See <http://ares.opengeo.org/jenkins/job/geoserver-master/1843/changes>
Changes:
[ben] Added layer.xml for gsml:GeologicUnit in the app-schema tutorial so it appears in the layer preview
[ben] Improved app-schema tutorial feature type titles and abstracts
[ben] Updated app-schema tutorial WFS service settings
[...truncated 21907 lines...]
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:15-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/snapshot/): Not authorized, ReasonPhrase:Unauthorized.
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ geoserver ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Updated app-schema tutorial WFS service settings
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 08.10.2015 @ 00:21:06 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 08-Oct-2015 01:00
[INFO] [GitCommitIdMojo] build.build.time = 08.10.2015 @ 01:00:53 UTC
[INFO] [GitCommitIdMojo] build.branch = 177c542a6228c434ba12f5028c11cffecbdb6f44
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 177c542
[INFO] [GitCommitIdMojo] build.commit.id = 177c542a6228c434ba12f5028c11cffecbdb6f44
[INFO] [GitCommitIdMojo] build.commit.message.full = Updated app-schema tutorial WFS service settings
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 08.10.2015 @ 01:00:54 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geoserver ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/target/geoserver-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
Downloading: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:geoserver:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/snapshot/): Not authorized, ReasonPhrase:Unauthorized.
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [4.753s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10.621s
[INFO] Finished at: Thu Oct 08 01:00:54 UTC 2015
[INFO] Final Memory: 41M/233M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.9-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/snapshot/): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
