See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2416/>
[...truncated 21858 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Results :
Failed tests: testListHTML(org.geoserver.wfs.xslt.rest.TransformRestTest)
Tests run: 29, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.646s]
[INFO] Core Platform Module .............................. SUCCESS [24.406s]
[INFO] Open Web Service Module ........................... SUCCESS [19.443s]
[INFO] Main Module ....................................... SUCCESS [4:34.966s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.063s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [38.867s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [18.492s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.553s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:16.969s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:26.396s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:25.140s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:00.995s]
[INFO] Web Map Service Module ............................ SUCCESS [5:12.022s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:06.979s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:15.314s]
[INFO] REST Support Module ............................... SUCCESS [33.252s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:54.107s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.367s]
[INFO] Core UI Module .................................... SUCCESS [2:17.035s]
[INFO] WMS UI Module ..................................... SUCCESS [49.679s]
[INFO] GWC UI Module ..................................... SUCCESS [1:25.573s]
[INFO] WFS UI Module ..................................... SUCCESS [23.088s]
[INFO] Demoes Module ..................................... SUCCESS [43.414s]
[INFO] WCS UI Module ..................................... SUCCESS [35.095s]
[INFO] Security UI Modules ............................... SUCCESS [0.863s]
[INFO] Security UI Core Module ........................... SUCCESS [2:46.113s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:50.649s]
[INFO] Security UI LDAP Module ........................... SUCCESS [33.329s]
[INFO] REST UI Module .................................... SUCCESS [27.797s]
[INFO] GeoServer Web Application ......................... SUCCESS [17.793s]
[INFO] Community Space ................................... SUCCESS [0.346s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.503s]
[INFO] Application Schema Support ........................ SUCCESS [0.435s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:31.126s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [22.369s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.999s]
[INFO] GeoSearch Index Module ............................ SUCCESS [26.724s]
[INFO] H2 DataStore Extension ............................ SUCCESS [18.274s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.540s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.725s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.522s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.965s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.643s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.601s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.596s]
[INFO] OGR parent ........................................ SUCCESS [0.418s]
[INFO] OGR CORE .......................................... SUCCESS [5.743s]
[INFO] OGR WFS ........................................... SUCCESS [19.556s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.529s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:48.144s]
[INFO] OGR WPS ........................................... SUCCESS [22.683s]
[INFO] Excel Output Format ............................... SUCCESS [27.800s]
[INFO] Chart external graphics support ................... SUCCESS [0.537s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.577s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.622s]
[INFO] OWS request flow controller ....................... SUCCESS [22.183s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [30.911s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:00.031s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [35.913s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.994s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.644s]
[INFO] Core Monitor Extension ............................ SUCCESS [27.421s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [15.300s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.732s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [12.569s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.885s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.768s]
[INFO] XLST based WFS output format ...................... FAILURE [38.097s]
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 56:22.580s
[INFO] Finished at: Fri Nov 27 17:13:18 CET 2015
[INFO] Final Memory: 97M/382M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-xslt: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/extension/xslt/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-xslt
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 2 second
