See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1839/changes>
Changes:
[andrea.aime] [GEOS-7083] Allow an import to have a set of default transformations
[andrea.aime] [GEOS-7084] Add a way to execute a import from REST in a single call
[andrea.aime] Documentation for GEOS-7083 and GEOS-7084
[...truncated 16607 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.importer.rest.RESTDataTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.412 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.46 sec
Results :
Failed tests: testDirectExecuteAsync(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<[COMPLETE]> but was:<[PENDING]>
testDirectExecuteSync(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<[COMPLETE]> but was:<[PENDING]>
testDefaultTransformationsInit(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<1> but was:<0>
Tests run: 59, Failures: 3, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.222s]
[INFO] Core Platform Module .............................. SUCCESS [20.981s]
[INFO] Open Web Service Module ........................... SUCCESS [17.534s]
[INFO] Main Module ....................................... SUCCESS [4:10.632s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.168s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [38.453s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.366s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.295s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.087s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.769s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.460s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:19.957s]
[INFO] Web Map Service Module ............................ SUCCESS [4:10.242s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:00.998s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:58.177s]
[INFO] REST Support Module ............................... SUCCESS [27.703s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:31.560s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.328s]
[INFO] Core UI Module .................................... SUCCESS [1:53.653s]
[INFO] WMS UI Module ..................................... SUCCESS [40.060s]
[INFO] GWC UI Module ..................................... SUCCESS [1:10.436s]
[INFO] WFS UI Module ..................................... SUCCESS [20.341s]
[INFO] Demoes Module ..................................... SUCCESS [38.038s]
[INFO] WCS UI Module ..................................... SUCCESS [27.677s]
[INFO] Security UI Modules ............................... SUCCESS [0.702s]
[INFO] Security UI Core Module ........................... SUCCESS [2:22.905s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:38.390s]
[INFO] Security UI LDAP Module ........................... SUCCESS [27.494s]
[INFO] REST UI Module .................................... SUCCESS [22.439s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.181s]
[INFO] Community Space ................................... SUCCESS [0.795s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.333s]
[INFO] Application Schema Support ........................ SUCCESS [0.328s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:47.127s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [19.425s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.775s]
[INFO] GeoSearch Index Module ............................ SUCCESS [23.740s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.001s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.421s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.468s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.453s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.421s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.250s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.718s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.795s]
[INFO] OGR parent ........................................ SUCCESS [0.468s]
[INFO] OGR WFS ........................................... SUCCESS [16.660s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.390s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:20.974s]
[INFO] OGR WPS ........................................... SUCCESS [21.450s]
[INFO] Excel Output Format ............................... SUCCESS [25.638s]
[INFO] Chart external graphics support ................... SUCCESS [0.530s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.576s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.608s]
[INFO] OWS request flow controller ....................... SUCCESS [21.353s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.226s]
[INFO] Web Processing Service GUI ........................ SUCCESS [49.703s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [32.412s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.560s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.718s]
[INFO] Core Monitor Extension ............................ SUCCESS [25.932s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.939s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.921s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [11.194s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.757s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.310s]
[INFO] XLST based WFS output format ...................... SUCCESS [35.447s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [44.299s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [27.418s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.859s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.698s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [18.159s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:12.351s]
[INFO] CSW UI Module ..................................... SUCCESS [19.209s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.312s]
[INFO] DXF WFS output format ............................. SUCCESS [25.162s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [20.759s]
[INFO] Printing Module ................................... SUCCESS [26.321s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.456s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [41.433s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [25.735s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [18.944s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.837s]
[INFO] Importer Core Module .............................. SUCCESS [1:30.119s]
[INFO] Importer REST Api Module .......................... FAILURE [3:23.220s]
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:00:36.628s
[INFO] Finished at: Fri Jul 03 11:55:07 CEST 2015
[INFO] Final Memory: 105M/252M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-rest: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/extension/importer/rest/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-rest
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 2 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1840/changes>
Changes:
[andrea.aime] Fixing typo
[andrea.aime] [GEOS-7082] Form requests with content type are not parsed as such
[andrea.aime] [GEOS-7081] Log content type too along with request url/body
[...truncated 16300 lines...]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.467 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.916 sec
Results :
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.490s]
[INFO] Core Platform Module .............................. SUCCESS [22.435s]
[INFO] Open Web Service Module ........................... SUCCESS [16.895s]
[INFO] Main Module ....................................... SUCCESS [4:12.933s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.092s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [36.220s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.196s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.774s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.768s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.018s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.046s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:43.735s]
[INFO] Web Map Service Module ............................ SUCCESS [7:58.904s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:02.440s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:02.043s]
[INFO] REST Support Module ............................... SUCCESS [30.751s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:36.363s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.483s]
[INFO] Core UI Module .................................... SUCCESS [1:58.302s]
[INFO] WMS UI Module ..................................... SUCCESS [40.581s]
[INFO] GWC UI Module ..................................... SUCCESS [1:08.772s]
[INFO] WFS UI Module ..................................... SUCCESS [19.096s]
[INFO] Demoes Module ..................................... SUCCESS [36.294s]
[INFO] WCS UI Module ..................................... SUCCESS [27.635s]
[INFO] Security UI Modules ............................... SUCCESS [0.827s]
[INFO] Security UI Core Module ........................... SUCCESS [2:23.396s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:38.088s]
[INFO] Security UI LDAP Module ........................... SUCCESS [27.135s]
[INFO] REST UI Module .................................... SUCCESS [21.893s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.965s]
[INFO] Community Space ................................... SUCCESS [1.108s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.390s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:44.128s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [20.405s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.685s]
[INFO] GeoSearch Index Module ............................ SUCCESS [22.368s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.110s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.437s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.452s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.452s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.608s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.570s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.717s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.546s]
[INFO] OGR parent ........................................ SUCCESS [0.390s]
[INFO] OGR WFS ........................................... SUCCESS [16.583s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.546s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:14.223s]
[INFO] OGR WPS ........................................... SUCCESS [20.668s]
[INFO] Excel Output Format ............................... SUCCESS [24.414s]
[INFO] Chart external graphics support ................... SUCCESS [1.701s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.183s]
[INFO] OWS request flow controller ....................... SUCCESS [21.155s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.522s]
[INFO] Web Processing Service GUI ........................ SUCCESS [49.930s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.759s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.369s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.671s]
[INFO] Core Monitor Extension ............................ SUCCESS [24.453s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.122s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.764s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.703s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.749s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.963s]
[INFO] XLST based WFS output format ...................... SUCCESS [33.876s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [41.701s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [25.717s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.951s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.043s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [18.231s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:12.277s]
[INFO] CSW UI Module ..................................... SUCCESS [17.817s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.296s]
[INFO] DXF WFS output format ............................. SUCCESS [24.084s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [19.240s]
[INFO] Printing Module ................................... SUCCESS [24.655s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.343s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [40.083s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [23.981s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [17.633s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.795s]
[INFO] Importer Core Module .............................. SUCCESS [1:20.339s]
[INFO] Importer REST Api Module .......................... FAILURE [3:11.731s]
[INFO] Total time: 1:05:01.457s
[INFO] Finished at: Fri Jul 03 15:12:52 CEST 2015
[INFO] Final Memory: 104M/248M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 3 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1841/>
[...truncated 16291 lines...]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.771 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.103 sec
Results :
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.271s]
[INFO] Core Platform Module .............................. SUCCESS [20.810s]
[INFO] Open Web Service Module ........................... SUCCESS [14.836s]
[INFO] Main Module ....................................... SUCCESS [3:51.311s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.842s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [35.408s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.118s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.490s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.570s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:13.107s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.393s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.183s]
[INFO] Web Map Service Module ............................ SUCCESS [4:08.922s]
[INFO] KML support for GeoServer ......................... SUCCESS [58.442s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:59.548s]
[INFO] REST Support Module ............................... SUCCESS [28.675s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:40.780s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.312s]
[INFO] Core UI Module .................................... SUCCESS [1:53.764s]
[INFO] WMS UI Module ..................................... SUCCESS [39.029s]
[INFO] GWC UI Module ..................................... SUCCESS [1:10.804s]
[INFO] WFS UI Module ..................................... SUCCESS [19.342s]
[INFO] Demoes Module ..................................... SUCCESS [36.522s]
[INFO] WCS UI Module ..................................... SUCCESS [27.642s]
[INFO] Security UI Modules ............................... SUCCESS [0.639s]
[INFO] Security UI Core Module ........................... SUCCESS [2:23.510s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:39.800s]
[INFO] Security UI LDAP Module ........................... SUCCESS [26.565s]
[INFO] REST UI Module .................................... SUCCESS [21.950s]
[INFO] GeoServer Web Application ......................... SUCCESS [13.338s]
[INFO] Community Space ................................... SUCCESS [0.405s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.343s]
[INFO] Application Schema Support ........................ SUCCESS [0.406s]
[INFO] Application Schema Integration Test ............... SUCCESS [4:18.526s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [29.715s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.144s]
[INFO] GeoSearch Index Module ............................ SUCCESS [30.354s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.825s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.998s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.889s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.717s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.702s]
[INFO] ImageMap Output Format ............................ SUCCESS [25.677s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [15.065s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [13.929s]
[INFO] OGR parent ........................................ SUCCESS [6.605s]
[INFO] OGR WFS ........................................... SUCCESS [1:02.692s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.248s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:52.005s]
[INFO] OGR WPS ........................................... SUCCESS [20.888s]
[INFO] Excel Output Format ............................... SUCCESS [23.947s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.261s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.546s]
[INFO] OWS request flow controller ....................... SUCCESS [20.006s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.453s]
[INFO] Web Processing Service GUI ........................ SUCCESS [52.394s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.967s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.385s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.920s]
[INFO] Core Monitor Extension ............................ SUCCESS [23.649s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.572s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.780s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.842s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.733s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.134s]
[INFO] XLST based WFS output format ...................... SUCCESS [34.068s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:37.089s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [26.151s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.562s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.165s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [18.845s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:10.862s]
[INFO] CSW UI Module ..................................... SUCCESS [18.589s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.328s]
[INFO] DXF WFS output format ............................. SUCCESS [23.465s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [19.631s]
[INFO] Printing Module ................................... SUCCESS [26.379s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.359s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [40.467s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [24.076s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [17.583s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.764s]
[INFO] Importer Core Module .............................. SUCCESS [1:21.111s]
[INFO] Importer REST Api Module .......................... FAILURE [3:13.080s]
[INFO] Total time: 1:04:34.997s
[INFO] Finished at: Sun Jul 05 12:23:20 CEST 2015
[INFO] Final Memory: 107M/249M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1842/>
[...truncated 16308 lines...]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.468 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.009 sec
Results :
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.191s]
[INFO] Core Platform Module .............................. SUCCESS [20.282s]
[INFO] Open Web Service Module ........................... SUCCESS [16.037s]
[INFO] Main Module ....................................... SUCCESS [3:56.054s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.764s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [35.336s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.728s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.664s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.880s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.482s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.079s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:27.062s]
[INFO] Web Map Service Module ............................ SUCCESS [4:11.527s]
[INFO] KML support for GeoServer ......................... SUCCESS [58.346s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:00.383s]
[INFO] REST Support Module ............................... SUCCESS [29.889s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:53.083s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.406s]
[INFO] Core UI Module .................................... SUCCESS [1:56.828s]
[INFO] WMS UI Module ..................................... SUCCESS [39.780s]
[INFO] GWC UI Module ..................................... SUCCESS [1:10.106s]
[INFO] WFS UI Module ..................................... SUCCESS [19.387s]
[INFO] Demoes Module ..................................... SUCCESS [36.607s]
[INFO] WCS UI Module ..................................... SUCCESS [28.301s]
[INFO] Security UI Modules ............................... SUCCESS [0.640s]
[INFO] Security UI Core Module ........................... SUCCESS [2:25.647s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:39.734s]
[INFO] Security UI LDAP Module ........................... SUCCESS [27.799s]
[INFO] REST UI Module .................................... SUCCESS [22.027s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.289s]
[INFO] Community Space ................................... SUCCESS [0.343s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.562s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:43.750s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [19.267s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.956s]
[INFO] GeoSearch Index Module ............................ SUCCESS [22.761s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.865s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.499s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.406s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.992s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.889s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.499s]
[INFO] OGR parent ........................................ SUCCESS [0.327s]
[INFO] OGR WFS ........................................... SUCCESS [16.694s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.530s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:17.294s]
[INFO] OGR WPS ........................................... SUCCESS [20.313s]
[INFO] Excel Output Format ............................... SUCCESS [24.928s]
[INFO] Chart external graphics support ................... SUCCESS [0.484s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.292s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.499s]
[INFO] OWS request flow controller ....................... SUCCESS [19.711s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [33.356s]
[INFO] Web Processing Service GUI ........................ SUCCESS [49.875s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [31.387s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.447s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.702s]
[INFO] Core Monitor Extension ............................ SUCCESS [24.306s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.526s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.888s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.748s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.009s]
[INFO] XLST based WFS output format ...................... SUCCESS [33.041s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [40.822s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [25.116s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.561s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.048s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [18.221s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:11.349s]
[INFO] CSW UI Module ..................................... SUCCESS [18.596s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.344s]
[INFO] DXF WFS output format ............................. SUCCESS [23.836s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [19.593s]
[INFO] Printing Module ................................... SUCCESS [41.497s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.368s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [42.432s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [24.103s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [17.524s]
[INFO] Importer Core Module .............................. SUCCESS [1:20.767s]
[INFO] Importer REST Api Module .......................... FAILURE [3:11.982s]
[INFO] Total time: 1:00:15.457s
[INFO] Finished at: Sun Jul 05 13:50:55 CEST 2015
[INFO] Final Memory: 105M/261M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1843/>
[...truncated 16299 lines...]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.52 sec
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.197 sec
Results :
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.957s]
[INFO] Core Platform Module .............................. SUCCESS [20.781s]
[INFO] Open Web Service Module ........................... SUCCESS [15.445s]
[INFO] Main Module ....................................... SUCCESS [3:57.098s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.826s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [35.407s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.057s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.805s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.335s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.726s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.265s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:24.034s]
[INFO] Web Map Service Module ............................ SUCCESS [4:37.216s]
[INFO] KML support for GeoServer ......................... SUCCESS [58.575s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:59.879s]
[INFO] REST Support Module ............................... SUCCESS [28.984s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:35.135s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.405s]
[INFO] Core UI Module .................................... SUCCESS [1:55.945s]
[INFO] WMS UI Module ..................................... SUCCESS [39.827s]
[INFO] GWC UI Module ..................................... SUCCESS [1:11.022s]
[INFO] WFS UI Module ..................................... SUCCESS [20.296s]
[INFO] Demoes Module ..................................... SUCCESS [36.478s]
[INFO] WCS UI Module ..................................... SUCCESS [28.470s]
[INFO] Security UI Modules ............................... SUCCESS [0.717s]
[INFO] Security UI Core Module ........................... SUCCESS [2:23.407s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:39.688s]
[INFO] Security UI LDAP Module ........................... SUCCESS [27.255s]
[INFO] REST UI Module .................................... SUCCESS [22.807s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.585s]
[INFO] Community Space ................................... SUCCESS [0.578s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.530s]
[INFO] Application Schema Support ........................ SUCCESS [0.421s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:51.840s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [19.625s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.469s]
[INFO] GeoSearch Index Module ............................ SUCCESS [22.983s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.738s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.436s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.437s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.484s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.691s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.671s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.500s]
[INFO] OGR parent ........................................ SUCCESS [0.375s]
[INFO] OGR WFS ........................................... SUCCESS [16.973s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.406s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:17.605s]
[INFO] OGR WPS ........................................... SUCCESS [21.411s]
[INFO] Excel Output Format ............................... SUCCESS [24.320s]
[INFO] Chart external graphics support ................... SUCCESS [1.342s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.245s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.593s]
[INFO] OWS request flow controller ....................... SUCCESS [20.124s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [28.379s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:02.744s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [1:34.576s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [11.160s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.858s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.795s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [17.948s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.983s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.805s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.920s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [5.916s]
[INFO] XLST based WFS output format ...................... SUCCESS [1:25.306s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:24.754s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [35.960s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [2.091s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.916s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [22.041s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:11.770s]
[INFO] CSW UI Module ..................................... SUCCESS [19.266s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.343s]
[INFO] DXF WFS output format ............................. SUCCESS [24.817s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [19.625s]
[INFO] Printing Module ................................... SUCCESS [26.589s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.344s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [40.748s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [23.776s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [18.158s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.749s]
[INFO] Importer Core Module .............................. SUCCESS [1:22.489s]
[INFO] Importer REST Api Module .......................... FAILURE [3:14.120s]
[INFO] Total time: 1:04:01.623s
[INFO] Finished at: Mon Jul 06 12:13:23 CEST 2015
[INFO] Final Memory: 104M/244M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
