[Geoserver-devel] Build failed in Jenkins: geoserver-master #1864
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1864/changes&gt;
Changes:
[andrea.aime] wip2
[andrea.aime] [GEOS-7240] Add support for perpendicular offset in SLD
[andrea.aime] Revert "wip2"
[...truncated 832 lines...]
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.480s]
[INFO] Core Platform Module .............................. FAILURE [3.933s]
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.399s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 13.137s (Wall Clock)
[INFO] Finished at: Mon Oct 12 12:03:14 UTC 2015
[INFO] Final Memory: 32M/229M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-platform: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/util/VersionPropertyEditor.java&gt;:\[10,24\] error: cannot find symbol
[ERROR] package org.geotools.util
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[24,27\] error: cannot find symbol
[ERROR] package org.geotools.factory
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[25,24\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[26,32\] error: package org.geotools.util.logging does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[64,11\] error: cannot find symbol
[ERROR] class GeoServerExtensions
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[83,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/Service.java&gt;:\[10,24\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/Service.java&gt;:\[46,10\] error: cannot find symbol
[ERROR] class Service
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/Service.java&gt;:\[60,46\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/Service.java&gt;:\[73,64\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/Service.java&gt;:\[96,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/Files.java&gt;:\[25,32\] error: package org.geotools.util.logging does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerResourceLoader.java&gt;:\[62,66\] error: package org.geotools.util.logging does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/util/VersionPropertyEditor.java&gt;:\[31,21\] error: cannot find symbol
[ERROR] class VersionPropertyEditor
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[57,43\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[64,67\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[83,64\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/GeoServerExtensions.java&gt;:\[168,25\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/OWS20Exception.java&gt;:\[22,66\] error: package org.geotools.util.logging does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/util/ReaderUtils.java&gt;:\[55,66\] error: package org.geotools.util.logging does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/Files.java&gt;:\[228,41\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1865/&gt;
