See <http://ares.opengeo.org/jenkins/job/geoserver-master/213/changes>
Changes:
[andrea.aime] [GEOS-6171] 'Disk used' to say 'N/A' when quota off
[...truncated 25255 lines...]
[INFO] [GitCommitIdMojo] build.branch = 4b5e9df767c404f03cff366b8c9f16f060a9fd7d
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4b5e9df
[INFO] [GitCommitIdMojo] build.commit.id = 4b5e9df767c404f03cff366b8c9f16f060a9fd7d
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6171] 'Disk used' to say 'N/A' when quota off
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-csw-core <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-csw-core ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.5-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-csw-core ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.5-SNAPSHOT/gs-csw-core-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.5-SNAPSHOT/gs-csw-core-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.5-SNAPSHOT/gs-csw-core-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.5-SNAPSHOT/gs-csw-core-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/gs-csw-core-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-csw-core/2.5-SNAPSHOT/gs-csw-core-2.5-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building WCS UI Module 2.5-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in WCS UI Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-wcs ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-web-wcs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6171] 'Disk used' to say 'N/A' when quota off
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.01.2014 @ 10:47:15 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Jan-2014 10:47
[INFO] [GitCommitIdMojo] build.build.time = 16.01.2014 @ 11:13:36 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs ---
[INFO] Copying 9 resources
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wcs ---
[INFO] Compiling 10 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/gwc/src/main/java/org/geoserver/gwc/web/layer/CachedLayerProvider.java>:\[80,18\] cannot find symbol
symbol : method isDiskQuotaEnabled()
[INFO] 1 error
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wcs ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/wcs/target/surefire-reports>
T E S T S
Running org.geoserver.wcs.web.WCSAdminPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.267s]
[INFO] Core Platform Module .............................. SUCCESS [4.500s]
[INFO] Open Web Service Module ........................... SUCCESS [12.297s]
[INFO] Main Module ....................................... SUCCESS [2:37.975s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.852s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.376s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.719s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.257s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.504s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.515s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:50.378s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:56.391s]
[INFO] Web Map Service Module ............................ SUCCESS [4:32.534s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:10.961s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:38.312s]
[INFO] REST Support Module ............................... SUCCESS [40.596s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:57.879s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.641s]
[INFO] Core UI Module .................................... SUCCESS [2:08.741s]
[INFO] WMS UI Module ..................................... SUCCESS [59.535s]
[INFO] GWC UI Module ..................................... FAILURE [4.312s]
[INFO] WFS UI Module ..................................... SUCCESS [35.610s]
[INFO] Demoes Module ..................................... SUCCESS [53.452s]
[INFO] Security UI Modules ............................... SUCCESS [0.420s]
[INFO] Security UI Core Module ........................... SUCCESS [3:37.093s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.361s]
[INFO] Printing Module ................................... SUCCESS [18.033s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.100s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.226s]
[INFO] Application Schema Support ........................ SUCCESS [0.235s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [29.824s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.709s]
[INFO] GeoSearch Index Module ............................ SUCCESS [40.940s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.540s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.339s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.848s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.664s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.571s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.122s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.443s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.723s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [30.087s]
[INFO] Excel Output Format ............................... SUCCESS [32.293s]
[INFO] Validation Module ................................. SUCCESS [2.464s]
[INFO] Chart external graphics support ................... SUCCESS [1.128s]
[INFO] Feature Generalization Extension .................. SUCCESS [12.561s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.974s]
[INFO] OWS request flow controller ....................... SUCCESS [19.851s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.270s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:06.344s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [42.934s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.137s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.452s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.607s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [47.932s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [59.686s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.582s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [14.921s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [21.836s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:42.209s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.377s]
[INFO] DXF output format ................................. SUCCESS [33.496s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [36.588s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.320s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [41.761s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [33.104s]
[INFO] BUILD FAILURE
[INFO] Total time: 25:54.888s (Wall Clock)
[INFO] Finished at: Thu Jan 16 11:13:43 UTC 2014
[INFO] Final Memory: 60M/225M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-web-gwc: Compilation failure
[ERROR] symbol : method isDiskQuotaEnabled()
[ERROR] location: class org.geoserver.gwc.GWC
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
