[Geoserver-devel] Build failed in Jenkins: geoserver-master #1979
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1979/changes&gt;
Changes:
[ridethepenguin] [GEOS-7306] Stored Queries don't work on App-Schema layers backed by database
[...truncated 11033 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1330 from ridethepenguin/fix-GEOS-7306
[GEOS-7306] Stored Queries don't work on App-Schema layers backed by DB
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1330 from ridethepenguin/fix-GEOS-7306
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.11.2015 @ 18:59:21 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-Nov-2015 21:06
[INFO] [GitCommitIdMojo] build.build.time = 11.11.2015 @ 21:21:08 UTC
[INFO] [GitCommitIdMojo] build.branch = 2e19a4ebe7f9c3698ac3eecf002da76bff0aa506
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2e19a4e
[INFO] [GitCommitIdMojo] build.commit.id = 2e19a4ebe7f9c3698ac3eecf002da76bff0aa506
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.518 sec
Running org.geoserver.web.netcdf.NetCDFOutSettingsPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.216 sec
Running org.geoserver.web.netcdf.layer.NetCDFOutTabPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.718 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf-out ---
[INFO] [GitCommitIdMojo] build.build.time = 11.11.2015 @ 21:21:16 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf-out ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.167s]
[INFO] Core Platform Module .............................. SUCCESS [16.151s]
[INFO] Open Web Service Module ........................... SUCCESS [21.818s]
[INFO] Main Module ....................................... SUCCESS [2:33.561s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.643s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.444s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:57.979s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.847s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.481s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.394s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:57.897s]
[INFO] Web Feature Service Module ........................ FAILURE [3:20.157s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [40.037s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.747s]
[INFO] Core UI Module .................................... SUCCESS [1:53.151s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.254s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.365s]
[INFO] Printing Module ................................... SUCCESS [36.529s]
[INFO] Community Space ................................... SUCCESS [0.215s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.198s]
[INFO] Application Schema Support ........................ SUCCESS [0.213s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.154s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.815s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.870s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.808s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.490s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.726s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.193s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.966s]
[INFO] OGR parent ........................................ SUCCESS [0.287s]
[INFO] OGR CORE .......................................... SUCCESS [6.265s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.512s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.281s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.647s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.277s]
[INFO] OWS request flow controller ....................... SUCCESS [31.025s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.220s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.144s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.209s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.356s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.698s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:41.808s]
[INFO] CSW UI Module ..................................... SUCCESS [21.768s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.387s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.225s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [42.024s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.085s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SUCCESS [40.097s]
[INFO] NetCDF Coverage format ............................ SUCCESS [34.694s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:30.889s]
[INFO] BUILD FAILURE
[INFO] Total time: 14:57.796s (Wall Clock)
[INFO] Finished at: Wed Nov 11 21:21:16 UTC 2015
[INFO] Final Memory: 65M/255M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1980/&gt;
