[Geoserver-devel] Build failed in Jenkins: geoserver-master #2159
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2159/changes&gt;
Changes:
[ben] Fix typo in module name
[ben] Fix build on Windows by comparing directories as resource paths
[...truncated 25152 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e7db0b0
[INFO] [GitCommitIdMojo] build.commit.id = e7db0b0b13df5fd81d0bd8232fc6149765a8f3cf
[INFO] [GitCommitIdMojo] build.commit.message.full = Fix build on Windows by comparing directories as resource paths
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.354 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-csw ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fix build on Windows by comparing directories as resource paths
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 27.01.2016 @ 02:45:39 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 27-Jan-2016 02:47
[INFO] [GitCommitIdMojo] build.build.time = 27.01.2016 @ 03:11:37 UTC
[INFO] [GitCommitIdMojo] build.branch = e7db0b0b13df5fd81d0bd8232fc6149765a8f3cf
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.277s]
[INFO] Core Platform Module .............................. SUCCESS [19.992s]
[INFO] Open Web Service Module ........................... SUCCESS [21.164s]
[INFO] Main Module ....................................... SUCCESS [2:58.854s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.227s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.693s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4:50.822s]
[INFO] Web Coverage Service Module ....................... SUCCESS [19.876s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [32.307s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [36.865s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [50.757s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:31.910s]
[INFO] Web Map Service Module ............................ SUCCESS [2:12.339s]
[INFO] KML support for GeoServer ......................... SUCCESS [41.270s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:14.701s]
[INFO] REST Support Module ............................... SUCCESS [24.706s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:16.679s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.379s]
[INFO] Core UI Module .................................... SUCCESS [3:05.871s]
[INFO] WMS UI Module ..................................... SUCCESS [30.286s]
[INFO] GWC UI Module ..................................... SUCCESS [47.579s]
[INFO] WFS UI Module ..................................... SUCCESS [14.012s]
[INFO] Demos Module ...................................... SUCCESS [24.605s]
[INFO] WCS UI Module ..................................... SUCCESS [18.136s]
[INFO] Security UI Modules ............................... SUCCESS [0.268s]
[INFO] Security UI Core Module ........................... FAILURE [1:53.981s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [15.864s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.237s]
[INFO] Printing Module ................................... SUCCESS [18.955s]
[INFO] Community Space ................................... SUCCESS [0.185s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [3.141s]
[INFO] Application Schema Support ........................ SUCCESS [0.178s]
[INFO] Application Schema Integration Test ............... SUCCESS [1:51.658s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [14.523s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [14.495s]
[INFO] H2 DataStore Extension ............................ SUCCESS [11.244s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.105s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.362s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.791s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.750s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.194s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.867s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.715s]
[INFO] OGR parent ........................................ SUCCESS [0.178s]
[INFO] OGR CORE .......................................... SUCCESS [3.449s]
[INFO] OGR WFS ........................................... SUCCESS [10.928s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.188s]
[INFO] Web Processing Service Module ..................... SUCCESS [1:36.637s]
[INFO] OGR WPS ........................................... SUCCESS [12.811s]
[INFO] Excel Output Format ............................... SUCCESS [16.795s]
[INFO] Chart external graphics support ................... SUCCESS [1.679s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.611s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.617s]
[INFO] OWS request flow controller ....................... SUCCESS [17.587s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.680s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [18.267s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.477s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [1.558s]
[INFO] Core Monitor Extension ............................ SUCCESS [19.232s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [10.257s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [23.983s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [30.198s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [23.586s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.216s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [14.438s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [14.147s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [40.046s]
[INFO] CSW UI Module ..................................... SUCCESS [11.156s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.180s]
[INFO] DXF WFS output format ............................. SUCCESS [14.694s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [10.307s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.175s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [25.433s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [13.746s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [14.395s]
[INFO] GeoServer Data Importer ........................... SUCCESS [5.266s]
[INFO] Importer Core Module .............................. SUCCESS [54.574s]
[INFO] Importer REST Api Module .......................... SUCCESS [48.296s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [24.674s]
[INFO] Importer Web UI Module ............................ SUCCESS [19.998s]
[INFO] GRIB Coverage Format .............................. SUCCESS [23.800s]
[INFO] NetCDF Coverage format ............................ SUCCESS [17.966s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [44.748s]
[INFO] BUILD FAILURE
[INFO] Total time: 23:39.115s (Wall Clock)
[INFO] Finished at: Wed Jan 27 03:11:37 UTC 2016
[INFO] Final Memory: 85M/220M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-sec-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2160/changes&gt;
