[Geoserver-devel] Build failed in Jenkins: geoserver-master #2177
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2177/changes&gt;
Changes:
[groldan] Set slf4j dependencies version in root pom.
[...truncated 28994 lines...]
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.081 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.194 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-app ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Set slf4j dependencies version in root pom.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 01.02.2016 @ 17:15:12 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 01-Feb-2016 18:42
[INFO] [GitCommitIdMojo] build.build.time = 01.02.2016 @ 19:02:11 UTC
[INFO] [GitCommitIdMojo] build.branch = 1e84d25037d256b9777239f4743e43498daeec78
[INFO] [GitCommitIdMojo] build.commit.user.email = groldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1e84d25
[INFO] [GitCommitIdMojo] build.commit.id = 1e84d25037d256b9777239f4743e43498daeec78
[INFO] [GitCommitIdMojo] build.commit.message.full = Set slf4j dependencies version in root pom.
Homogenize slf4j dependency version, there were
several mixed versions across modules.
Upgrade to latest stable 1.7.14.
Signed-off-by: Gabriel Roldan <groldan@anonymised.com>
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [334 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.398s]
[INFO] Core Platform Module .............................. SUCCESS [14.263s]
[INFO] Open Web Service Module ........................... SUCCESS [15.052s]
[INFO] Main Module ....................................... SUCCESS [2:01.227s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.262s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [45.156s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:37.914s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.193s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [26.135s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [30.722s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [50.089s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:32.201s]
[INFO] Web Map Service Module ............................ SUCCESS [2:02.581s]
[INFO] KML support for GeoServer ......................... SUCCESS [38.968s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:10.227s]
[INFO] REST Support Module ............................... SUCCESS [17.224s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:13.119s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.280s]
[INFO] Core UI Module .................................... SUCCESS [1:08.357s]
[INFO] WMS UI Module ..................................... SUCCESS [27.334s]
[INFO] GWC UI Module ..................................... SUCCESS [42.702s]
[INFO] WFS UI Module ..................................... SUCCESS [14.425s]
[INFO] Demos Module ...................................... SUCCESS [24.005s]
[INFO] WCS UI Module ..................................... SUCCESS [18.366s]
[INFO] Security UI Modules ............................... SUCCESS [0.237s]
[INFO] Security UI Core Module ........................... SUCCESS [1:45.006s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:19.472s]
[INFO] Security UI LDAP Module ........................... SUCCESS [52.499s]
[INFO] REST UI Module .................................... SUCCESS [15.522s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.211s]
[INFO] Printing Module ................................... SUCCESS [13.842s]
[INFO] Community Space ................................... SUCCESS [0.208s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [2.565s]
[INFO] GeoServer Web Application ......................... SUCCESS [6.000s]
[INFO] Application Schema Support ........................ SUCCESS [0.181s]
[INFO] Application Schema Integration Test ............... SUCCESS [1:51.174s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [15.597s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [15.216s]
[INFO] H2 DataStore Extension ............................ SUCCESS [11.063s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.198s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.248s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.724s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.780s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.207s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.295s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.742s]
[INFO] OGR parent ........................................ SUCCESS [0.171s]
[INFO] OGR CORE .......................................... SUCCESS [2.255s]
[INFO] OGR WFS ........................................... SUCCESS [12.148s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.190s]
[INFO] Web Processing Service Module ..................... SUCCESS [1:25.384s]
[INFO] OGR WPS ........................................... SUCCESS [11.589s]
[INFO] Excel Output Format ............................... SUCCESS [17.730s]
[INFO] Chart external graphics support ................... SUCCESS [1.057s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.828s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.331s]
[INFO] OWS request flow controller ....................... SUCCESS [15.241s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.252s]
[INFO] Web Processing Service GUI ........................ SUCCESS [28.666s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [21.324s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.620s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.279s]
[INFO] Core Monitor Extension ............................ SUCCESS [15.647s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.406s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.251s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [8.746s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.244s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [2.677s]
[INFO] XLST based WFS output format ...................... SUCCESS [24.471s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [30.966s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.626s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.204s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [13.901s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [12.115s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [41.558s]
[INFO] CSW UI Module ..................................... SUCCESS [13.659s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.167s]
[INFO] DXF WFS output format ............................. SUCCESS [17.316s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [12.566s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.163s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [22.192s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [15.367s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [12.542s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.235s]
[INFO] Importer Core Module .............................. SUCCESS [52.112s]
[INFO] Importer REST Api Module .......................... SUCCESS [48.574s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [23.916s]
[INFO] Importer Web UI Module ............................ SUCCESS [18.586s]
[INFO] GRIB Coverage Format .............................. FAILURE [12.046s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.930s]
[INFO] WCS NetCDF output Module .......................... FAILURE [22.953s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:16.009s (Wall Clock)
[INFO] Finished at: Mon Feb 01 19:02:13 UTC 2016
[INFO] Final Memory: 92M/248M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-grib: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/grib/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf-out: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-grib
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2178/changes&gt;
