See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2412/changes>
Changes:
[tbarsballe] [GSIP-131] Minor fixup to StyleGenerator code
[...truncated 351 lines...]
[WARNING] Failed to getClass for org.apache.maven.plugin.source.TestSourceJarMojo
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ geoserver ---
[INFO] Copying gt-api-15-SNAPSHOT.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/target/dependency/gt-api-15-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/target/dependency/gwc-core-1.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (read-manifest) @ geoserver ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[copy] Copying 1 file to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/target>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geoserver ---
[INFO] Installing <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/pom.xml> to C:\.m2\repository\org\geoserver\geoserver\2.9-SNAPSHOT\geoserver-2.9-SNAPSHOT.pom
[INFO] Installing <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/target/geoserver-2.9-SNAPSHOT-tests.jar> to C:\.m2\repository\org\geoserver\geoserver\2.9-SNAPSHOT\geoserver-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving disabled
log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
log4j:WARN Please initialize the log4j system properly.
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 7 second
[INFO]
[INFO] Building Core Platform Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-platform ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/platform/target>
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [14.602s]
[INFO] Core Platform Module .............................. FAILURE [1.029s]
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 27.940s
[INFO] Finished at: Fri Nov 27 00:57:36 CET 2015
[INFO] Final Memory: 43M/381M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-clean-plugin:2.4.1:clean (default-clean) on project gs-platform: Failed to clean project: Failed to delete <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/platform/target/gs-platform-2.9-SNAPSHOT.jar> -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
