[Geoserver-devel] Build failed in Jenkins: geoserver-master #2245
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2245/changes&gt;
Changes:
[daniele.romagnoli] [GEOS-7431]: Updating the GRIB Zip's included dependencies
[daniele.romagnoli] [GEOS-7396]: ClassCastException fix
[...truncated 3014 lines...]
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/target&gt;
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wcs2_0-eo ---
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1499 from dromagnoli/GEOS-7431
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.02.2016 @ 10:39:31 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Feb-2016 11:03
[INFO] [GitCommitIdMojo] build.build.time = 18.02.2016 @ 11:03:51 UTC
[INFO] [GitCommitIdMojo] build.branch = 1b591d7354875d30073e48e60dac26f64f04023d
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1b591d7
[INFO] [GitCommitIdMojo] build.commit.id = 1b591d7354875d30073e48e60dac26f64f04023d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1499 from dromagnoli/GEOS-7431
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/target/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wcs2_0-eo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/target/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.487s]
[INFO] Core Platform Module .............................. SUCCESS [13.511s]
[INFO] Open Web Service Module ........................... FAILURE [7.606s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.154s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.118s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.075s]
[INFO] Application Schema Support ........................ SUCCESS [0.075s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.170s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.770s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.504s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.330s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.297s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.305s]
[INFO] OGR parent ........................................ SUCCESS [0.062s]
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.059s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.008s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.897s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.063s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.066s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 30.312s (Wall Clock)
[INFO] Finished at: Thu Feb 18 11:03:51 UTC 2016
[INFO] Final Memory: 40M/321M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ows: Compilation failure
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2246/changes&gt;
Changes:
[afabiani] - fix Python Remote WPS Git repo URL
[...truncated 2958 lines...]
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = - fix Python Remote WPS Git repo URL
[INFO] [GitCommitIdMojo] build.commit.time = 18.02.2016 @ 11:29:34 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Feb-2016 11:32
[INFO] [GitCommitIdMojo] build.build.time = 18.02.2016 @ 11:33:17 UTC
[INFO] [GitCommitIdMojo] build.branch = b2269ceeedea11805bf8dc55350b6e99075fccaa
[INFO] [GitCommitIdMojo] build.commit.user.email = alessio.fabiani@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = afabiani
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b2269ce
[INFO] [GitCommitIdMojo] build.commit.id = b2269ceeedea11805bf8dc55350b6e99075fccaa
[INFO] [GitCommitIdMojo] build.commit.message.full = - fix Python Remote WPS Git repo URL
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.831s]
[INFO] Core Platform Module .............................. SUCCESS [12.181s]
[INFO] Open Web Service Module ........................... FAILURE [3.838s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.104s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.122s]
[INFO] Community Space ................................... SUCCESS [0.077s]
[INFO] Application Schema Support ........................ SUCCESS [0.077s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.265s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.582s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.331s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.298s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.631s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.389s]
[INFO] OGR parent ........................................ SUCCESS [0.069s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.061s]
[INFO] Chart external graphics support ................... SUCCESS [0.604s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.578s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.060s]
[INFO] Total time: 22.227s (Wall Clock)
[INFO] Finished at: Thu Feb 18 11:33:17 UTC 2016
[INFO] Final Memory: 40M/306M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2247/&gt;
[...truncated 24840 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 20-Feb-2016 02:39
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2016 @ 02:58:45 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2016 @ 02:58:48 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO] Webapp assembled in [8793 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.war
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.409s]
[INFO] Core Platform Module .............................. SUCCESS [17.662s]
[INFO] Open Web Service Module ........................... SUCCESS [18.007s]
[INFO] Main Module ....................................... SUCCESS [2:13.044s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.559s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [43.228s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:58.239s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.321s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [27.155s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [32.108s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [52.268s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:36.991s]
[INFO] Web Map Service Module ............................ SUCCESS [2:06.589s]
[INFO] KML support for GeoServer ......................... SUCCESS [37.198s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:19.333s]
[INFO] REST Support Module ............................... SUCCESS [18.317s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:15.077s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.178s]
[INFO] Core UI Module .................................... SUCCESS [1:13.459s]
[INFO] WMS UI Module ..................................... SUCCESS [28.814s]
[INFO] GWC UI Module ..................................... SUCCESS [43.246s]
[INFO] WFS UI Module ..................................... SUCCESS [14.456s]
[INFO] Demos Module ...................................... SUCCESS [24.575s]
[INFO] WCS UI Module ..................................... SUCCESS [18.456s]
[INFO] Security UI Modules ............................... SUCCESS [0.136s]
[INFO] Security UI Core Module ........................... SUCCESS [1:45.643s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:18.564s]
[INFO] Security UI LDAP Module ........................... SUCCESS [53.618s]
[INFO] REST UI Module .................................... SUCCESS [15.897s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.132s]
[INFO] Printing Module ................................... SUCCESS [16.309s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.609s]
[INFO] Community Space ................................... SUCCESS [0.158s]
[INFO] Application Schema Support ........................ SUCCESS [0.283s]
[INFO] Application Schema Integration Test ............... SUCCESS [1:50.406s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [15.681s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [14.831s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.265s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.046s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.332s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.222s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.544s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.787s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.259s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.679s]
[INFO] OGR parent ........................................ SUCCESS [0.091s]
[INFO] OGR CORE .......................................... SUCCESS [2.108s]
[INFO] OGR WFS ........................................... SUCCESS [11.641s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.065s]
[INFO] Web Processing Service Module ..................... FAILURE [1:29.838s]
[INFO] Excel Output Format ............................... SUCCESS [19.087s]
[INFO] Chart external graphics support ................... SUCCESS [1.332s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.045s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [2.083s]
[INFO] OWS request flow controller ....................... SUCCESS [16.131s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [19.851s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.966s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.287s]
[INFO] Core Monitor Extension ............................ SUCCESS [19.026s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.310s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.174s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [8.389s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.165s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.312s]
[INFO] XLST based WFS output format ...................... SUCCESS [23.324s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [31.101s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [18.350s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.136s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [13.860s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [13.134s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [39.727s]
[INFO] CSW UI Module ..................................... SUCCESS [11.521s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.114s]
[INFO] DXF WFS output format ............................. SUCCESS [17.379s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.076s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [23.795s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [13.854s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [12.462s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.374s]
[INFO] Importer Core Module .............................. SUCCESS [55.662s]
[INFO] Importer REST Api Module .......................... SUCCESS [46.284s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [25.066s]
[INFO] Importer Web UI Module ............................ SUCCESS [19.970s]
[INFO] GRIB Coverage Format .............................. SUCCESS [21.989s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.179s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [37.410s]
[INFO] Total time: 19:49.883s (Wall Clock)
[INFO] Finished at: Sat Feb 20 02:58:55 UTC 2016
[INFO] Final Memory: 89M/226M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2248/&gt;
[...truncated 25008 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 20-Feb-2016 03:03
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2016 @ 03:23:32 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.088 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.24 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-app ---
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2016 @ 03:23:33 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-app ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-app >>>
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [4009 msecs]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.574s]
[INFO] Core Platform Module .............................. SUCCESS [12.238s]
[INFO] Open Web Service Module ........................... SUCCESS [15.100s]
[INFO] Main Module ....................................... SUCCESS [1:57.248s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.122s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [43.988s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:27.423s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.176s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [26.693s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [31.715s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:03.635s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:32.338s]
[INFO] Web Map Service Module ............................ SUCCESS [2:02.532s]
[INFO] KML support for GeoServer ......................... SUCCESS [34.736s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:15.722s]
[INFO] REST Support Module ............................... SUCCESS [17.921s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:14.569s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.152s]
[INFO] Core UI Module .................................... SUCCESS [1:06.157s]
[INFO] WMS UI Module ..................................... SUCCESS [28.003s]
[INFO] GWC UI Module ..................................... SUCCESS [45.066s]
[INFO] WFS UI Module ..................................... SUCCESS [14.998s]
[INFO] Demos Module ...................................... SUCCESS [24.900s]
[INFO] WCS UI Module ..................................... SUCCESS [19.554s]
[INFO] Security UI Modules ............................... SUCCESS [0.154s]
[INFO] Security UI Core Module ........................... SUCCESS [1:47.296s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:21.504s]
[INFO] Security UI LDAP Module ........................... SUCCESS [1:45.456s]
[INFO] REST UI Module .................................... SUCCESS [16.283s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.111s]
[INFO] Printing Module ................................... SUCCESS [13.548s]
[INFO] GeoServer Web Application ......................... SUCCESS [11.146s]
[INFO] Community Space ................................... SUCCESS [0.076s]
[INFO] Application Schema Support ........................ SUCCESS [0.076s]
[INFO] Application Schema Integration Test ............... SUCCESS [1:56.159s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [14.523s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [14.432s]
[INFO] H2 DataStore Extension ............................ SUCCESS [9.984s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.479s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.590s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.350s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.320s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.812s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.346s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.346s]
[INFO] OGR parent ........................................ SUCCESS [0.071s]
[INFO] OGR CORE .......................................... SUCCESS [2.322s]
[INFO] OGR WFS ........................................... SUCCESS [12.670s]
[INFO] Web Processing Service Module ..................... FAILURE [1:31.875s]
[INFO] Excel Output Format ............................... SUCCESS [17.510s]
[INFO] Chart external graphics support ................... SUCCESS [0.653s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.564s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.681s]
[INFO] OWS request flow controller ....................... SUCCESS [14.524s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [19.883s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.165s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.118s]
[INFO] Core Monitor Extension ............................ SUCCESS [17.237s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.411s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.161s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [8.650s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.162s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [2.835s]
[INFO] XLST based WFS output format ...................... SUCCESS [24.837s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [31.677s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [15.963s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.120s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [13.272s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [14.001s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [39.323s]
[INFO] CSW UI Module ..................................... SUCCESS [12.802s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.074s]
[INFO] DXF WFS output format ............................. SUCCESS [16.868s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.097s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [24.495s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [14.389s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [11.603s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.138s]
[INFO] Importer Core Module .............................. SUCCESS [57.228s]
[INFO] Importer REST Api Module .......................... SUCCESS [45.299s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [29.195s]
[INFO] Importer Web UI Module ............................ SUCCESS [18.367s]
[INFO] GRIB Coverage Format .............................. SUCCESS [20.937s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.695s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [38.312s]
[INFO] Total time: 19:55.568s (Wall Clock)
[INFO] Finished at: Sat Feb 20 03:23:39 UTC 2016
[INFO] Final Memory: 90M/256M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2249/changes&gt;
Changes:
[dtucker] Updating the ResourcePool to use non-deprecated method for style retrieval
[...truncated 25147 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1496 from dvntucker/resource_pool_fix
[INFO] [GitCommitIdMojo] build.commit.time = 20.02.2016 @ 10:55:52 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Feb-2016 11:27
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2016 @ 11:46:24 UTC
[INFO] [GitCommitIdMojo] build.branch = 5d256c4111d2b1d752ee808fc2907623ccc8c75d
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 5d256c4
[INFO] [GitCommitIdMojo] build.commit.id = 5d256c4111d2b1d752ee808fc2907623ccc8c75d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1496 from dvntucker/resource_pool_fix
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.089 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [369 msecs]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.326s]
[INFO] Core Platform Module .............................. SUCCESS [16.033s]
[INFO] Open Web Service Module ........................... SUCCESS [17.595s]
[INFO] Main Module ....................................... SUCCESS [2:01.922s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.123s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [42.243s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:44.814s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.967s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [25.836s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [30.435s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [52.501s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:31.364s]
[INFO] Web Map Service Module ............................ SUCCESS [1:59.577s]
[INFO] KML support for GeoServer ......................... SUCCESS [37.040s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:13.477s]
[INFO] REST Support Module ............................... SUCCESS [17.812s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:17.465s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.109s]
[INFO] Core UI Module .................................... SUCCESS [1:06.297s]
[INFO] WMS UI Module ..................................... SUCCESS [27.842s]
[INFO] GWC UI Module ..................................... SUCCESS [43.130s]
[INFO] WFS UI Module ..................................... SUCCESS [13.615s]
[INFO] Demos Module ...................................... SUCCESS [26.108s]
[INFO] WCS UI Module ..................................... SUCCESS [17.811s]
[INFO] Security UI Modules ............................... SUCCESS [0.133s]
[INFO] Security UI Core Module ........................... SUCCESS [1:46.862s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:17.582s]
[INFO] Security UI LDAP Module ........................... SUCCESS [54.548s]
[INFO] REST UI Module .................................... SUCCESS [15.003s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.110s]
[INFO] Printing Module ................................... SUCCESS [13.846s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.645s]
[INFO] Community Space ................................... SUCCESS [0.100s]
[INFO] Application Schema Integration Test ............... SUCCESS [1:53.852s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [15.872s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [15.180s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.889s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.077s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.262s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.916s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.628s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.662s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.191s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.640s]
[INFO] OGR parent ........................................ SUCCESS [0.063s]
[INFO] OGR CORE .......................................... SUCCESS [2.158s]
[INFO] OGR WFS ........................................... SUCCESS [11.687s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.060s]
[INFO] Web Processing Service Module ..................... FAILURE [1:28.652s]
[INFO] Excel Output Format ............................... SUCCESS [18.791s]
[INFO] Chart external graphics support ................... SUCCESS [1.838s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.573s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [2.375s]
[INFO] OWS request flow controller ....................... SUCCESS [14.685s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [20.238s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.598s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.115s]
[INFO] Core Monitor Extension ............................ SUCCESS [16.069s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.573s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.149s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [8.054s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.142s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.028s]
[INFO] XLST based WFS output format ...................... SUCCESS [22.285s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [29.387s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.575s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.121s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [13.191s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [11.291s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [40.236s]
[INFO] CSW UI Module ..................................... SUCCESS [13.091s]
[INFO] DXF WFS output format ............................. SUCCESS [16.914s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.067s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [22.807s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [13.361s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [12.265s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.153s]
[INFO] Importer Core Module .............................. SUCCESS [53.821s]
[INFO] Importer REST Api Module .......................... SUCCESS [44.881s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [24.333s]
[INFO] Importer Web UI Module ............................ SUCCESS [17.921s]
[INFO] GRIB Coverage Format .............................. SUCCESS [20.958s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.411s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [39.122s]
[INFO] Total time: 18:56.328s (Wall Clock)
[INFO] Finished at: Sat Feb 20 11:46:26 UTC 2016
[INFO] Final Memory: 89M/243M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2250/&gt;
[INFO] [GitCommitIdMojo] build.timestamp = 20-Feb-2016 13:02
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2016 @ 13:21:35 UTC
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [401 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2016 @ 13:21:37 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.186s]
[INFO] Core Platform Module .............................. SUCCESS [12.244s]
[INFO] Open Web Service Module ........................... SUCCESS [16.189s]
[INFO] Main Module ....................................... SUCCESS [2:01.040s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.134s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [44.235s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:41.191s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.926s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [26.480s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [29.258s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [47.504s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:29.992s]
[INFO] Web Map Service Module ............................ SUCCESS [1:59.774s]
[INFO] KML support for GeoServer ......................... SUCCESS [36.748s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:10.716s]
[INFO] REST Support Module ............................... SUCCESS [16.810s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:18.183s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.140s]
[INFO] Core UI Module .................................... SUCCESS [1:05.675s]
[INFO] WMS UI Module ..................................... SUCCESS [27.724s]
[INFO] GWC UI Module ..................................... SUCCESS [43.385s]
[INFO] WFS UI Module ..................................... SUCCESS [14.589s]
[INFO] Demos Module ...................................... SUCCESS [26.215s]
[INFO] WCS UI Module ..................................... SUCCESS [17.867s]
[INFO] Security UI Modules ............................... SUCCESS [0.150s]
[INFO] Security UI Core Module ........................... SUCCESS [1:45.742s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:17.076s]
[INFO] Security UI LDAP Module ........................... SUCCESS [55.836s]
[INFO] REST UI Module .................................... SUCCESS [14.946s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.112s]
[INFO] Printing Module ................................... SUCCESS [13.633s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.018s]
[INFO] Community Space ................................... SUCCESS [0.074s]
[INFO] Application Schema Support ........................ SUCCESS [0.074s]
[INFO] Application Schema Integration Test ............... SUCCESS [1:52.858s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [15.546s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [15.524s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.696s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.681s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.193s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.675s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.660s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.738s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.278s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.651s]
[INFO] OGR parent ........................................ SUCCESS [0.065s]
[INFO] OGR CORE .......................................... SUCCESS [2.499s]
[INFO] OGR WFS ........................................... SUCCESS [12.427s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.080s]
[INFO] Web Processing Service Module ..................... FAILURE [1:28.847s]
[INFO] Excel Output Format ............................... SUCCESS [17.081s]
[INFO] Chart external graphics support ................... SUCCESS [1.407s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.749s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.199s]
[INFO] OWS request flow controller ....................... SUCCESS [14.630s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [20.245s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.475s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.116s]
[INFO] Core Monitor Extension ............................ SUCCESS [16.341s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.599s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.130s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [7.402s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.159s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.355s]
[INFO] XLST based WFS output format ...................... SUCCESS [23.445s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [29.156s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.757s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.100s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [12.996s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [11.542s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [39.856s]
[INFO] CSW UI Module ..................................... SUCCESS [12.733s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.065s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [22.658s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [13.836s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [11.962s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.154s]
[INFO] Importer Core Module .............................. SUCCESS [53.064s]
[INFO] Importer REST Api Module .......................... SUCCESS [47.038s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [23.787s]
[INFO] Importer Web UI Module ............................ SUCCESS [18.352s]
[INFO] GRIB Coverage Format .............................. SUCCESS [21.276s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.855s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [38.160s]
[INFO] Total time: 18:45.145s (Wall Clock)
[INFO] Finished at: Sat Feb 20 13:21:38 UTC 2016
[INFO] Final Memory: 89M/230M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2251/changes&gt;
