Hudson
1
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2100/>
[...truncated 27155 lines...]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1348 from NielsCharlier/layergroup
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 29.12.2015 @ 09:18:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 29-Dec-2015 17:24
[INFO] [GitCommitIdMojo] build.build.time = 29.12.2015 @ 17:55:29 UTC
[INFO] [GitCommitIdMojo] build.branch = d94002f3aeadc451e7219404b5554750dfad69ed
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d94002f
[INFO] [GitCommitIdMojo] build.commit.id = d94002f3aeadc451e7219404b5554750dfad69ed
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1348 from NielsCharlier/layergroup
Refactor layer/layergroup UI - joined base with tabs for layergroup -…
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO] Webapp assembled in [598 msecs]
[INFO] Building war: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.war
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 29.12.2015 @ 17:55:33 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.954s]
[INFO] Core Platform Module .............................. SUCCESS [14.449s]
[INFO] Open Web Service Module ........................... SUCCESS [21.516s]
[INFO] Main Module ....................................... SUCCESS [2:17.464s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.128s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:02.849s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:57.001s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.401s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [35.110s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [46.803s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:34.144s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:48.987s]
[INFO] Web Map Service Module ............................ SUCCESS [3:44.733s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:08.321s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:08.179s]
[INFO] REST Support Module ............................... SUCCESS [33.913s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:17.066s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.187s]
[INFO] Core UI Module .................................... SUCCESS [1:41.124s]
[INFO] WMS UI Module ..................................... SUCCESS [47.183s]
[INFO] GWC UI Module ..................................... SUCCESS [1:14.566s]
[INFO] WFS UI Module ..................................... SUCCESS [26.807s]
[INFO] Demoes Module ..................................... SUCCESS [40.526s]
[INFO] WCS UI Module ..................................... SUCCESS [31.481s]
[INFO] Security UI Modules ............................... SUCCESS [0.278s]
[INFO] Security UI Core Module ........................... SUCCESS [2:39.214s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:59.703s]
[INFO] Security UI LDAP Module ........................... SUCCESS [38.951s]
[INFO] REST UI Module .................................... SUCCESS [28.198s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.162s]
[INFO] Printing Module ................................... SUCCESS [28.478s]
[INFO] Community Space ................................... SUCCESS [0.131s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.168s]
[INFO] GeoServer Web Application ......................... SUCCESS [11.574s]
[INFO] Application Schema Support ........................ SUCCESS [0.506s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:27.087s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [26.964s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.349s]
[INFO] GeoSearch Index Module ............................ SUCCESS [29.323s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.068s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.516s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.008s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.480s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.658s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.863s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.126s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.537s]
[INFO] OGR parent ........................................ SUCCESS [0.453s]
[INFO] OGR CORE .......................................... SUCCESS [4.237s]
[INFO] OGR WFS ........................................... SUCCESS [25.610s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.446s]
[INFO] Web Processing Service Module ..................... FAILURE [2:44.552s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [33.523s]
[INFO] Chart external graphics support ................... SUCCESS [1.538s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.659s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.376s]
[INFO] OWS request flow controller ....................... SUCCESS [27.872s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [39.013s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.587s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.175s]
[INFO] Core Monitor Extension ............................ SUCCESS [29.011s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [17.245s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.314s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [15.442s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.177s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.494s]
[INFO] XLST based WFS output format ...................... SUCCESS [42.741s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [57.422s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [29.475s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.216s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.468s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.142s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:14.753s]
[INFO] CSW UI Module ..................................... SUCCESS [22.705s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.165s]
[INFO] DXF WFS output format ............................. SUCCESS [32.881s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.104s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [43.442s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [26.480s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.751s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.688s]
[INFO] Importer Core Module .............................. SUCCESS [1:35.641s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:30.858s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [49.299s]
[INFO] Importer Web UI Module ............................ SUCCESS [33.384s]
[INFO] GRIB Coverage Format .............................. SUCCESS [40.894s]
[INFO] NetCDF Coverage format ............................ SUCCESS [27.816s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:10.958s]
[INFO] BUILD FAILURE
[INFO] Total time: 30:58.699s (Wall Clock)
[INFO] Finished at: Tue Dec 29 17:55:33 UTC 2015
[INFO] Final Memory: 93M/239M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
Hudson
2
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2101/>
[...truncated 27081 lines...]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 29-Dec-2015 18:00
[INFO] [GitCommitIdMojo] build.build.time = 29.12.2015 @ 18:31:33 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 29.12.2015 @ 18:31:36 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.525s]
[INFO] Core Platform Module .............................. SUCCESS [14.860s]
[INFO] Open Web Service Module ........................... SUCCESS [20.558s]
[INFO] Main Module ....................................... SUCCESS [2:18.586s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.251s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:09.409s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:03.376s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.767s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [35.903s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [48.522s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:30.496s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:48.641s]
[INFO] Web Map Service Module ............................ SUCCESS [3:32.402s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:08.104s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:06.279s]
[INFO] REST Support Module ............................... SUCCESS [31.875s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:12.783s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.147s]
[INFO] Core UI Module .................................... SUCCESS [1:39.970s]
[INFO] WMS UI Module ..................................... SUCCESS [47.562s]
[INFO] GWC UI Module ..................................... SUCCESS [1:10.345s]
[INFO] WFS UI Module ..................................... SUCCESS [25.005s]
[INFO] Demoes Module ..................................... SUCCESS [39.365s]
[INFO] WCS UI Module ..................................... SUCCESS [28.729s]
[INFO] Security UI Modules ............................... SUCCESS [0.225s]
[INFO] Security UI Core Module ........................... SUCCESS [2:33.744s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:59.590s]
[INFO] Security UI LDAP Module ........................... SUCCESS [38.177s]
[INFO] REST UI Module .................................... SUCCESS [27.621s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.116s]
[INFO] Printing Module ................................... SUCCESS [29.695s]
[INFO] Community Space ................................... SUCCESS [0.090s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.540s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.447s]
[INFO] Application Schema Support ........................ SUCCESS [0.474s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:33.323s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [30.459s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [26.183s]
[INFO] GeoSearch Index Module ............................ SUCCESS [27.138s]
[INFO] H2 DataStore Extension ............................ SUCCESS [19.692s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.332s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.025s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.492s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.610s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.471s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.801s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.782s]
[INFO] OGR parent ........................................ SUCCESS [0.124s]
[INFO] OGR CORE .......................................... SUCCESS [4.783s]
[INFO] OGR WFS ........................................... SUCCESS [23.166s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.108s]
[INFO] Web Processing Service Module ..................... FAILURE [2:46.930s]
[INFO] Excel Output Format ............................... SUCCESS [35.393s]
[INFO] Chart external graphics support ................... SUCCESS [1.127s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.325s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.416s]
[INFO] OWS request flow controller ....................... SUCCESS [27.100s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [39.166s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.367s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.187s]
[INFO] Core Monitor Extension ............................ SUCCESS [28.756s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.451s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.231s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [16.576s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.120s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.994s]
[INFO] XLST based WFS output format ...................... SUCCESS [42.992s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [55.220s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [31.996s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.171s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.461s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.574s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:19.853s]
[INFO] CSW UI Module ..................................... SUCCESS [22.268s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.145s]
[INFO] DXF WFS output format ............................. SUCCESS [34.365s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.100s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [43.891s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [29.636s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [23.974s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.238s]
[INFO] Importer Core Module .............................. SUCCESS [1:35.841s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:25.432s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [47.104s]
[INFO] Importer Web UI Module ............................ SUCCESS [31.985s]
[INFO] GRIB Coverage Format .............................. SUCCESS [40.605s]
[INFO] NetCDF Coverage format ............................ SUCCESS [32.228s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:10.006s]
[INFO] Total time: 30:52.954s (Wall Clock)
[INFO] Finished at: Tue Dec 29 18:31:36 UTC 2015
[INFO] Final Memory: 94M/259M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
3
See <http://ares.opengeo.org/jenkins/job/geoserver-master/2102/changes>
Changes:
[ben] Update list of Project Steering Committee members
[...truncated 26941 lines...]
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[WARNING] *****************************************************************
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Update list of Project Steering Committee members
[INFO] [GitCommitIdMojo] build.commit.time = 29.12.2015 @ 19:28:27 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 29-Dec-2015 19:49
[INFO] [GitCommitIdMojo] build.build.time = 29.12.2015 @ 20:21:39 UTC
[INFO] [GitCommitIdMojo] build.branch = 728de176c943475dd6c1f0451e8a6249e851ceeb
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 728de17
[INFO] [GitCommitIdMojo] build.commit.id = 728de176c943475dd6c1f0451e8a6249e851ceeb
[INFO] [GitCommitIdMojo] build.commit.message.full = Update list of Project Steering Committee members
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 29.12.2015 @ 20:21:43 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.751s]
[INFO] Core Platform Module .............................. SUCCESS [14.539s]
[INFO] Open Web Service Module ........................... SUCCESS [17.988s]
[INFO] Main Module ....................................... SUCCESS [2:13.092s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.527s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:09.510s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:49.720s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.795s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:06.450s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:00.237s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:31.035s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:39.223s]
[INFO] Web Map Service Module ............................ SUCCESS [2:24.743s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:06.853s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:33.963s]
[INFO] REST Support Module ............................... SUCCESS [35.123s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:43.573s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.548s]
[INFO] Core UI Module .................................... SUCCESS [1:38.084s]
[INFO] WMS UI Module ..................................... SUCCESS [47.651s]
[INFO] GWC UI Module ..................................... SUCCESS [1:13.506s]
[INFO] WFS UI Module ..................................... SUCCESS [25.825s]
[INFO] Demoes Module ..................................... SUCCESS [42.005s]
[INFO] WCS UI Module ..................................... SUCCESS [29.950s]
[INFO] Security UI Modules ............................... SUCCESS [0.494s]
[INFO] Security UI Core Module ........................... SUCCESS [2:32.144s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:03.178s]
[INFO] Security UI LDAP Module ........................... SUCCESS [37.054s]
[INFO] REST UI Module .................................... SUCCESS [28.255s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.661s]
[INFO] Printing Module ................................... SUCCESS [32.173s]
[INFO] Community Space ................................... SUCCESS [0.242s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.315s]
[INFO] GeoServer Web Application ......................... SUCCESS [11.719s]
[INFO] Application Schema Support ........................ SUCCESS [0.202s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:35.163s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [2:21.685s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [24.499s]
[INFO] GeoSearch Index Module ............................ SUCCESS [26.117s]
[INFO] H2 DataStore Extension ............................ SUCCESS [20.552s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.374s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.747s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.409s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.694s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.981s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.977s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.598s]
[INFO] OGR parent ........................................ SUCCESS [0.252s]
[INFO] OGR CORE .......................................... SUCCESS [4.514s]
[INFO] OGR WFS ........................................... SUCCESS [13.623s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.272s]
[INFO] Web Processing Service Module ..................... FAILURE [2:46.946s]
[INFO] Excel Output Format ............................... SUCCESS [32.583s]
[INFO] Chart external graphics support ................... SUCCESS [8.486s]
[INFO] Feature Generalization Extension .................. SUCCESS [37.437s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.475s]
[INFO] OWS request flow controller ....................... SUCCESS [16.362s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [38.489s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.035s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.417s]
[INFO] Core Monitor Extension ............................ SUCCESS [27.423s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [17.058s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.508s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [14.847s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.323s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.418s]
[INFO] XLST based WFS output format ...................... SUCCESS [41.927s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [55.517s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [31.693s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.532s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.023s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.352s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:22.328s]
[INFO] CSW UI Module ..................................... SUCCESS [24.321s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.324s]
[INFO] DXF WFS output format ............................. SUCCESS [32.710s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.372s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [42.432s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [28.571s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.644s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.619s]
[INFO] Importer Core Module .............................. SUCCESS [1:40.159s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:25.608s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [49.762s]
[INFO] Importer Web UI Module ............................ SUCCESS [32.574s]
[INFO] GRIB Coverage Format .............................. SUCCESS [39.522s]
[INFO] NetCDF Coverage format ............................ SUCCESS [29.843s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:11.356s]
[INFO] Total time: 31:59.236s (Wall Clock)
[INFO] Finished at: Tue Dec 29 20:21:44 UTC 2015
[INFO] Final Memory: 90M/218M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
4
