[Geoserver-devel] Build failed in Jenkins: geoserver-master #2346
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2346/changes&gt;
Changes:
[etj] Fix spring4 porting for geofence community modules
[...truncated 134436 lines...]
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-property/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-epsg-hsql/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-wms/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-render/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/xsd/gt-xsd-sld/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-imagemosaic/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-transform/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-shapefile/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/jdbc/gt-jdbc-postgis/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-arcgrid/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-geotiff/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-gtopo30/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-image/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geoserver/geofence/geofence-services-api/3.1-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-svg/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-process/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-process-raster/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-process-feature/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-grid/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geoserver/gs-main/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geoserver/web/gs-web-core/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geoserver/geofence/geofence-model/3.1-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/ogc/net.opengis.wfs/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/ogc/org.w3.xlink/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/ogc/net.opengis.fes/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/xsd/gt-xsd-wfs/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/xsd/gt-xsd-fes/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/xsd/gt-xsd-filter/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/xsd/gt-xsd-gml2/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-api/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-referencing/15-SNAPSHOT/maven-metadata.xml
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-geofence-server ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geofence-server ---
[INFO] Copying 6 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geofence-server ---
[INFO] Compiling 17 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geofence-server/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-geofence-server ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geofence-server/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-geofence-server ---
[INFO] Compiling 5 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geofence-server/target/test-classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[8,38\] error: cannot find symbol
[ERROR] package org.geoserver.geofence.core.dao
<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[106,17\] error: cannot find symbol
[INFO] 2 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.256 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.357 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.749 s]
[INFO] Main Module ........................................ SUCCESS [ 15.665 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.171 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.971 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.812 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.503 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 2.474 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 3.157 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.491 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.287 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.859 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 2.695 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.481 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.857 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 5.262 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.911 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.554 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 3.304 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 2.451 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.720 s]
[INFO] Demos Module ....................................... SUCCESS [ 2.434 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 2.344 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.918 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.828 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.603 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 2.422 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.701 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:31 min]
[INFO] Community Space .................................... SUCCESS [ 0.989 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.506 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 10.884 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.059 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.270 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.198 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.914 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.885 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 5.762 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.999 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.114 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.396 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.387 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 20.054 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 2.310 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 13.418 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 8.005 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.980 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.931 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.190 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.057 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.927 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.725 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.240 s]
[INFO] REST plugin community module ....................... SUCCESS [ 7.202 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.701 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.498 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.948 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 2.985 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 21.242 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.529 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 18.952 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.301 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.125 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.990 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 8.601 s]
[INFO] GeoFence Server .................................... FAILURE [ 13.910 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:46 min
[INFO] Finished at: 2016-03-30T17:47:55+00:00
[INFO] Final Memory: 190M/458M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[106,17\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2347/changes&gt;
