[Geoserver-devel] Build failed in Jenkins: geoserver-master #1894
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1894/&gt;
[...truncated 3880 lines...]
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO] [INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Skipping Web process status sharing with Hazelcast
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.605s]
[INFO] Core Platform Module .............................. SUCCESS [15.583s]
[INFO] Open Web Service Module ........................... SUCCESS [4:18.481s]
[INFO] Main Module ....................................... FAILURE [5:20.712s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.571s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.328s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.233s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.219s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1:01.920s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1:00.708s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.575s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.497s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.898s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.535s]
[INFO] OGR parent ........................................ SUCCESS [0.197s]
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.189s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [0.846s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.142s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.224s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.190s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:04.895s (Wall Clock)
[INFO] Finished at: Wed Oct 21 08:48:41 UTC 2015
[INFO] Final Memory: 43M/300M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredGridCoverage2DReader.java&gt;:\[41,7\] error: SecuredGridCoverage2DReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/SingleGridCoverage2DReader.java&gt;:\[32,7\] error: SingleGridCoverage2DReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/StructuredSingleGridCoverage2DReader.java&gt;:\[24,7\] error: StructuredSingleGridCoverage2DReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java&gt;:\[62,7\] error: CoverageViewReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[65,7\] error: CoverageDimensionCustomizerReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[212,24\] error: getInfo() in CoverageDimensionCustomizerReader cannot implement getInfo() in GridCoverage2DReader
[ERROR] return type CoverageInfo is not compatible with ServiceInfo
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/CoverageDimensionCustomizerReader.java&gt;:\[77,11\] error: CoverageDimensionCustomizerStructuredReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java&gt;:\[173,11\] error: getInfo() in CoverageDimensionCustomizerReader cannot implement getInfo() in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/CoverageViewReader.java&gt;:\[213,11\] error: getInfo() in CoverageDimensionCustomizerReader cannot implement getInfo() in GridCoverage2DReader
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/catalog/StructuredCoverageViewReader.java&gt;:\[44,7\] error: StructuredCoverageViewReader is not abstract and does not override abstract method getInfo(String) in GridCoverage2DReader
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1895/&gt;
[...truncated 3886 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.275s]
[INFO] Core Platform Module .............................. SUCCESS [16.722s]
[INFO] Open Web Service Module ........................... SUCCESS [18.411s]
[INFO] Main Module ....................................... FAILURE [1:17.904s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.351s]
[INFO] Community Space ................................... SUCCESS [0.185s]
[INFO] Application Schema Support ........................ SUCCESS [0.207s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.482s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.735s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.445s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.591s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1:00.563s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.680s]
[INFO] OGR parent ........................................ SUCCESS [0.238s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.234s]
[INFO] Chart external graphics support ................... SUCCESS [0.686s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.891s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.334s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.280s]
[INFO] Total time: 2:05.271s (Wall Clock)
[INFO] Finished at: Wed Oct 21 09:33:52 UTC 2015
[INFO] Final Memory: 43M/295M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1896/&gt;
[...truncated 3883 lines...]
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO]
[INFO]
[INFO] Skipping OGR WFS
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO]
[INFO] [INFO] ------------------------------------------------------------------------
[INFO] [INFO]
[INFO] [INFO]
[INFO]
[INFO]
[INFO] [INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.057s]
[INFO] Core Platform Module .............................. SUCCESS [15.817s]
[INFO] Open Web Service Module ........................... SUCCESS [19.358s]
[INFO] Main Module ....................................... FAILURE [1:20.365s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.710s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.294s]
[INFO] Community Space ................................... SUCCESS [0.203s]
[INFO] Application Schema Support ........................ SUCCESS [0.234s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.447s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.976s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.751s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.540s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.111s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.606s]
[INFO] OGR parent ........................................ SUCCESS [0.555s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.323s]
[INFO] Chart external graphics support ................... SUCCESS [1.062s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.174s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.352s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.407s]
[INFO] Total time: 2:05.427s (Wall Clock)
[INFO] Finished at: Wed Oct 21 09:42:08 UTC 2015
[INFO] Final Memory: 43M/288M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1897/&gt;
[...truncated 3887 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [INFO]
[INFO]
[INFO]
[INFO]
[INFO] [INFO]
[INFO]
[INFO]
[INFO]
[INFO] [INFO]
Skipping OGR WPS
[INFO] [INFO]
[INFO]
[INFO]
[INFO]
[INFO] [INFO]
[INFO]
[INFO] [INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.708s]
[INFO] Core Platform Module .............................. SUCCESS [18.162s]
[INFO] Open Web Service Module ........................... SUCCESS [22.953s]
[INFO] Main Module ....................................... FAILURE [22.881s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.530s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.358s]
[INFO] Community Space ................................... SUCCESS [0.584s]
[INFO] Application Schema Support ........................ SUCCESS [0.336s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.340s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.950s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.750s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.832s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.864s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.305s]
[INFO] OGR parent ........................................ SUCCESS [0.640s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.432s]
[INFO] Chart external graphics support ................... SUCCESS [2.914s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.211s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.378s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.518s]
[INFO] Total time: 1:20.643s (Wall Clock)
[INFO] Finished at: Thu Oct 22 06:24:45 UTC 2015
[INFO] Final Memory: 43M/287M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1898/&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.521s]
[INFO] Core Platform Module .............................. SUCCESS [15.606s]
[INFO] Open Web Service Module ........................... SUCCESS [20.165s]
[INFO] Main Module ....................................... FAILURE [17.686s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.521s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.312s]
[INFO] Community Space ................................... SUCCESS [0.196s]
[INFO] Application Schema Support ........................ SUCCESS [0.229s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.491s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.682s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.640s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.454s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.155s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.874s]
[INFO] OGR parent ........................................ SUCCESS [0.571s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.436s]
[INFO] Chart external graphics support ................... SUCCESS [1.190s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.218s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.456s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.380s]
[INFO] Total time: 1:02.231s (Wall Clock)
[INFO] Finished at: Thu Oct 22 06:31:07 UTC 2015
[INFO] Final Memory: 43M/286M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1899/changes&gt;
Changes:
[jody.garnett] review repositories
[...truncated 3936 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.598s]
[INFO] Core Platform Module .............................. SUCCESS [16.406s]
[INFO] Open Web Service Module ........................... SUCCESS [19.866s]
[INFO] Main Module ....................................... FAILURE [19.099s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.788s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.291s]
[INFO] Community Space ................................... SUCCESS [0.224s]
[INFO] Application Schema Support ........................ SUCCESS [0.187s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.500s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.837s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.555s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.662s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.921s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.711s]
[INFO] OGR parent ........................................ SUCCESS [0.316s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.311s]
[INFO] Chart external graphics support ................... SUCCESS [1.106s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.151s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.350s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.356s]
[INFO] Total time: 1:05.081s (Wall Clock)
[INFO] Finished at: Thu Oct 22 06:48:30 UTC 2015
[INFO] Final Memory: 44M/287M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1900/changes&gt;
Changes:
[daniele.romagnoli] GeoServer updates needed as consequency of GEOT-5247
[...truncated 20372 lines...]
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] *****************************************************************
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1277 from dromagnoli/GS-GEOT-5247
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.10.2015 @ 08:43:31 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 22-Oct-2015 08:49
[INFO] [GitCommitIdMojo] build.build.time = 22.10.2015 @ 09:24:23 UTC
[INFO] [GitCommitIdMojo] build.branch = cb734a4894cb1aed000c28557b463734202a239d
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = cb734a4
[INFO] [GitCommitIdMojo] build.commit.id = cb734a4894cb1aed000c28557b463734202a239d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1277 from dromagnoli/GS-GEOT-5247
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 22.10.2015 @ 09:24:26 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.446s]
[INFO] Core Platform Module .............................. SUCCESS [17.479s]
[INFO] Open Web Service Module ........................... SUCCESS [20.362s]
[INFO] Main Module ....................................... SUCCESS [2:38.810s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.647s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.834s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:16.569s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.787s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [44.036s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.195s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:48.508s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:28.287s]
[INFO] Web Map Service Module ............................ SUCCESS [4:20.991s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.014s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:24.212s]
[INFO] REST Support Module ............................... SUCCESS [41.184s]
[INFO] REST Configuration Service Module ................. FAILURE [2:36.243s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.713s]
[INFO] Core UI Module .................................... SUCCESS [2:00.683s]
[INFO] WMS UI Module ..................................... SUCCESS [1:03.981s]
[INFO] GWC UI Module ..................................... SUCCESS [1:24.401s]
[INFO] WFS UI Module ..................................... SUCCESS [30.133s]
[INFO] Demoes Module ..................................... SUCCESS [57.933s]
[INFO] WCS UI Module ..................................... SUCCESS [36.709s]
[INFO] Security UI Modules ............................... SUCCESS [0.671s]
[INFO] Security UI Core Module ........................... SUCCESS [2:49.292s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:06.472s]
[INFO] Security UI LDAP Module ........................... SUCCESS [42.193s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.435s]
[INFO] Printing Module ................................... SUCCESS [41.282s]
[INFO] Community Space ................................... SUCCESS [0.223s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.328s]
[INFO] Application Schema Support ........................ SUCCESS [0.276s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.412s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.315s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.255s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.850s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.882s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.832s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.502s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.629s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.699s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.423s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.654s]
[INFO] OGR parent ........................................ SUCCESS [0.372s]
[INFO] OGR CORE .......................................... SUCCESS [4.923s]
[INFO] OGR WFS ........................................... SUCCESS [23.670s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.345s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:10.470s]
[INFO] OGR WPS ........................................... SUCCESS [26.694s]
[INFO] Excel Output Format ............................... SUCCESS [38.842s]
[INFO] Chart external graphics support ................... SUCCESS [1.341s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.790s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.175s]
[INFO] OWS request flow controller ....................... SUCCESS [31.253s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [28.601s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:12.998s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.604s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.018s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.741s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.300s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [17.948s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.673s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [13.700s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.475s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.294s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:00.255s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.112s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.312s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.850s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [24.420s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:39.761s]
[INFO] CSW UI Module ..................................... SUCCESS [27.620s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.323s]
[INFO] DXF WFS output format ............................. SUCCESS [37.440s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [31.421s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.608s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.268s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [31.165s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.160s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.949s]
[INFO] Importer Core Module .............................. SUCCESS [2:03.830s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [55.889s]
[INFO] Importer Web UI Module ............................ SUCCESS [39.481s]
[INFO] GRIB Coverage Format .............................. SUCCESS [46.107s]
[INFO] NetCDF Coverage format ............................ SUCCESS [37.819s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:33.418s]
[INFO] Total time: 34:31.842s (Wall Clock)
[INFO] Finished at: Thu Oct 22 09:24:26 UTC 2015
[INFO] Final Memory: 90M/268M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1901/changes&gt;
