[Geoserver-devel] Build failed in Jenkins: geoserver-master #1858
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1858/&gt;
[...truncated 3007 lines...]
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1247 from tbarsballe/importer-defer
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.10.2015 @ 13:44:08 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-Oct-2015 12:31
[INFO] [GitCommitIdMojo] build.build.time = 11.10.2015 @ 12:31:38 UTC
[INFO] [GitCommitIdMojo] build.branch = 09174583c5672b92dfc5f11082f4b548c7726812
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0917458
[INFO] [GitCommitIdMojo] build.commit.id = 09174583c5672b92dfc5f11082f4b548c7726812
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1247 from tbarsballe/importer-defer
[GEOS-7227] Defer bounds calculation during import
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-imagemosaic-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-imagemosaic-jdbc ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-imagemosaic-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-imagemosaic-jdbc ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-imagemosaic-jdbc ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-imagemosaic-jdbc ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-imagemosaic-jdbc ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 11.10.2015 @ 12:31:39 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-imagemosaic-jdbc ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.737s]
[INFO] Core Platform Module .............................. SUCCESS [15.407s]
[INFO] Open Web Service Module ........................... FAILURE [6.376s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.657s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.307s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.186s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.206s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.222s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.759s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.519s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.461s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.266s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.643s]
[INFO] OGR parent ........................................ SUCCESS [0.195s]
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.189s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [0.800s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.196s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.174s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.184s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 33.682s (Wall Clock)
[INFO] Finished at: Sun Oct 11 12:31:39 UTC 2015
[INFO] Final Memory: 41M/272M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ows: Compilation failure
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1859/&gt;
