Hudson
1
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2240/changes>
Changes:
[jody.garnett] remove design docs for versioning community module
[daniele.romagnoli] [GEOS-7396]: ClassCastException fix
[...truncated 22676 lines...]
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] *****************************************************************
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1497 from jodygarnett/rm-versioning-docs
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.02.2016 @ 06:00:35 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Feb-2016 07:32
[INFO] [GitCommitIdMojo] build.build.time = 18.02.2016 @ 07:47:52 UTC
[INFO] [GitCommitIdMojo] build.branch = 134c8b56592a9b224910bf2c3a1aa6c6e06d428f
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 134c8b5
[INFO] [GitCommitIdMojo] build.commit.id = 134c8b56592a9b224910bf2c3a1aa6c6e06d428f
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1497 from jodygarnett/rm-versioning-docs
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 18.02.2016 @ 07:47:54 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.155s]
[INFO] Core Platform Module .............................. SUCCESS [13.233s]
[INFO] Open Web Service Module ........................... SUCCESS [13.254s]
[INFO] Main Module ....................................... SUCCESS [1:57.326s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.134s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [46.151s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:46.313s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.762s]
[INFO] Web Coverage Service 1.0 Module ................... FAILURE [26.536s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [30.073s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [51.695s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:32.030s]
[INFO] Web Map Service Module ............................ SUCCESS [2:10.288s]
[INFO] KML support for GeoServer ......................... SUCCESS [36.510s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:13.305s]
[INFO] REST Support Module ............................... SUCCESS [16.700s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.127s]
[INFO] Core UI Module .................................... SUCCESS [1:06.535s]
[INFO] WMS UI Module ..................................... SUCCESS [27.540s]
[INFO] GWC UI Module ..................................... SUCCESS [44.919s]
[INFO] WFS UI Module ..................................... SUCCESS [14.876s]
[INFO] Demos Module ...................................... SUCCESS [24.678s]
[INFO] WCS UI Module ..................................... SUCCESS [16.854s]
[INFO] Security UI Modules ............................... SUCCESS [0.156s]
[INFO] Security UI Core Module ........................... SUCCESS [1:45.681s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:19.978s]
[INFO] Security UI LDAP Module ........................... SUCCESS [57.651s]
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.243s]
[INFO] Printing Module ................................... SUCCESS [13.570s]
[INFO] Community Space ................................... SUCCESS [0.073s]
[INFO] Application Schema Support ........................ SUCCESS [0.077s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [16.032s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [15.012s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.392s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.251s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.846s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.726s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.402s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.274s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.663s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.409s]
[INFO] OGR parent ........................................ SUCCESS [0.121s]
[INFO] OGR CORE .......................................... SUCCESS [2.157s]
[INFO] OGR WFS ........................................... SUCCESS [12.075s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.086s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [17.650s]
[INFO] Chart external graphics support ................... SUCCESS [0.817s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.598s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.579s]
[INFO] OWS request flow controller ....................... SUCCESS [14.190s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [19.529s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.388s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.160s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [7.059s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.153s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [2.349s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [26.745s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.408s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.123s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [14.807s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [13.176s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [39.538s]
[INFO] CSW UI Module ..................................... SUCCESS [12.803s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.084s]
[INFO] DXF WFS output format ............................. SUCCESS [16.785s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.078s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [21.564s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [13.447s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [11.339s]
[INFO] GeoServer Data Importer ........................... SUCCESS [1.092s]
[INFO] Importer Core Module .............................. SUCCESS [52.452s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [24.032s]
[INFO] Importer Web UI Module ............................ SUCCESS [17.470s]
[INFO] GRIB Coverage Format .............................. SUCCESS [21.479s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.904s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [37.679s]
[INFO] BUILD FAILURE
[INFO] Total time: 15:42.683s (Wall Clock)
[INFO] Finished at: Thu Feb 18 07:47:54 UTC 2016
[INFO] Final Memory: 79M/181M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs1_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wcs1_0/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs1_0
Hudson
2
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2241/>
[...truncated 22708 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-csw ---
[INFO] [GitCommitIdMojo] build.timestamp = 18-Feb-2016 07:52
[INFO] [GitCommitIdMojo] build.build.time = 18.02.2016 @ 08:07:20 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 18.02.2016 @ 08:07:21 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.654s]
[INFO] Core Platform Module .............................. SUCCESS [12.234s]
[INFO] Open Web Service Module ........................... SUCCESS [12.428s]
[INFO] Main Module ....................................... SUCCESS [1:55.835s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.121s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [42.430s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:42.653s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.232s]
[INFO] Web Coverage Service 1.0 Module ................... FAILURE [25.240s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [29.156s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [48.850s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:31.417s]
[INFO] Web Map Service Module ............................ SUCCESS [1:58.813s]
[INFO] KML support for GeoServer ......................... SUCCESS [37.074s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:10.217s]
[INFO] REST Support Module ............................... SUCCESS [17.687s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.145s]
[INFO] Core UI Module .................................... SUCCESS [1:06.164s]
[INFO] WMS UI Module ..................................... SUCCESS [28.880s]
[INFO] GWC UI Module ..................................... SUCCESS [44.068s]
[INFO] WFS UI Module ..................................... SUCCESS [14.752s]
[INFO] Demos Module ...................................... SUCCESS [25.635s]
[INFO] WCS UI Module ..................................... SUCCESS [17.334s]
[INFO] Security UI Modules ............................... SUCCESS [0.142s]
[INFO] Security UI Core Module ........................... SUCCESS [1:44.345s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:18.193s]
[INFO] Security UI LDAP Module ........................... SUCCESS [54.601s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.112s]
[INFO] Printing Module ................................... SUCCESS [13.592s]
[INFO] Community Space ................................... SUCCESS [0.074s]
[INFO] Application Schema Support ........................ SUCCESS [0.074s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [14.804s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [13.870s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.394s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.265s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.597s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.371s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.331s]
[INFO] ImageMap Output Format ............................ SUCCESS [9.986s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.701s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.330s]
[INFO] OGR parent ........................................ SUCCESS [0.058s]
[INFO] OGR CORE .......................................... SUCCESS [2.198s]
[INFO] OGR WFS ........................................... SUCCESS [12.249s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.057s]
[INFO] Excel Output Format ............................... SUCCESS [17.046s]
[INFO] Chart external graphics support ................... SUCCESS [0.876s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.103s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.597s]
[INFO] OWS request flow controller ....................... SUCCESS [14.590s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [20.352s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.796s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.129s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [7.256s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.159s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [2.255s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [27.865s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.733s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.098s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [12.749s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [12.116s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [42.329s]
[INFO] CSW UI Module ..................................... SUCCESS [12.246s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.071s]
[INFO] DXF WFS output format ............................. SUCCESS [16.517s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.080s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [20.526s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [16.019s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [12.187s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.507s]
[INFO] Importer Core Module .............................. SUCCESS [52.009s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [23.687s]
[INFO] Importer Web UI Module ............................ SUCCESS [18.105s]
[INFO] GRIB Coverage Format .............................. SUCCESS [19.841s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.945s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [34.708s]
[INFO] Total time: 15:11.967s (Wall Clock)
[INFO] Finished at: Thu Feb 18 08:07:21 UTC 2016
[INFO] Final Memory: 79M/193M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
3
