See <http://ares.opengeo.org/jenkins/job/geoserver-master/1873/>
[...truncated 18009 lines...]
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding a profile for gs-hz-cluster
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 13.10.2015 @ 13:45:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 14-Oct-2015 03:16
[INFO] [GitCommitIdMojo] build.build.time = 14.10.2015 @ 03:51:14 UTC
[INFO] [GitCommitIdMojo] build.branch = 19d7d4aff291f814c3c2a5f8e27146e5fd2fd459
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 19d7d4a
[INFO] [GitCommitIdMojo] build.commit.id = 19d7d4aff291f814c3c2a5f8e27146e5fd2fd459
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding a profile for gs-hz-cluster
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.137 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.296 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-app ---
[INFO] [GitCommitIdMojo] build.build.time = 14.10.2015 @ 03:51:15 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [5869 msecs]
[INFO] Building war: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.862s]
[INFO] Core Platform Module .............................. SUCCESS [16.090s]
[INFO] Open Web Service Module ........................... SUCCESS [22.066s]
[INFO] Main Module ....................................... SUCCESS [2:37.011s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.239s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.345s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:08.836s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.303s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.408s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:04.408s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:47.210s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.129s]
[INFO] Web Map Service Module ............................ SUCCESS [4:07.890s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:16.917s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:23.371s]
[INFO] REST Support Module ............................... SUCCESS [39.752s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:34.657s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.425s]
[INFO] Core UI Module .................................... SUCCESS [1:53.461s]
[INFO] WMS UI Module ..................................... SUCCESS [55.614s]
[INFO] GWC UI Module ..................................... SUCCESS [1:28.791s]
[INFO] WFS UI Module ..................................... SUCCESS [30.962s]
[INFO] Demoes Module ..................................... SUCCESS [58.214s]
[INFO] WCS UI Module ..................................... SUCCESS [37.923s]
[INFO] Security UI Modules ............................... SUCCESS [0.336s]
[INFO] Security UI Core Module ........................... SUCCESS [2:47.639s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:04.134s]
[INFO] Security UI LDAP Module ........................... SUCCESS [37.927s]
[INFO] REST UI Module .................................... SUCCESS [35.624s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.401s]
[INFO] Printing Module ................................... SUCCESS [41.722s]
[INFO] Community Space ................................... SUCCESS [0.202s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.343s]
[INFO] GeoServer Web Application ......................... SUCCESS [20.224s]
[INFO] Application Schema Support ........................ SUCCESS [0.182s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:57.411s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [34.966s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.745s]
[INFO] GeoSearch Index Module ............................ SUCCESS [30.332s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.575s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.753s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.134s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.522s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.545s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.961s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.216s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.760s]
[INFO] OGR parent ........................................ SUCCESS [0.513s]
[INFO] OGR CORE .......................................... SUCCESS [6.438s]
[INFO] OGR WFS ........................................... SUCCESS [26.254s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.524s]
[INFO] Web Processing Service Module ..................... FAILURE [4:03.968s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [42.929s]
[INFO] Chart external graphics support ................... SUCCESS [1.629s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.489s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.289s]
[INFO] OWS request flow controller ....................... SUCCESS [28.183s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.831s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.989s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.590s]
[INFO] Core Monitor Extension ............................ SUCCESS [29.400s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [20.430s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.362s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.756s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.698s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.614s]
[INFO] XLST based WFS output format ...................... SUCCESS [50.328s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:00.134s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [38.549s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.334s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [29.083s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [30.426s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:37.845s]
[INFO] CSW UI Module ..................................... SUCCESS [22.467s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.490s]
[INFO] DXF WFS output format ............................. SUCCESS [37.273s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.487s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [50.602s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [35.563s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.058s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.533s]
[INFO] Importer Core Module .............................. SUCCESS [1:58.342s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:42.730s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [54.075s]
[INFO] Importer Web UI Module ............................ SUCCESS [37.656s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:50.310s (Wall Clock)
[INFO] Finished at: Wed Oct 14 03:51:27 UTC 2015
[INFO] Final Memory: 92M/274M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
