[Geoserver-devel] Build failed in Jenkins: geoserver-master #240
See <http://ares.opengeo.org/jenkins/job/geoserver-master/240/changes&gt;
Changes:
[andrea.aime] Migrate importer tests to the new tests infrastructure
[...truncated 47449 lines...]
</gml:Polygon>
</gsml:shape>
</gsml:MappedFeature>
</gml:featureMember>
<gml:featureMember>
<gsml:MappedFeature gml:id="mf2">
<gml:name>MERCIA MUDSTONE GROUP</gml:name>
<gsml:specification xlink:href="urn:x-test:GeologicUnit:gu.25678"/>
<gsml:shape>
<gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:exterior>
<gml:LinearRing srsDimension="2">
<gml:posList>52.5 -1.3 52.6 -1.3 52.6 -1.2 52.5 -1.2 52.5 -1.3</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
<gml:featureMember>
<gsml:MappedFeature gml:id="mf3">
<gml:name>CLIFTON FORMATION</gml:name>
<gsml:shape>
<gml:exterior>
<gml:posList>52.5 -1.2 52.6 -1.2 52.6 -1.1 52.5 -1.1 52.5 -1.2</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
<gml:featureMember>
<gsml:MappedFeature gml:id="mf4">
<gml:name>MURRADUC BASALT</gml:name>
<gsml:specification xlink:href="urn:x-test:GeologicUnit:gu.25682"/>
<gsml:shape>
<gml:exterior>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
</wfs:FeatureCollection>
Jan 22, 2014 9:13:59 AM org.geoserver.test.XlinkWfsTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs/2.0&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; elementFormDefault="qualified" targetNamespace="urn:cgi:xmlns:CGI:GeoSciML:2.0">
  <xsd:import namespace="http://www.opengis.net/wfs/2.0&quot; schemaLocation="jar:file:/var/lib/jenkins/.m2/repository/org/geotools/xsd/gt-xsd-wfs/11-SNAPSHOT/gt-xsd-wfs-11-SNAPSHOT.jar!/org/geotools/wfs/v2_0/wfs.xsd"/>
  <xsd:include schemaLocation="http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd&quot;/&gt;
</xsd:schema>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.245 sec
Results :
Tests run: 150, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-test ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.5-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-test ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.5-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-app-schema-test >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-app-schema-test ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #464 from aaime/importer_test_migrate
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.01.2014 @ 08:37:50 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 22-Jan-2014 08:43
[INFO] [GitCommitIdMojo] build.build.time = 22.01.2014 @ 09:14:00 UTC
[INFO] [GitCommitIdMojo] build.branch = e79845ebbd0bf7d4c379d89cb72c3d396d2e864d
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e79845e
[INFO] [GitCommitIdMojo] build.commit.id = e79845ebbd0bf7d4c379d89cb72c3d396d2e864d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #464 from aaime/importer_test_migrate
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-app-schema-test <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-app-schema-test ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-app-schema-test >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-app-schema-test <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-app-schema-test ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-app-schema-test ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.5-SNAPSHOT/gs-app-schema-test-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.5-SNAPSHOT/gs-app-schema-test-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.5-SNAPSHOT/gs-app-schema-test-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.5-SNAPSHOT/gs-app-schema-test-2.5-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.183s]
[INFO] Core Platform Module .............................. SUCCESS [4.305s]
[INFO] Open Web Service Module ........................... SUCCESS [13.832s]
[INFO] Main Module ....................................... SUCCESS [2:36.000s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.037s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:07.766s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.277s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.665s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:05.993s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.101s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:51.701s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:52.090s]
[INFO] Web Map Service Module ............................ SUCCESS [4:41.702s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:10.018s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:59.390s]
[INFO] REST Support Module ............................... SUCCESS [40.620s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:47.615s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.433s]
[INFO] Core UI Module .................................... SUCCESS [2:09.306s]
[INFO] WMS UI Module ..................................... SUCCESS [55.940s]
[INFO] GWC UI Module ..................................... SUCCESS [1:01.924s]
[INFO] WFS UI Module ..................................... SUCCESS [35.801s]
[INFO] Demoes Module ..................................... SUCCESS [1:05.752s]
[INFO] WCS UI Module ..................................... SUCCESS [44.287s]
[INFO] Security UI Modules ............................... SUCCESS [0.813s]
[INFO] Security UI Core Module ........................... SUCCESS [3:41.941s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.367s]
[INFO] Printing Module ................................... SUCCESS [22.249s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.251s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.303s]
[INFO] Application Schema Support ........................ SUCCESS [0.265s]
[INFO] Application Schema Integration Test ............... SUCCESS [4:35.046s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.582s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [24.791s]
[INFO] GeoSearch Index Module ............................ SUCCESS [42.624s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.371s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.321s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.793s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.553s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.481s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.160s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.430s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.681s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [32.651s]
[INFO] Excel Output Format ............................... SUCCESS [34.276s]
[INFO] Validation Module ................................. SUCCESS [2.167s]
[INFO] Chart external graphics support ................... SUCCESS [1.276s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.719s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.947s]
[INFO] OWS request flow controller ....................... SUCCESS [21.875s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.365s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:41.470s]
[INFO] Web Processing Service GUI ........................ SUCCESS [49.941s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [42.878s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.266s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.546s]
[INFO] Core Monitor Extension ............................ SUCCESS [23.852s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [51.582s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [47.505s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [30.612s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.518s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [20.575s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [21.605s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:48.866s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.385s]
[INFO] DXF output format ................................. SUCCESS [33.542s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [34.417s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.438s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [44.468s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [31.605s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.372s]
[INFO] Importer Core Module .............................. FAILURE [1:34.009s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 30:59.101s (Wall Clock)
[INFO] Finished at: Wed Jan 22 09:14:00 UTC 2014
[INFO] Final Memory: 64M/220M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/241/changes&gt;
