See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2317/>
[...truncated 152706 lines...]
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-core/2.9-SNAPSHOT/maven-metadata.xml
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-core/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 5.9 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-core/2.9-SNAPSHOT/gs-dxf-core-2.9-20160317.223630-412-test-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-core/2.9-SNAPSHOT/gs-dxf-core-2.9-20160317.223630-412-test-sources.jar (5 KB at 9.5 KB/sec)
2/2 KB
[INFO]
[INFO] Building DXF WPS PPIO 2.9-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = One more round of cleanup
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.03.2016 @ 16:04:20 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Mar-2016 22:23
[INFO] [GitCommitIdMojo] build.build.time = 17.03.2016 @ 22:36:34 UTC
[INFO] [GitCommitIdMojo] build.branch = bf0345d228111c15aeff6f7c1bc87b4ed230af96
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bf0345d
[INFO] [GitCommitIdMojo] build.commit.id = bf0345d228111c15aeff6f7c1bc87b4ed230af96
[INFO] [GitCommitIdMojo] build.commit.message.full = One more round of cleanup
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-dxf-wps ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-dxf-wps ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-dxf-wps ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-dxf-wps ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-dxf-wps ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-dxf-wps ---
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 10.8 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412.jar (5 KB at 15.9 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412.pom
2/3 KB
3/3 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412.pom (3 KB at 4.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/maven-metadata.xml
445/445 B
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/maven-metadata.xml (445 B at 3.2 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/maven-metadata.xml
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 7.6 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/maven-metadata.xml
401/401 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/maven-metadata.xml (401 B at 1.5 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412-tests.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412-tests.jar (5 KB at 14.8 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 3.3 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412-sources.jar
2/3 KB
3/3 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412-sources.jar (3 KB at 6.7 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 5.9 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412-test-sources.jar
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-20160317.223634-412-test-sources.jar (2 KB at 3.9 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 6.1 KB/sec)
[INFO]
[INFO] Building Printing Module 2.9-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-printing ---
[INFO] [GitCommitIdMojo] build.build.time = 17.03.2016 @ 22:36:39 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-printing ---
[INFO] Copying 4 resources
[INFO] Copying 16 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-printing ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-printing ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-printing ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-printing ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-printing ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-printing ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-printing >>>
[INFO]
[ERROR] Java heap space -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/OutOfMemoryError
