[Geoserver-devel] Build failed in Jenkins: geoserver-master #1947
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1947/&gt;
[...truncated 10990 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = ae8644f
[INFO] [GitCommitIdMojo] build.commit.id = ae8644fb9bb3bbe6102c710a4469856454476d01
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-4762] WCS should force usage of imageread
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-4762] WCS should force usage of imageread
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 02.11.2015 @ 11:27:11 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 02-Nov-2015 18:42
[INFO] [GitCommitIdMojo] build.build.time = 02.11.2015 @ 18:57:51 UTC
[INFO] [GitCommitIdMojo] build.branch = ae8644fb9bb3bbe6102c710a4469856454476d01
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.001 sec
Running org.geoserver.web.netcdf.NetCDFOutSettingsPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.435 sec
Running org.geoserver.web.netcdf.layer.NetCDFOutTabPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.753 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf-out ---
[INFO] [GitCommitIdMojo] build.build.time = 02.11.2015 @ 18:57:58 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf-out ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.720s]
[INFO] Core Platform Module .............................. SUCCESS [15.706s]
[INFO] Open Web Service Module ........................... SUCCESS [29.697s]
[INFO] Main Module ....................................... SUCCESS [2:47.680s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.274s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.137s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.138s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.482s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.719s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:10.369s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:54.904s]
[INFO] Web Feature Service Module ........................ FAILURE [3:20.030s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [41.380s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.375s]
[INFO] Core UI Module .................................... SUCCESS [1:53.125s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.147s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.154s]
[INFO] Printing Module ................................... SUCCESS [38.746s]
[INFO] Community Space ................................... SUCCESS [0.118s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.803s]
[INFO] Application Schema Support ........................ SUCCESS [0.103s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.185s]
[INFO] H2 DataStore Extension ............................ SUCCESS [20.779s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.544s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [2.038s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.601s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [2.671s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [5.235s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [3.278s]
[INFO] OGR parent ........................................ SUCCESS [0.253s]
[INFO] OGR CORE .......................................... SUCCESS [4.497s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.176s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.880s]
[INFO] Feature Generalization Extension .................. SUCCESS [7.011s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [2.530s]
[INFO] OWS request flow controller ....................... SUCCESS [28.342s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.438s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.670s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.171s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.863s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.935s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:39.593s]
[INFO] CSW UI Module ..................................... SUCCESS [25.927s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.185s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.144s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [45.211s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [35.776s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SUCCESS [42.942s]
[INFO] NetCDF Coverage format ............................ SUCCESS [32.987s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:35.694s]
[INFO] BUILD FAILURE
[INFO] Total time: 15:32.266s (Wall Clock)
[INFO] Finished at: Mon Nov 02 18:57:58 UTC 2015
[INFO] Final Memory: 67M/259M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1948/&gt;
[...truncated 10794 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 02-Nov-2015 19:41
[INFO] [GitCommitIdMojo] build.build.time = 02.11.2015 @ 19:58:06 UTC
[INFO]
[INFO]
[INFO]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.395 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.061 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.945 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 02.11.2015 @ 19:58:13 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.406s]
[INFO] Core Platform Module .............................. SUCCESS [24.936s]
[INFO] Open Web Service Module ........................... SUCCESS [31.208s]
[INFO] Main Module ....................................... SUCCESS [3:21.062s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.438s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.997s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:04.973s]
[INFO] Web Coverage Service Module ....................... SUCCESS [8.956s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.659s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.529s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:55.292s]
[INFO] Web Feature Service Module ........................ FAILURE [3:40.301s]
[INFO] REST Support Module ............................... SUCCESS [47.044s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.501s]
[INFO] Core UI Module .................................... SUCCESS [2:08.886s]
[INFO] Security UI Modules ............................... SUCCESS [0.307s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.217s]
[INFO] Printing Module ................................... SUCCESS [40.438s]
[INFO] Community Space ................................... SUCCESS [0.106s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.754s]
[INFO] Application Schema Support ........................ SUCCESS [0.274s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.625s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.583s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.250s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.731s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.754s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.660s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.616s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.025s]
[INFO] OGR parent ........................................ SUCCESS [0.345s]
[INFO] OGR CORE .......................................... SUCCESS [4.256s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.357s]
[INFO] Chart external graphics support ................... SUCCESS [1.596s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.618s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.600s]
[INFO] OWS request flow controller ....................... SUCCESS [28.831s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.980s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [40.729s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.175s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.210s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.282s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:39.197s]
[INFO] CSW UI Module ..................................... SUCCESS [24.926s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.096s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.299s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [45.848s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.725s]
[INFO] GRIB Coverage Format .............................. SUCCESS [44.273s]
[INFO] NetCDF Coverage format ............................ SUCCESS [33.664s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:31.380s]
[INFO] Total time: 16:46.021s (Wall Clock)
[INFO] Finished at: Mon Nov 02 19:58:13 UTC 2015
[INFO] Final Memory: 67M/258M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1949/changes&gt;
Changes:
[ridethepenguin] Update line_optimizedstyledlabel.sld
[...truncated 10750 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge branch 'jairds-patch-1'
[INFO] [GitCommitIdMojo] build.commit.time = 02.11.2015 @ 21:13:26 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 02-Nov-2015 21:20
[INFO] [GitCommitIdMojo] build.build.time = 02.11.2015 @ 21:35:24 UTC
[INFO] [GitCommitIdMojo] build.branch = 02fe243c9867cfcfc1570ce6d0594907fa5eda5f
[INFO] [GitCommitIdMojo] build.commit.user.email = ridethepenguin@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Stefano Costa
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 02fe243
[INFO] [GitCommitIdMojo] build.commit.id = 02fe243c9867cfcfc1570ce6d0594907fa5eda5f
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge branch 'jairds-patch-1'
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
GeneralEnvelope[(40.0, 10.0), (70.0, 55.0)]
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 23.276 sec
Running org.geoserver.wcs2_0.WCSNetCDFTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.216 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.564 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.711 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 02.11.2015 @ 21:35:36 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.199s]
[INFO] Core Platform Module .............................. SUCCESS [16.973s]
[INFO] Open Web Service Module ........................... SUCCESS [21.792s]
[INFO] Main Module ....................................... SUCCESS [2:43.432s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.313s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.593s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.837s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.577s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.242s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.880s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:53.940s]
[INFO] Web Feature Service Module ........................ FAILURE [3:28.144s]
[INFO] REST Support Module ............................... SUCCESS [40.167s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.435s]
[INFO] Core UI Module .................................... SUCCESS [1:55.731s]
[INFO] Security UI Modules ............................... SUCCESS [0.548s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.291s]
[INFO] Printing Module ................................... SUCCESS [38.612s]
[INFO] Community Space ................................... SUCCESS [0.212s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.026s]
[INFO] Application Schema Support ........................ SUCCESS [0.423s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.922s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.386s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.157s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.309s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.575s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.808s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.468s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.827s]
[INFO] OGR parent ........................................ SUCCESS [0.431s]
[INFO] OGR CORE .......................................... SUCCESS [4.396s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.318s]
[INFO] Chart external graphics support ................... SUCCESS [1.309s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.193s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.395s]
[INFO] OWS request flow controller ....................... SUCCESS [28.936s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.886s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [41.562s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.517s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.318s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.346s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:42.493s]
[INFO] CSW UI Module ..................................... SUCCESS [19.145s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.212s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.334s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [44.373s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [35.785s]
[INFO] GRIB Coverage Format .............................. SUCCESS [46.767s]
[INFO] NetCDF Coverage format ............................ SUCCESS [33.926s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:32.554s]
[INFO] Total time: 15:26.529s (Wall Clock)
[INFO] Finished at: Mon Nov 02 21:35:36 UTC 2015
[INFO] Final Memory: 65M/266M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1950/&gt;
