See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2252/changes>
Changes:
[andrea.aime] Tiny tweak to the CSS demo page command links layout
[...truncated 2972 lines...]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
959/959 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-shapefile/15-SNAPSHOT/maven-metadata.xml (959 B at 1.8 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-imagemosaic-jdbc ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-imagemosaic-jdbc ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Tiny tweak to the CSS demo page command links layout
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.02.2016 @ 10:56:35 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 22-Feb-2016 12:09
[INFO] [GitCommitIdMojo] build.build.time = 22.02.2016 @ 12:09:48 UTC
[INFO] [GitCommitIdMojo] build.branch = 7dee4ced58313e1086cb35d514d411e7124f13d6
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7dee4ce
[INFO] [GitCommitIdMojo] build.commit.id = 7dee4ced58313e1086cb35d514d411e7124f13d6
[INFO] [GitCommitIdMojo] build.commit.message.full = Tiny tweak to the CSS demo page command links layout
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-imagemosaic-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-imagemosaic-jdbc ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-imagemosaic-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-imagemosaic-jdbc ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-imagemosaic-jdbc ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-imagemosaic-jdbc ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-imagemosaic-jdbc ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.123s]
[INFO] Core Platform Module .............................. SUCCESS [16.459s]
[INFO] Open Web Service Module ........................... FAILURE [6.577s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.611s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.132s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.153s]
[INFO] Application Schema Support ........................ SUCCESS [0.069s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.105s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.734s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.707s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.023s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.251s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.713s]
[INFO] OGR parent ........................................ SUCCESS [0.079s]
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.060s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [0.946s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.138s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.083s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.065s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 31.361s (Wall Clock)
[INFO] Finished at: Mon Feb 22 12:09:48 UTC 2016
[INFO] Final Memory: 40M/320M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ows: Compilation failure
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
