jar:4.1.10 (compile), com.ning:compress-lzf:jar:0.9.1 (compile), org.geoserver.importer:gs-importer-core:jar:tests:2.9-SNAPSHOT (test), org.geoserver:gs-main:jar:2.9-SNAPSHOT (compile), org.geotools:gt-epsg-hsql:jar:15-SNAPSHOT (test), org.geotools:gt-geojson:jar:15-SNAPSHOT (compile), org.geoserver:gs-main:jar:tests:2.9-SNAPSHOT (test), org.geoserver:gs-wfs:jar:2.9-SNAPSHOT (test), org.geoserver:gs-wms:jar:2.9-SNAPSHOT (test), junit:junit:jar:4.11 (test), commons-net:commons-net:jar:2.2 (test), org.apache.commons:commons-vfs2:jar:2.0 (compile), xmlunit:xmlunit:jar:1.3 (test), com.mockrunner:mockrunner:jar:0.3.6 (test), org.easymock:easymockclassextension:jar:2.5.2 (test), org.geoserver:gs-platform:jar:2.9-SNAPSHOT (compile), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:15-SNAPSHOT (compile), org.geotools:gt-main:jar:15-SNAPSHOT (compile)]: Failed to read artifact descriptor for com.sleepycat:je:jar:4.1.10: Could not transfer artifact com.sleepycat:je:pom:4.1.10 from/to boundlessgeo (https://boundless.artifactoryonline.com/boundless/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
