See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2365/>
[...truncated 18902 lines...]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-web-sec >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-web-sec <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-web-sec >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-web-sec <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.789 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-sec-cas >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sec-cas ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.9-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.986 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.259 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.795 s]
[INFO] Main Module ........................................ SUCCESS [02:13 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.082 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 51.265 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [01:44 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.294 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.670 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.791 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.355 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:31 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:24 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.406 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:02 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.709 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:07 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.077 s]
[INFO] Core UI Module ..................................... SUCCESS [01:02 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 24.602 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 12.264 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.777 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.362 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.132 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:15 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:40 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 49.301 s]
[INFO] REST UI Module ..................................... SUCCESS [ 12.764 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.095 s]
[INFO] Printing Module .................................... SUCCESS [ 13.736 s]
[INFO] Community Space .................................... SUCCESS [ 0.369 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.098 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.228 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.222 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.705 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.483 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.590 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.357 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.390 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.766 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.552 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.670 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.069 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.316 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.608 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.052 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:28 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.178 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.042 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.626 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.530 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.720 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 13.079 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.231 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 25.609 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.265 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.291 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.238 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.539 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.511 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.096 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.594 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.089 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.404 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.783 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 26.703 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.232 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.101 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.350 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.742 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 38.427 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.778 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.052 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.684 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.644 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.030 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.958 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.521 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.690 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.176 s]
[INFO] Importer Core Module ............................... SUCCESS [ 48.793 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 43.574 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 24.273 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.083 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.921 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 14.035 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 31.807 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:01 min (Wall Clock)
[INFO] Finished at: 2016-04-05T23:43:37+00:00
[INFO] Final Memory: 150M/300M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
