[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #1924
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1924/&gt;
[...truncated 6488 lines...]
  testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testGenericStyle(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLayer(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testFeatureType(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testSRSConverter(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testVirtualTable(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testCRSConverterInvalidWKT(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:3575" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testCRSConverter(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testPerserveUserData(org.geoserver.feature.ReprojectingFeatureCollectionTest): SRS 'epsg:4326' unknown:No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLockUnlockFilter(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testGetFeaturesReader(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testFeautureSourceFidFilter(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testDelete(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testLookupFeatureType(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testModify(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testFeatureReaderFidFilter(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testLockUnlockQuery(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testGetFeaturesFeatureSource(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
  testFullAccess(org.geoserver.security.impl.SecureCatalogIntegrationTest): org.geotools.data.DataSourceException: Lines schema not available
  testCannotWrite(org.geoserver.security.impl.SecureCatalogIntegrationTest): org.geotools.data.DataSourceException: Deletes schema not available
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default6688171073863400387data/DEM/tazdem.tiff&gt; with format GeoTIFF
  testForce(org.vfny.geoserver.ProjectionPolicyTest)
  testForceCoverage(org.vfny.geoserver.ProjectionPolicyTest)
  testReproject(org.vfny.geoserver.ProjectionPolicyTest)
  testWithRename(org.vfny.geoserver.ProjectionPolicyTest)
  testOverride(org.vfny.geoserver.crs.OverrideCRSTest): No code "EPSG:3002" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:3002" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testOverrideEPSGOperation(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:4269" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testNadCon(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:4138" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
Tests run: 675, Failures: 1, Errors: 72, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 1 second
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.287s]
[INFO] Core Platform Module .............................. SUCCESS [19.157s]
[INFO] Open Web Service Module ........................... SUCCESS [16.988s]
[INFO] Main Module ....................................... FAILURE [2:51.883s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:48.728s
[INFO] Finished at: Thu Jul 30 21:32:59 CEST 2015
[INFO] Final Memory: 49M/531M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 2 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1925/changes&gt;
Changes:
[maurobartolomeoli] GEOS-7131: fixed formatting in credentialsfromheaders tutorial
[...truncated 6388 lines...]
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default5380593558686691276data/DEM/tazdem.tiff&gt; with format GeoTIFF
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.928s]
[INFO] Core Platform Module .............................. SUCCESS [20.015s]
[INFO] Open Web Service Module ........................... SUCCESS [15.538s]
[INFO] Main Module ....................................... FAILURE [2:55.938s]
[INFO] Total time: 3:53.299s
[INFO] Finished at: Fri Jul 31 10:38:16 CEST 2015
[INFO] Final Memory: 49M/527M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1926/&gt;
[...truncated 6390 lines...]
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default2061797431459486893data/DEM/tazdem.tiff&gt; with format GeoTIFF
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.068s]
[INFO] Core Platform Module .............................. SUCCESS [19.125s]
[INFO] Open Web Service Module ........................... SUCCESS [15.740s]
[INFO] Main Module ....................................... FAILURE [2:53.395s]
[INFO] Total time: 3:51.615s
[INFO] Finished at: Fri Jul 31 19:46:41 CEST 2015
[INFO] Final Memory: 49M/525M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1927/changes&gt;
Changes:
[andrea.aime] [GEOS-7124] Remote Code Execution with Xstream
[andrea.aime] Work in progress on more whitelist authorization
[andrea.aime] Property to add to XStream whitelist
[andrea.aime] Make PropertyRule public and move to platform
[andrea.aime] Authorize wfsinfo and gmlinfo
[andrea.aime] Authorize WatermarkInfo
[andrea.aime] Adding a test for WPS xml service loading
[andrea.aime] Adding wcs whitelist bits too
[andrea.aime] Authorize SOLR configuration bits
[andrea.aime] Add better error message and descriptive log when a class is not in the whitelist
[...truncated 6482 lines...]
  testCoverage(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default5032441768909015249data/DEM/tazdem.tiff&gt; with format GeoTIFF
Tests run: 679, Failures: 1, Errors: 73, Skipped: 2
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.008s]
[INFO] Core Platform Module .............................. SUCCESS [18.517s]
[INFO] Open Web Service Module ........................... SUCCESS [16.037s]
[INFO] Main Module ....................................... FAILURE [2:49.184s]
[INFO] Total time: 3:44.189s
[INFO] Finished at: Fri Jul 31 20:00:54 CEST 2015
[INFO] Final Memory: 49M/532M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1928/changes&gt;
Changes:
[ksmith] Docs for XStream Whitelist property
[...truncated 6472 lines...]
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default5914189950754691549data/DEM/tazdem.tiff&gt; with format GeoTIFF
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.193s]
[INFO] Core Platform Module .............................. SUCCESS [20.654s]
[INFO] Open Web Service Module ........................... SUCCESS [16.583s]
[INFO] Main Module ....................................... FAILURE [2:51.586s]
[INFO] Total time: 3:51.162s
[INFO] Finished at: Fri Jul 31 23:38:19 CEST 2015
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1929/changes&gt;
Changes:
[tbattle] Removing dead maven repo.
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default5718490245067358918data/DEM/tazdem.tiff&gt; with format GeoTIFF
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.039s]
[INFO] Core Platform Module .............................. SUCCESS [20.155s]
[INFO] Open Web Service Module ........................... SUCCESS [15.803s]
[INFO] Main Module ....................................... FAILURE [2:51.788s]
[INFO] Total time: 3:49.883s
[INFO] Finished at: Sat Aug 01 01:38:20 CEST 2015
[INFO] Final Memory: 49M/537M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1930/changes&gt;
Changes:
[andrea.aime] Fix a typo, add a couple of comments
[...truncated 6464 lines...]
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default2023710006988965092data/DEM/tazdem.tiff&gt; with format GeoTIFF
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.162s]
[INFO] Core Platform Module .............................. SUCCESS [19.859s]
[INFO] Open Web Service Module ........................... SUCCESS [16.178s]
[INFO] Main Module ....................................... FAILURE [2:56.812s]
[INFO] Total time: 3:54.750s
[INFO] Finished at: Sat Aug 01 08:29:06 CEST 2015
[INFO] Final Memory: 49M/547M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1931/changes&gt;
Changes:
[andrea.aime] Adding missing file from xstream security changes commit
[...truncated 6481 lines...]
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default1518261838604184601data/DEM/tazdem.tiff&gt; with format GeoTIFF
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.475s]
[INFO] Core Platform Module .............................. SUCCESS [20.795s]
[INFO] Open Web Service Module ........................... SUCCESS [16.115s]
[INFO] Main Module ....................................... FAILURE [2:56.671s]
[INFO] Total time: 3:55.467s
[INFO] Finished at: Sat Aug 01 17:48:24 CEST 2015
[INFO] Final Memory: 49M/538M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1932/changes&gt;
Changes:
[andrea.aime] Some improvements to the SOLR docs
[...truncated 6474 lines...]
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/default4567221944942314209data/DEM/tazdem.tiff&gt; with format GeoTIFF
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.179s]
[INFO] Open Web Service Module ........................... SUCCESS [15.709s]
[INFO] Main Module ....................................... FAILURE [3:01.308s]
[INFO] Total time: 3:56.922s
[INFO] Finished at: Mon Aug 03 12:39:14 CEST 2015
[INFO] Final Memory: 49M/529M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1933/changes&gt;
