[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #2398
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2398/changes&gt;
Changes:
[andrea.aime] [GEOS-7317] com.thoughtworks.xstream.mapper.DynamicProxyMapper is not part of XStream class whitelist
[...truncated 21779 lines...]
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Results :
Failed tests: testNoOutputFormats(org.geoserver.wfs.xslt.GetFeatureXSLTTest)
Tests in error:
  testDelete(org.geoserver.wfs.xslt.rest.TransformRestTest): Could not remove directory .\target\default8605518174280127155data\wfs\transform after repeated attempts
Tests run: 29, Failures: 1, Errors: 1, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.883s]
[INFO] Core Platform Module .............................. SUCCESS [20.514s]
[INFO] Open Web Service Module ........................... SUCCESS [14.711s]
[INFO] Main Module ....................................... SUCCESS [3:39.618s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.905s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.770s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.368s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.836s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:06.284s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.412s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.270s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:10.009s]
[INFO] Web Map Service Module ............................ SUCCESS [4:00.973s]
[INFO] KML support for GeoServer ......................... SUCCESS [54.514s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:51.923s]
[INFO] REST Support Module ............................... SUCCESS [27.471s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:26.751s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.406s]
[INFO] Core UI Module .................................... SUCCESS [3:28.588s]
[INFO] WMS UI Module ..................................... SUCCESS [1:13.195s]
[INFO] GWC UI Module ..................................... SUCCESS [2:09.110s]
[INFO] WFS UI Module ..................................... SUCCESS [24.555s]
[INFO] Demoes Module ..................................... SUCCESS [50.715s]
[INFO] WCS UI Module ..................................... SUCCESS [41.730s]
[INFO] Security UI Modules ............................... SUCCESS [1.092s]
[INFO] Security UI Core Module ........................... SUCCESS [4:53.421s]
[INFO] Security UI JDBC Module ........................... SUCCESS [3:03.744s]
[INFO] Security UI LDAP Module ........................... SUCCESS [53.992s]
[INFO] REST UI Module .................................... SUCCESS [33.836s]
[INFO] GeoServer Web Application ......................... SUCCESS [50.435s]
[INFO] Community Space ................................... SUCCESS [0.499s]
[INFO] GeoServer Extensions .............................. SUCCESS [1.388s]
[INFO] Application Schema Support ........................ SUCCESS [1.638s]
[INFO] Application Schema Integration Test ............... SUCCESS [6:36.240s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [26.988s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.635s]
[INFO] GeoSearch Index Module ............................ SUCCESS [38.719s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.882s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.087s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.092s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.560s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.718s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.658s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [4.930s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [3.931s]
[INFO] OGR parent ........................................ SUCCESS [0.780s]
[INFO] OGR CORE .......................................... SUCCESS [5.726s]
[INFO] OGR WFS ........................................... SUCCESS [27.393s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.421s]
[INFO] Web Processing Service Module ..................... SUCCESS [8:28.795s]
[INFO] OGR WPS ........................................... SUCCESS [31.543s]
[INFO] Excel Output Format ............................... SUCCESS [40.841s]
[INFO] Chart external graphics support ................... SUCCESS [2.902s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.959s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [2.496s]
[INFO] OWS request flow controller ....................... SUCCESS [45.437s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [42.931s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:44.957s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [1:01.137s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.708s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [3.556s]
[INFO] Core Monitor Extension ............................ SUCCESS [48.064s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [29.999s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [1.622s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [49.280s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [5.725s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [6.552s]
[INFO] XLST based WFS output format ...................... FAILURE [1:08.531s]
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:10:16.004s
[INFO] Finished at: Sat Nov 21 18:08:12 CET 2015
[INFO] Final Memory: 96M/372M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-xslt: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/extension/xslt/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-xslt
Sending e-mails to: geoserver-devel@lists.sourceforge.net
Finished Calculation of disk usage of workspace in 6 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2399/&gt;
