[Geoserver-devel] Build failed in Jenkins: geoserver-master #1869
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1869/changes&gt;
Changes:
[andrea.aime] Adding a profile for gs-hz-cluster
[...truncated 2948 lines...]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding a profile for gs-hz-cluster
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 13.10.2015 @ 13:45:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Oct-2015 13:47
[INFO] [GitCommitIdMojo] build.build.time = 13.10.2015 @ 13:48:16 UTC
[INFO] [GitCommitIdMojo] build.branch = 19d7d4aff291f814c3c2a5f8e27146e5fd2fd459
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 19d7d4a
[INFO] [GitCommitIdMojo] build.commit.id = 19d7d4aff291f814c3c2a5f8e27146e5fd2fd459
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding a profile for gs-hz-cluster
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/target/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/target/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.351s]
[INFO] Core Platform Module .............................. SUCCESS [16.620s]
[INFO] Open Web Service Module ........................... FAILURE [6.146s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.971s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.340s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.249s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.231s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.934s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.856s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.697s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.943s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.348s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.681s]
[INFO] OGR parent ........................................ SUCCESS [0.255s]
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.197s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [0.941s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.993s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.219s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.203s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 40.945s (Wall Clock)
[INFO] Finished at: Tue Oct 13 13:48:16 UTC 2015
[INFO] Final Memory: 41M/264M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ows: Compilation failure
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
[ERROR] -> [Help 1]
Looks like we have persistent jar file corruptions breaking the builds?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1870/&gt;
