Hudson
1
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2304/>
[...truncated 11409 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 70658e0
[INFO] [GitCommitIdMojo] build.commit.id = 70658e0ea682aef1100d6d081e712ce4e19c5c0e
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1526 from nmco/GEOS-7449-master
[GEOS-7449] Fixes WPS workspace specifc configuration load
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf-out ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1526 from nmco/GEOS-7449-master
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 08.03.2016 @ 16:46:50 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-Mar-2016 17:19
[INFO] [GitCommitIdMojo] build.build.time = 10.03.2016 @ 17:28:21 UTC
[INFO] [GitCommitIdMojo] build.branch = 70658e0ea682aef1100d6d081e712ce4e19c5c0e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf-out ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.837 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.694 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] build.build.time = 10.03.2016 @ 17:28:28 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.633s]
[INFO] Core Platform Module .............................. SUCCESS [12.190s]
[INFO] Open Web Service Module ........................... SUCCESS [12.962s]
[INFO] Main Module ....................................... SUCCESS [1:59.156s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.152s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [43.396s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:38.396s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.270s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [25.919s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [30.049s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [56.079s]
[INFO] Web Feature Service Module ........................ FAILURE [1:28.934s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [17.404s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.168s]
[INFO] Core UI Module .................................... SUCCESS [1:06.083s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.214s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.129s]
[INFO] Printing Module ................................... SUCCESS [13.572s]
[INFO] Community Space ................................... SUCCESS [0.121s]
[INFO] Application Schema Support ........................ SUCCESS [0.080s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [14.204s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.836s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.438s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.606s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.368s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.846s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.731s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.444s]
[INFO] OGR parent ........................................ SUCCESS [0.079s]
[INFO] OGR CORE .......................................... SUCCESS [2.207s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.094s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [0.683s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.332s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.670s]
[INFO] OWS request flow controller ....................... SUCCESS [14.692s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.141s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.043s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.185s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [12.418s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [12.979s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [46.617s]
[INFO] CSW UI Module ..................................... SUCCESS [12.532s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.098s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.078s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [22.456s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [13.561s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SUCCESS [20.710s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.730s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [37.197s]
[INFO] BUILD FAILURE
[INFO] Total time: 8:31.442s (Wall Clock)
[INFO] Finished at: Thu Mar 10 17:28:28 UTC 2016
[INFO] Final Memory: 63M/234M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
Hudson
2
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2305/>
[...truncated 11395 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 10-Mar-2016 17:32
[INFO] [GitCommitIdMojo] build.build.time = 10.03.2016 @ 17:40:40 UTC
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.862 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 10.03.2016 @ 17:40:42 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.727s]
[INFO] Core Platform Module .............................. SUCCESS [12.008s]
[INFO] Open Web Service Module ........................... SUCCESS [12.259s]
[INFO] Main Module ....................................... SUCCESS [1:55.505s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.132s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [43.333s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:35.217s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.615s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [25.882s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [30.931s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [49.966s]
[INFO] Web Feature Service Module ........................ FAILURE [1:30.341s]
[INFO] REST Support Module ............................... SUCCESS [17.852s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.148s]
[INFO] Core UI Module .................................... SUCCESS [1:05.611s]
[INFO] Security UI Modules ............................... SUCCESS [0.130s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.128s]
[INFO] Printing Module ................................... SUCCESS [14.153s]
[INFO] Community Space ................................... SUCCESS [0.086s]
[INFO] Application Schema Support ........................ SUCCESS [0.105s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [14.315s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.530s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.236s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.574s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.325s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.316s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.623s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.339s]
[INFO] OGR parent ........................................ SUCCESS [0.077s]
[INFO] OGR CORE .......................................... SUCCESS [2.036s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.073s]
[INFO] Chart external graphics support ................... SUCCESS [0.639s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.605s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.627s]
[INFO] OWS request flow controller ....................... SUCCESS [14.480s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.258s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.989s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.119s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [12.639s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [12.905s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [45.911s]
[INFO] CSW UI Module ..................................... SUCCESS [12.577s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.094s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.082s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [21.905s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [14.348s]
[INFO] GRIB Coverage Format .............................. SUCCESS [20.619s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.744s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [36.138s]
[INFO] Total time: 8:14.032s (Wall Clock)
[INFO] Finished at: Thu Mar 10 17:40:42 UTC 2016
[INFO] Final Memory: 63M/268M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
3
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2306/>
[...truncated 11389 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 12-Mar-2016 10:28
[INFO] [GitCommitIdMojo] build.build.time = 12.03.2016 @ 10:36:43 UTC
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.251 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.07 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 12.03.2016 @ 10:36:48 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.662s]
[INFO] Core Platform Module .............................. SUCCESS [12.750s]
[INFO] Open Web Service Module ........................... SUCCESS [13.345s]
[INFO] Main Module ....................................... SUCCESS [1:55.980s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.142s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [44.321s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:38.830s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.023s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [25.164s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [29.529s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [51.127s]
[INFO] Web Feature Service Module ........................ FAILURE [1:31.221s]
[INFO] REST Support Module ............................... SUCCESS [17.280s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.184s]
[INFO] Core UI Module .................................... SUCCESS [1:07.405s]
[INFO] Security UI Modules ............................... SUCCESS [0.156s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.113s]
[INFO] Printing Module ................................... SUCCESS [14.032s]
[INFO] Community Space ................................... SUCCESS [0.109s]
[INFO] Application Schema Support ........................ SUCCESS [0.081s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [14.208s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.925s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.495s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.546s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.330s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.311s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.614s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.340s]
[INFO] OGR parent ........................................ SUCCESS [0.083s]
[INFO] OGR CORE .......................................... SUCCESS [2.349s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.075s]
[INFO] Chart external graphics support ................... SUCCESS [1.982s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.450s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.721s]
[INFO] OWS request flow controller ....................... SUCCESS [15.138s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.790s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [16.725s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.139s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [12.995s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [13.188s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [46.154s]
[INFO] CSW UI Module ..................................... SUCCESS [12.738s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.090s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.081s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [23.531s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [14.351s]
[INFO] GRIB Coverage Format .............................. SUCCESS [20.192s]
[INFO] NetCDF Coverage format ............................ SUCCESS [16.396s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [37.150s]
[INFO] Total time: 8:21.841s (Wall Clock)
[INFO] Finished at: Sat Mar 12 10:36:48 UTC 2016
[INFO] Final Memory: 63M/262M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
4
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2307/>
[...truncated 11381 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 12-Mar-2016 10:54
[INFO] [GitCommitIdMojo] build.build.time = 12.03.2016 @ 11:02:41 UTC
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.281 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.659 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 12.03.2016 @ 11:02:49 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.358s]
[INFO] Core Platform Module .............................. SUCCESS [14.080s]
[INFO] Open Web Service Module ........................... SUCCESS [14.314s]
[INFO] Main Module ....................................... SUCCESS [1:56.113s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.149s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [44.221s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:37.527s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.839s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [26.215s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [30.330s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [52.562s]
[INFO] Web Feature Service Module ........................ FAILURE [1:32.662s]
[INFO] REST Support Module ............................... SUCCESS [16.954s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.147s]
[INFO] Core UI Module .................................... SUCCESS [1:05.440s]
[INFO] Security UI Modules ............................... SUCCESS [0.179s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.141s]
[INFO] Printing Module ................................... SUCCESS [14.880s]
[INFO] Community Space ................................... SUCCESS [0.127s]
[INFO] Application Schema Support ........................ SUCCESS [0.088s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [14.618s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.786s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.338s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.904s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.422s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.327s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.335s]
[INFO] OGR parent ........................................ SUCCESS [0.080s]
[INFO] OGR CORE .......................................... SUCCESS [2.261s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.074s]
[INFO] Chart external graphics support ................... SUCCESS [0.672s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.182s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.678s]
[INFO] OWS request flow controller ....................... SUCCESS [14.389s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.173s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [17.392s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.135s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [13.312s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [13.118s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [44.144s]
[INFO] CSW UI Module ..................................... SUCCESS [13.041s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.099s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [21.895s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [13.700s]
[INFO] GRIB Coverage Format .............................. SUCCESS [19.659s]
[INFO] NetCDF Coverage format ............................ SUCCESS [17.504s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [35.158s]
[INFO] Total time: 8:25.335s (Wall Clock)
[INFO] Finished at: Sat Mar 12 11:02:49 UTC 2016
[INFO] Final Memory: 63M/255M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
5
