[Geoserver-devel] Build failed in Jenkins: geoserver-master #2077
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2077/&gt;
[...truncated 4295 lines...]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO]
[INFO] [INFO] Skipping Teradata DataStore Extension
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO] [INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO] Skipping OGR WPS
[INFO] [INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO] [INFO]
[INFO] Skipping Importer Web UI Module
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.990s]
[INFO] Core Platform Module .............................. SUCCESS [15.035s]
[INFO] Open Web Service Module ........................... SUCCESS [17.911s]
[INFO] Main Module ....................................... FAILURE [2:06.991s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.506s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.291s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.435s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.497s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.027s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [2.401s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.709s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.681s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.024s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.525s]
[INFO] OGR parent ........................................ SUCCESS [0.350s]
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.269s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [0.952s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.982s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.190s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.255s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:51.451s (Wall Clock)
[INFO] Finished at: Fri Dec 18 15:01:36 UTC 2015
[INFO] Final Memory: 42M/283M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2078/changes&gt;
Changes:
[tbarsballe] Add assembly and release of vector tiles community extension
[...truncated 144081 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-gdal-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-gdal-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-gdal-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-gdal-wps ---
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 9.5 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204.jar
2/9 KB
4/9 KB
6/9 KB
8/9 KB
9/9 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204.jar (9 KB at 21.4 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204.pom
2/3 KB
3/3 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204.pom (3 KB at 2.1 KB/sec)
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/maven-metadata.xml
370/370 B
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/maven-metadata.xml (370 B at 2.9 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 7.0 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/maven-metadata.xml
326/326 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/maven-metadata.xml (326 B at 1.1 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204-tests.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204-tests.jar (7 KB at 16.4 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 5.6 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204-sources.jar (5 KB at 9.6 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204-test-sources.jar
2/4 KB
4/4 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151218.233004-204-test-sources.jar (4 KB at 7.9 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 5.5 KB/sec)
[INFO]
[INFO] Building GeoServer Community Release Module 2.9-SNAPSHOT
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-SNAPSHOT.pom
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.community:gs-vectortiles:jar:2.9-SNAPSHOT is missing, no dependency information available
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-SNAPSHOT.jar
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-SNAPSHOT.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.791s]
[INFO] Core Platform Module .............................. SUCCESS [4.847s]
[INFO] Open Web Service Module ........................... SUCCESS [12.202s]
[INFO] Main Module ....................................... SUCCESS [30.242s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.129s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [4.797s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.326s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.554s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.270s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [7.546s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [5.648s]
[INFO] Web Feature Service Module ........................ SUCCESS [6.191s]
[INFO] Web Map Service Module ............................ SUCCESS [8.244s]
[INFO] KML support for GeoServer ......................... SUCCESS [5.186s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [10.168s]
[INFO] REST Support Module ............................... SUCCESS [4.412s]
[INFO] REST Configuration Service Module ................. SUCCESS [8.044s]
[INFO] GeoServer Web Modules ............................. SUCCESS [2.041s]
[INFO] Core UI Module .................................... SUCCESS [6.965s]
[INFO] WMS UI Module ..................................... SUCCESS [4.422s]
[INFO] GWC UI Module ..................................... SUCCESS [4.639s]
[INFO] WFS UI Module ..................................... SUCCESS [3.974s]
[INFO] Demoes Module ..................................... SUCCESS [5.102s]
[INFO] WCS UI Module ..................................... SUCCESS [4.971s]
[INFO] Security UI Modules ............................... SUCCESS [2.012s]
[INFO] Security UI Core Module ........................... SUCCESS [4.962s]
[INFO] Security UI JDBC Module ........................... SUCCESS [4.202s]
[INFO] Security UI LDAP Module ........................... SUCCESS [4.061s]
[INFO] REST UI Module .................................... SUCCESS [4.407s]
[INFO] GeoServer Web Application ......................... SUCCESS [1:32.350s]
[INFO] Community Space ................................... SUCCESS [2.103s]
[INFO] Authentication by unique url key .................. SUCCESS [10.141s]
[INFO] WorldWind Format Module ........................... SUCCESS [10.557s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [7.722s]
[INFO] SpatiaLite Extension .............................. SUCCESS [8.964s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [12.070s]
[INFO] Simple Feature Service ............................ SUCCESS [9.365s]
[INFO] Aggregating Data Store ............................ SUCCESS [7.329s]
[INFO] GeoServer Extensions .............................. SUCCESS [1.990s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.918s]
[INFO] Web Processing Service Module ..................... SUCCESS [7.636s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [2.158s]
[INFO] Core Scripting Extension .......................... SUCCESS [12.552s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [10.486s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [9.471s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [38.609s]
[INFO] H2 DataStore Extension ............................ SUCCESS [3.973s]
[INFO] Python Scripting Extension ........................ SUCCESS [21.788s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [12.996s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [9.617s]
[INFO] WMS-EO ............................................ SUCCESS [12.183s]
[INFO] ColorMap .......................................... SUCCESS [9.449s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [10.990s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [11.353s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [6.106s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [9.636s]
[INFO] REST plugin community module ...................... SUCCESS [9.702s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [9.316s]
[INFO] KML PPIO for WPS .................................. SUCCESS [11.145s]
[INFO] DownloadProcess ................................... SUCCESS [10.313s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [4.002s]
[INFO] ActiveMQ .......................................... SUCCESS [24.179s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [5.603s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [19.819s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [11.220s]
[INFO] Solr Module ....................................... SUCCESS [10.227s]
[INFO] Resumable REST Upload module ...................... SUCCESS [9.169s]
[INFO] GeoFence security integration ..................... SUCCESS [13.488s]
[INFO] GeoFence Server ................................... SUCCESS [12.428s]
[INFO] REST SLD service .................................. SUCCESS [12.395s]
[INFO] GWC Distributed Caching Plugin .................... SUCCESS [7.455s]
[INFO] GeoWebCache S3 .................................... SUCCESS [11.435s]
[INFO] OGR parent ........................................ SUCCESS [3.512s]
[INFO] OGR CORE .......................................... SUCCESS [4.709s]
[INFO] GDAL translate parent ............................. SUCCESS [2.005s]
[INFO] GDAL translate WCS ................................ SUCCESS [8.961s]
[INFO] GDAL translate WPS ................................ SUCCESS [9.110s]
[INFO] GeoServer Community Release Module ................ FAILURE [3.378s]
[INFO] Application Schema Support ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] Total time: 12:40.853s
[INFO] Finished at: Fri Dec 18 23:30:12 UTC 2015
[INFO] Final Memory: 115M/373M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.9-SNAPSHOT: Could not find artifact org.geoserver.community:gs-vectortiles:jar:2.9-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
It looks like vector-tiles is not being deployed to repo.boundlessgeo.com for some reason; either the vector-tiles build is misconfigured or something is wrong with the repo.
I have confirmed that vector-tiles is being pushed to the local maven repo on ares, so it is being built.
I have manually deployed the latest vector-tiles (for 2.8 and master) to repo.boundlessgeo.com in order to get the build running again promptly. After doing this, 2.8.x build correctly; I am rerunning master now.
Torben
On Fri, Dec 18, 2015 at 3:30 PM, <monitor@anonymised.com> wrote:
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2078/changes>
Changes:
[…truncated 144081 lines…]
[INFO]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-gdal-wps —
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.3.1:install (default-install) @ gs-gdal-wps —
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] — maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-gdal-wps —
2/2 KB
2/9 KB
4/9 KB
6/9 KB
8/9 KB
9/9 KB
2/3 KB
3/3 KB
370/370 B
2/2 KB
326/326 B
2/7 KB
4/7 KB
6/7 KB
7/7 KB
2/2 KB
2/5 KB
4/5 KB
5/5 KB
2/2 KB
2/4 KB
4/4 KB
2/2 KB
[INFO]
[INFO]
[INFO] GeoServer … SUCCESS [8.791s]
[INFO] Core Platform Module … SUCCESS [4.847s]
[INFO] Open Web Service Module … SUCCESS [12.202s]
[INFO] Main Module … SUCCESS [30.242s]
[INFO] GeoServer Security Modules … SUCCESS [2.129s]
[INFO] GeoServer JDBC Security Module … SUCCESS [4.797s]
[INFO] GeoServer LDAP Security Module … SUCCESS [6.326s]
[INFO] Web Coverage Service Module … SUCCESS [5.554s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [8.270s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [7.546s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [5.648s]
[INFO] Web Feature Service Module … SUCCESS [6.191s]
[INFO] Web Map Service Module … SUCCESS [8.244s]
[INFO] KML support for GeoServer … SUCCESS [5.186s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [10.168s]
[INFO] REST Support Module … SUCCESS [4.412s]
[INFO] REST Configuration Service Module … SUCCESS [8.044s]
[INFO] GeoServer Web Modules … SUCCESS [2.041s]
[INFO] Core UI Module … SUCCESS [6.965s]
[INFO] WMS UI Module … SUCCESS [4.422s]
[INFO] GWC UI Module … SUCCESS [4.639s]
[INFO] WFS UI Module … SUCCESS [3.974s]
[INFO] Demoes Module … SUCCESS [5.102s]
[INFO] WCS UI Module … SUCCESS [4.971s]
[INFO] Security UI Modules … SUCCESS [2.012s]
[INFO] Security UI Core Module … SUCCESS [4.962s]
[INFO] Security UI JDBC Module … SUCCESS [4.202s]
[INFO] Security UI LDAP Module … SUCCESS [4.061s]
[INFO] REST UI Module … SUCCESS [4.407s]
[INFO] GeoServer Web Application … SUCCESS [1:32.350s]
[INFO] Community Space … SUCCESS [2.103s]
[INFO] Authentication by unique url key … SUCCESS [10.141s]
[INFO] WorldWind Format Module … SUCCESS [10.557s]
[INFO] GeoServer Embedded FTP server … SUCCESS [7.722s]
[INFO] SpatiaLite Extension … SUCCESS [8.964s]
[INFO] GeoServer JDBC KV Catalog … SUCCESS [12.070s]
[INFO] Simple Feature Service … SUCCESS [9.365s]
[INFO] Aggregating Data Store … SUCCESS [7.329s]
[INFO] GeoServer Extensions … SUCCESS [1.990s]
[INFO] Web Processing Service parent … SUCCESS [1.918s]
[INFO] Web Processing Service Module … SUCCESS [7.636s]
[INFO] GeoServer Scripting Extensions … SUCCESS [2.158s]
[INFO] Core Scripting Extension … SUCCESS [12.552s]
[INFO] Web UI Scripting Extension … SUCCESS [10.486s]
[INFO] BeanShell Scripting Extension … SUCCESS [9.471s]
[INFO] Groovy Scripting Extension … SUCCESS [38.609s]
[INFO] H2 DataStore Extension … SUCCESS [3.973s]
[INFO] Python Scripting Extension … SUCCESS [21.788s]
[INFO] JavaScript Scripting Extension … SUCCESS [12.996s]
[INFO] Ruby Scripting Extension … SUCCESS [9.617s]
[INFO] WMS-EO … SUCCESS [12.183s]
[INFO] ColorMap … SUCCESS [9.449s]
[INFO] GeoServer mbtiles Extension … SUCCESS [10.990s]
[INFO] GeoServer GeoPackage Extension … SUCCESS [11.353s]
[INFO] Dynamic WMS dimension value defaults … SUCCESS [9.636s]
[INFO] REST plugin community module … SUCCESS [9.702s]
[INFO] GPX PPIO for WPS … SUCCESS [9.316s]
[INFO] KML PPIO for WPS … SUCCESS [11.145s]
[INFO] DownloadProcess … SUCCESS [10.313s]
[INFO] GeoServer JMS based clustering modules … SUCCESS [4.002s]
[INFO] ActiveMQ … SUCCESS [24.179s]
[INFO] GeoServer JMS clustering Commons module … SUCCESS [5.603s]
[INFO] GeoServer JMS clustering module … SUCCESS [19.819s]
[INFO] GeoServer Hazelcast Clustering Module … SUCCESS [11.220s]
[INFO] Solr Module … SUCCESS [10.227s]
[INFO] Resumable REST Upload module … SUCCESS [9.169s]
[INFO] GeoFence security integration … SUCCESS [13.488s]
[INFO] GeoFence Server … SUCCESS [12.428s]
[INFO] REST SLD service … SUCCESS [12.395s]
[INFO] GWC Distributed Caching Plugin … SUCCESS [7.455s]
[INFO] GeoWebCache S3 … SUCCESS [11.435s]
[INFO] OGR parent … SUCCESS [3.512s]
[INFO] OGR CORE … SUCCESS [4.709s]
[INFO] GDAL translate parent … SUCCESS [2.005s]
[INFO] GDAL translate WCS … SUCCESS [8.961s]
[INFO] GDAL translate WPS … SUCCESS [9.110s]
[INFO] GeoServer Community Release Module … FAILURE [3.378s]
[INFO] Application Schema Support … SKIPPED
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SKIPPED
[INFO] ArcSDE DataStore Extension … SKIPPED
[INFO] GeoSearch Index Module … SKIPPED
[INFO] SQL Server DataStore Extension … SKIPPED
[INFO] Oracle DataStore Extension … SKIPPED
[INFO] MySQL DataStore Extension … SKIPPED
[INFO] DB2 DataStore Extension … SKIPPED
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SKIPPED
[INFO] JP2K Coverage Extension … SKIPPED
[INFO] OGR WFS … SKIPPED
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SKIPPED
[INFO] Chart external graphics support … SKIPPED
[INFO] Feature Generalization Extension … SKIPPED
[INFO] Image Mosaic JDBC Extension … SKIPPED
[INFO] OWS request flow controller … SKIPPED
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SKIPPED
[INFO] Teradata DataStore Extension … SKIPPED
[INFO] GeoServer Monitor Extensions … SKIPPED
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SKIPPED
[INFO] Catalog Services for the Web interfaces … SKIPPED
[INFO] Catalog Services for the Web core module … SKIPPED
[INFO] CSW UI Module … SKIPPED
[INFO] DXF WFS output format and WPS PPIO … SKIPPED
[INFO] DXF WFS output format … SKIPPED
[INFO] DXF WPS PPIO … SKIPPED
[INFO] Printing Module … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SKIPPED
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] Importer REST Api Module … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO] GRIB Coverage Format … SKIPPED
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.9-SNAPSHOT: Could not find artifact org.geoserver.community:gs-vectortiles:jar:2.9-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-release
Build step ‘Invoke top-level Maven targets’ marked build as failure
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2079/&gt;
[...truncated 144104 lines...]
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/maven-metadata.xml (370 B at 2.8 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 6.7 KB/sec)
326/326 B
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151219.011620-205-tests.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151219.011620-205-tests.jar (7 KB at 16.4 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151219.011620-205-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151219.011620-205-sources.jar (5 KB at 10.4 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 5.4 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151219.011620-205-test-sources.jar
2/4 KB
4/4 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-gdal-wps/2.9-SNAPSHOT/gs-gdal-wps-2.9-20151219.011620-205-test-sources.jar (4 KB at 7.5 KB/sec)
2/2 KB
[INFO]
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 2.0 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-20151219.001853-1.pom
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-20151219.001853-1.pom (2 KB at 3.5 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.pom
Downloading: http://download.osgeo.org/webdav/geotools/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.pom
Downloading: http://maven.restlet.org/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.pom
Downloading: http://www.hibernatespatial.org/repository/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.pom
Downloading: http://repo.maven.apache.org/maven2/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.pom
[WARNING] The POM for no.ecc.vectortile:java-vector-tile:jar:1.0.8 is missing, no dependency information available
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-20151219.001853-1.jar
Downloading: https://repo.boundlessgeo.com/main/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.jar
4/60 KB
8/60 KB
12/60 KB
16/60 KB
20/60 KB
24/60 KB
28/60 KB
32/60 KB
32/60 KB
36/60 KB
40/60 KB
44/60 KB
48/60 KB
52/60 KB
56/60 KB
60/60 KB
60/60 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.9-SNAPSHOT/gs-vectortiles-2.9-20151219.001853-1.jar (60 KB at 108.4 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.jar
Downloading: http://maven.restlet.org/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.jar
Downloading: http://www.hibernatespatial.org/repository/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.jar
Downloading: http://repo.maven.apache.org/maven2/no/ecc/vectortile/java-vector-tile/1.0.8/java-vector-tile-1.0.8.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.257s]
[INFO] Core Platform Module .............................. SUCCESS [5.689s]
[INFO] Open Web Service Module ........................... SUCCESS [12.347s]
[INFO] Main Module ....................................... SUCCESS [30.786s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.180s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [4.478s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4.321s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.112s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [5.731s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [5.685s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [5.716s]
[INFO] Web Feature Service Module ........................ SUCCESS [6.516s]
[INFO] Web Map Service Module ............................ SUCCESS [11.321s]
[INFO] KML support for GeoServer ......................... SUCCESS [4.725s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.078s]
[INFO] REST Support Module ............................... SUCCESS [4.439s]
[INFO] REST Configuration Service Module ................. SUCCESS [7.972s]
[INFO] GeoServer Web Modules ............................. SUCCESS [2.139s]
[INFO] Core UI Module .................................... SUCCESS [7.267s]
[INFO] WMS UI Module ..................................... SUCCESS [5.544s]
[INFO] GWC UI Module ..................................... SUCCESS [5.902s]
[INFO] WFS UI Module ..................................... SUCCESS [4.694s]
[INFO] Demoes Module ..................................... SUCCESS [5.361s]
[INFO] WCS UI Module ..................................... SUCCESS [4.975s]
[INFO] Security UI Modules ............................... SUCCESS [2.310s]
[INFO] Security UI Core Module ........................... SUCCESS [6.825s]
[INFO] Security UI JDBC Module ........................... SUCCESS [4.735s]
[INFO] Security UI LDAP Module ........................... SUCCESS [4.544s]
[INFO] REST UI Module .................................... SUCCESS [4.564s]
[INFO] GeoServer Web Application ......................... SUCCESS [1:31.798s]
[INFO] Community Space ................................... SUCCESS [2.780s]
[INFO] Authentication by unique url key .................. SUCCESS [10.089s]
[INFO] WorldWind Format Module ........................... SUCCESS [10.564s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [6.429s]
[INFO] SpatiaLite Extension .............................. SUCCESS [10.087s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [12.506s]
[INFO] Simple Feature Service ............................ SUCCESS [9.132s]
[INFO] Aggregating Data Store ............................ SUCCESS [6.553s]
[INFO] GeoServer Extensions .............................. SUCCESS [2.153s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.927s]
[INFO] Web Processing Service Module ..................... SUCCESS [8.189s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [2.678s]
[INFO] Core Scripting Extension .......................... SUCCESS [12.165s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [9.434s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [7.903s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [39.876s]
[INFO] H2 DataStore Extension ............................ SUCCESS [3.873s]
[INFO] Python Scripting Extension ........................ SUCCESS [21.705s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [12.188s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [8.857s]
[INFO] WMS-EO ............................................ SUCCESS [10.382s]
[INFO] ColorMap .......................................... SUCCESS [9.164s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [10.593s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [11.477s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [6.282s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [9.317s]
[INFO] REST plugin community module ...................... SUCCESS [8.468s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [8.946s]
[INFO] KML PPIO for WPS .................................. SUCCESS [8.737s]
[INFO] DownloadProcess ................................... SUCCESS [9.812s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [3.715s]
[INFO] ActiveMQ .......................................... SUCCESS [20.230s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [5.930s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [21.956s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [10.804s]
[INFO] Solr Module ....................................... SUCCESS [9.219s]
[INFO] Resumable REST Upload module ...................... SUCCESS [9.925s]
[INFO] GeoFence security integration ..................... SUCCESS [13.294s]
[INFO] GeoFence Server ................................... SUCCESS [11.728s]
[INFO] REST SLD service .................................. SUCCESS [10.858s]
[INFO] GWC Distributed Caching Plugin .................... SUCCESS [7.853s]
[INFO] GeoWebCache S3 .................................... SUCCESS [11.298s]
[INFO] OGR parent ........................................ SUCCESS [1.910s]
[INFO] OGR CORE .......................................... SUCCESS [3.206s]
[INFO] GDAL translate parent ............................. SUCCESS [1.942s]
[INFO] GDAL translate WCS ................................ SUCCESS [8.602s]
[INFO] GDAL translate WPS ................................ SUCCESS [9.047s]
[INFO] GeoServer Community Release Module ................ FAILURE [5.305s]
[INFO] Total time: 12:29.422s
[INFO] Finished at: Sat Dec 19 01:16:29 UTC 2015
[INFO] Final Memory: 115M/368M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.9-SNAPSHOT: Could not find artifact no.ecc.vectortile:java-vector-tile:jar:1.0.8 in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2080/&gt;
