See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2425/>
[...truncated 18162 lines...]
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.386 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.844 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.219 sec
Running org.geoserver.wps.ppio.GeotiffPPIOTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.254 sec
Running org.geoserver.wps.ppio.RawDataPPIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.56 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.863 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.067 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.112 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.335 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.118 sec
Results :
Failed tests: testAsyncExecutionLimits(org.geoserver.wps.InputLimitsTest): Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
Tests run: 227, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.811s]
[INFO] Core Platform Module .............................. SUCCESS [22.934s]
[INFO] Open Web Service Module ........................... SUCCESS [16.525s]
[INFO] Main Module ....................................... SUCCESS [4:13.190s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.928s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [37.199s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [15.545s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.443s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.366s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:21.682s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:19.859s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:44.858s]
[INFO] Web Map Service Module ............................ SUCCESS [4:35.868s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:00.266s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:06.403s]
[INFO] REST Support Module ............................... SUCCESS [30.251s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:41.603s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.331s]
[INFO] Core UI Module .................................... SUCCESS [2:10.080s]
[INFO] WMS UI Module ..................................... SUCCESS [43.481s]
[INFO] GWC UI Module ..................................... SUCCESS [1:22.601s]
[INFO] WFS UI Module ..................................... SUCCESS [20.911s]
[INFO] Demoes Module ..................................... SUCCESS [38.082s]
[INFO] WCS UI Module ..................................... SUCCESS [29.899s]
[INFO] Security UI Modules ............................... SUCCESS [0.737s]
[INFO] Security UI Core Module ........................... SUCCESS [2:34.051s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:41.798s]
[INFO] Security UI LDAP Module ........................... SUCCESS [29.033s]
[INFO] REST UI Module .................................... SUCCESS [23.389s]
[INFO] GeoServer Web Application ......................... SUCCESS [16.661s]
[INFO] Community Space ................................... SUCCESS [0.355s]
[INFO] GeoServer Extensions .............................. SUCCESS [1.232s]
[INFO] Application Schema Support ........................ SUCCESS [0.411s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:06.541s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [20.369s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [21.873s]
[INFO] GeoSearch Index Module ............................ SUCCESS [24.366s]
[INFO] H2 DataStore Extension ............................ SUCCESS [18.110s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.475s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.487s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.423s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.862s]
[INFO] ImageMap Output Format ............................ SUCCESS [15.871s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.950s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.720s]
[INFO] OGR parent ........................................ SUCCESS [0.515s]
[INFO] OGR CORE .......................................... SUCCESS [4.759s]
[INFO] OGR WFS ........................................... SUCCESS [18.952s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.363s]
[INFO] Web Processing Service Module ..................... FAILURE [4:39.729s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 47:18.775s
[INFO] Finished at: Wed Dec 02 15:31:03 CET 2015
[INFO] Final Memory: 84M/415M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
