See <http://ares.opengeo.org/jenkins/job/geoserver-master/1998/>
[...truncated 11021 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7314] GeoTiffPPIO can return the source file of a processed coverage
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.11.2015 @ 14:15:27 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Nov-2015 22:19
[INFO] [GitCommitIdMojo] build.build.time = 16.11.2015 @ 22:34:33 UTC
[INFO] [GitCommitIdMojo] build.branch = 4466bdf101962cdc85061bc3a15f1f10b766716d
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4466bdf
[INFO] [GitCommitIdMojo] build.commit.id = 4466bdf101962cdc85061bc3a15f1f10b766716d
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7314] GeoTiffPPIO can return the source file of a processed coverage
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
GeneralEnvelope[(40.0, 10.0), (70.0, 55.0)]
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 21.456 sec
Running org.geoserver.wcs2_0.WCSNetCDFTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.046 sec
Running org.geoserver.web.netcdf.NetCDFOutSettingsPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.138 sec
Running org.geoserver.web.netcdf.layer.NetCDFOutTabPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.623 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf-out ---
[INFO] [GitCommitIdMojo] build.build.time = 16.11.2015 @ 22:34:44 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 16.11.2015 @ 22:34:45 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf-out ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.862s]
[INFO] Core Platform Module .............................. SUCCESS [16.122s]
[INFO] Open Web Service Module ........................... SUCCESS [20.709s]
[INFO] Main Module ....................................... SUCCESS [2:34.828s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.896s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.878s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:08.446s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.780s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.051s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.825s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:52.728s]
[INFO] Web Feature Service Module ........................ FAILURE [3:30.179s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [41.937s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.829s]
[INFO] Core UI Module .................................... SUCCESS [1:55.893s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.261s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.336s]
[INFO] Printing Module ................................... SUCCESS [38.488s]
[INFO] Community Space ................................... SUCCESS [0.232s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.172s]
[INFO] Application Schema Support ........................ SUCCESS [0.309s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.496s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.538s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.760s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.819s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.504s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.365s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.189s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.780s]
[INFO] OGR parent ........................................ SUCCESS [0.371s]
[INFO] OGR CORE .......................................... SUCCESS [4.412s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.214s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.171s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.768s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.050s]
[INFO] OWS request flow controller ....................... SUCCESS [28.014s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.150s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.284s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.358s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.865s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.107s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:42.586s]
[INFO] CSW UI Module ..................................... SUCCESS [18.862s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.668s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.507s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [47.450s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.970s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SUCCESS [41.299s]
[INFO] NetCDF Coverage format ............................ SUCCESS [38.181s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:27.756s]
[INFO] BUILD FAILURE
[INFO] Total time: 15:12.937s (Wall Clock)
[INFO] Finished at: Mon Nov 16 22:34:45 UTC 2015
[INFO] Final Memory: 65M/266M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
