[Geoserver-devel] Build failed in Jenkins: geoserver-master #2426
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2426/changes&gt;
Changes:
[tbarsballe] Updated version to 2.10-SNAPSHOT, updated GeoTools dependency to 16-SNAPSHOT, updated GeoWebCache dependency to 1.10-SNAPSHOT, and related changes
[...truncated 18504 lines...]
[INFO] Building GeoServer Security Extension Web Modules 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-web-sec >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-web-sec <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-web-sec >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-web-sec <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.882 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-web ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-importer-web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.276 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.809 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.721 s]
[INFO] Main Module ........................................ SUCCESS [02:16 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.068 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 52.346 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [01:44 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.509 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.417 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.341 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 44.986 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:31 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:13 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.596 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 10.737 s]
[INFO] REST Support Module ................................ SUCCESS [ 15.423 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:09 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.111 s]
[INFO] Core UI Module ..................................... SUCCESS [01:04 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 24.946 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 13.139 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.031 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.233 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:12 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:39 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 47.235 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.214 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.053 s]
[INFO] Printing Module .................................... SUCCESS [ 13.625 s]
[INFO] Community Space .................................... SUCCESS [ 0.049 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.054 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:45 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.116 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.737 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.741 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.229 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.805 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.372 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.532 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.652 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.526 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.385 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.030 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.958 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.556 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.029 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:29 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.416 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.710 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.040 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.467 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.619 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 13.345 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.124 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 25.777 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.216 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.953 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.100 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.663 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.927 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.276 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.568 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 25.670 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.299 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.331 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.740 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 38.076 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.816 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.808 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.132 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.045 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.480 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.185 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.583 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.180 s]
[INFO] Importer Core Module ............................... SUCCESS [ 46.389 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 41.163 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 22.877 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.465 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.666 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 14.081 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 31.503 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:12 min (Wall Clock)
[INFO] Finished at: 2016-04-29T22:58:56+00:00
[INFO] Final Memory: 139M/278M
[ERROR] Failed to execute goal on project gs-gwc: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.10-SNAPSHOT: The following artifacts could not be resolved: org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.10-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.10-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.10-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.10-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.10-SNAPSHOT: Could not find artifact org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2427/&gt;
[...truncated 135003 lines...]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-ysld ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/ysld/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-ysld ---
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1.jar
2/9 KB
4/9 KB
6/9 KB
8/9 KB
9/9 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1.jar (9 KB at 36.4 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1.pom
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1.pom (2 KB at 10.8 KB/sec)
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml
406/406 B
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml (406 B at 5.8 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml
777/777 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (777 B at 8.9 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml
362/362 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml (362 B at 3.0 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1-tests.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1-tests.jar (7 KB at 36.6 KB/sec)
988/988 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (988 B at 11.4 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1-sources.jar (5 KB at 26.8 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 14.0 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1-test-sources.jar
2/4 KB
4/4 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160429.234906-1-test-sources.jar (4 KB at 16.6 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 16.3 KB/sec)
[INFO]
[INFO] Building GeoServer Community Release Module 2.10-SNAPSHOT
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.pom
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.pom
Downloading: http://maven.geo-solutions.it/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.community:gs-vectortiles:jar:2.10-SNAPSHOT is missing, no dependency information available
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.jar
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.jar
Downloading: http://maven.geo-solutions.it/org/geoserver/community/gs-vectortiles/2.10-SNAPSHOT/gs-vectortiles-2.10-SNAPSHOT.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.115 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.349 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.991 s]
[INFO] Main Module ........................................ SUCCESS [ 15.734 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.488 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.887 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.800 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.556 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 2.475 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.710 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.403 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.173 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.082 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 2.702 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.242 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.802 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 5.173 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.859 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.353 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 2.786 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 2.105 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.739 s]
[INFO] Demos Module ....................................... SUCCESS [ 2.439 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 2.382 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.970 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.491 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 3.226 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 2.245 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.622 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:27 min]
[INFO] Community Space .................................... SUCCESS [ 1.170 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.757 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.119 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.434 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.551 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.398 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.937 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.840 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 6.131 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.920 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.464 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.177 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 6.253 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 24.776 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.634 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 14.401 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 8.745 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.628 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.090 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.784 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.280 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.811 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.546 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.121 s]
[INFO] REST plugin community module ....................... SUCCESS [ 6.402 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.553 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.467 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.953 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 3.480 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 20.437 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.231 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 19.094 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.326 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.088 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 6.230 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.862 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.880 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.837 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.148 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.881 s]
[INFO] Importer Core Module ............................... SUCCESS [ 4.608 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.317 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.128 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.987 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.173 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.862 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.343 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.857 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.662 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.710 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.156 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 2.273 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Total time: 08:45 min
[INFO] Finished at: 2016-04-29T23:49:09+00:00
[INFO] Final Memory: 208M/462M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.10-SNAPSHOT: Could not find artifact org.geoserver.community:gs-vectortiles:jar:2.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2428/&gt;
[...truncated 135576 lines...]
[INFO]
2/2 KB
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 18.0 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2.jar
2/9 KB
4/9 KB
6/9 KB
8/9 KB
9/9 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2.jar (9 KB at 43.3 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2.pom
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2.pom (2 KB at 11.4 KB/sec)
406/406 B
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml (406 B at 5.6 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 16.1 KB/sec)
362/362 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml (362 B at 2.7 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2-tests.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2-tests.jar (7 KB at 37.0 KB/sec)
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 16.5 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2-sources.jar (5 KB at 25.9 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2-test-sources.jar
2/4 KB
4/4 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.003906-2-test-sources.jar (4 KB at 15.5 KB/sec)
2/2 KB
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.637 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.406 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.873 s]
[INFO] Main Module ........................................ SUCCESS [ 14.971 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.450 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.956 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.040 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.491 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 2.379 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.141 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.466 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.009 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.983 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 2.744 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 6.877 s]
[INFO] REST Support Module ................................ SUCCESS [ 2.049 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 5.091 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.828 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.975 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 2.168 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 2.170 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.762 s]
[INFO] Demos Module ....................................... SUCCESS [ 2.279 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 2.496 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.868 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.473 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.698 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 3.110 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.725 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:28 min]
[INFO] Community Space .................................... SUCCESS [ 0.927 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.900 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.634 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.900 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.275 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.050 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.810 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.838 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 5.304 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.877 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.309 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.066 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.616 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 24.918 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.869 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 14.211 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 9.782 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.368 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.097 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.778 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.008 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.656 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.687 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.099 s]
[INFO] REST plugin community module ....................... SUCCESS [ 6.455 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.540 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.374 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.762 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 2.931 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 19.245 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.940 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 18.133 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.350 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.850 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 6.190 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.453 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.635 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.528 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.667 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.861 s]
[INFO] Importer Core Module ............................... SUCCESS [ 4.561 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.045 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.975 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 4.158 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.056 s]
[INFO] OGR parent ......................................... SUCCESS [ 1.010 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.354 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.829 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.605 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.226 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.201 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 2.464 s]
[INFO] Total time: 08:37 min
[INFO] Finished at: 2016-04-30T00:39:10+00:00
[INFO] Final Memory: 193M/453M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2429/&gt;
[...truncated 135283 lines...]
[INFO]
2/2 KB
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 19.0 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3.jar
2/9 KB
4/9 KB
6/9 KB
8/9 KB
9/9 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3.jar (9 KB at 39.1 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3.pom
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3.pom (2 KB at 10.4 KB/sec)
406/406 B
2/2 KB
362/362 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml (362 B at 2.8 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3-tests.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3-tests.jar (7 KB at 33.5 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3-sources.jar (5 KB at 25.5 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3-test-sources.jar
2/4 KB
4/4 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.011305-3-test-sources.jar (4 KB at 15.1 KB/sec)
2/2 KB
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.352 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.374 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.382 s]
[INFO] Main Module ........................................ SUCCESS [ 19.197 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.506 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.961 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.787 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.425 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 2.412 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.406 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.404 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.199 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.735 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 2.727 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 6.883 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.798 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 5.514 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.857 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.390 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 2.463 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 2.133 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.749 s]
[INFO] Demos Module ....................................... SUCCESS [ 2.358 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 2.044 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.857 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.456 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.752 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 2.066 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.656 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:26 min]
[INFO] Community Space .................................... SUCCESS [ 0.902 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.580 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.635 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.362 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.143 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.172 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.849 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.836 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 5.782 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.916 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.134 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.096 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.634 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 23.354 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.688 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 13.460 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 8.729 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.408 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.698 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.352 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.632 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.703 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.440 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.777 s]
[INFO] REST plugin community module ....................... SUCCESS [ 6.710 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.653 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.756 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.680 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 2.893 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 18.707 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.054 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 16.345 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.271 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.388 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.862 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.101 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.542 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.682 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.633 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.878 s]
[INFO] Importer Core Module ............................... SUCCESS [ 4.873 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 6.920 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.217 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 4.094 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 7.028 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.836 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.383 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.805 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.523 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 7.052 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.101 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 3.139 s]
[INFO] Total time: 08:39 min
[INFO] Finished at: 2016-04-30T01:13:09+00:00
[INFO] Final Memory: 202M/452M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2430/changes&gt;
Changes:
[nuno.oliveira] [GEOS-7523] Make GWC settings UI only show the accepted eviction policies
[...truncated 138880 lines...]
[INFO]
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4.jar
2/9 KB
4/9 KB
6/9 KB
8/9 KB
9/9 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4.jar (9 KB at 31.1 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4.pom
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4.pom (2 KB at 8.2 KB/sec)
406/406 B
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml (406 B at 5.5 KB/sec)
2/2 KB
362/362 B
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/maven-metadata.xml (362 B at 2.4 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4-tests.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4-tests.jar (7 KB at 29.5 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4-sources.jar (5 KB at 24.0 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4-test-sources.jar
2/4 KB
4/4 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160430.115413-4-test-sources.jar (4 KB at 13.3 KB/sec)
2/2 KB
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.998 s]
[INFO] Core Platform Module ............................... SUCCESS [ 3.752 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.104 s]
[INFO] Main Module ........................................ SUCCESS [ 15.725 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.816 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 2.671 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.053 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.264 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 4.041 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.776 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 4.022 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 4.400 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.824 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 4.188 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 8.574 s]
[INFO] REST Support Module ................................ SUCCESS [ 3.050 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 6.364 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 1.169 s]
[INFO] Core UI Module ..................................... SUCCESS [ 5.215 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 3.516 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 3.637 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 2.704 s]
[INFO] Demos Module ....................................... SUCCESS [ 3.615 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 2.831 s]
[INFO] Security UI Modules ................................ SUCCESS [ 1.241 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 3.249 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 3.706 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 3.988 s]
[INFO] REST UI Module ..................................... SUCCESS [ 2.196 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:31 min]
[INFO] Community Space .................................... SUCCESS [ 1.098 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.999 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.172 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.370 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.856 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 5.521 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.168 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 1.101 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 6.447 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 1.192 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.697 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.830 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 7.178 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 25.369 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 2.399 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 15.003 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 10.186 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 6.243 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.497 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.069 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.776 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.347 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 4.838 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.999 s]
[INFO] REST plugin community module ....................... SUCCESS [ 7.446 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.759 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.282 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.936 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 3.734 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 27.086 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.262 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 19.497 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.081 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.648 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 6.349 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.349 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.809 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.782 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.672 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.958 s]
[INFO] Importer Core Module ............................... SUCCESS [ 4.853 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.139 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.544 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 4.598 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.557 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.908 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.250 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 1.004 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.642 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.461 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.185 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 2.238 s]
[INFO] Total time: 09:44 min
[INFO] Finished at: 2016-04-30T11:54:17+00:00
[INFO] Final Memory: 203M/487M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2431/changes&gt;
Changes:
[andrea.aime] [GEOS-7463] GeoServer allows for layer specific catalog/services, but not for layer group ones
[...truncated 137206 lines...]
[INFO]
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5.jar
2/9 KB
4/9 KB
6/9 KB
8/9 KB
9/9 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5.jar (9 KB at 35.1 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5.pom
2/2 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5.pom (2 KB at 10.7 KB/sec)
406/406 B
2/2 KB
362/362 B
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5-tests.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5-tests.jar (7 KB at 34.8 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5-sources.jar (5 KB at 23.8 KB/sec)
2/2 KB
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5-test-sources.jar
2/4 KB
4/4 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-20160501.193837-5-test-sources.jar (4 KB at 15.3 KB/sec)
2/2 KB
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.347 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.453 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.546 s]
[INFO] Main Module ........................................ SUCCESS [ 15.344 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.249 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.905 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.922 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.455 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 4.390 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.094 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.517 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.073 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.895 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 3.408 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.473 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.894 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 5.223 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.879 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.737 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 2.616 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 2.222 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.727 s]
[INFO] Demos Module ....................................... SUCCESS [ 2.478 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 2.140 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.903 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.483 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.654 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 2.313 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.681 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:30 min]
[INFO] Community Space .................................... SUCCESS [ 0.866 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.155 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.681 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.477 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.282 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.351 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.893 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.853 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 5.954 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 3.885 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.479 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.202 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.742 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 25.542 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.664 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 14.223 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 10.168 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.871 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.176 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.252 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.041 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.830 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 5.847 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.193 s]
[INFO] REST plugin community module ....................... SUCCESS [ 6.628 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.827 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.791 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.893 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 2.994 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 23.531 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.925 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 16.417 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.518 s]
[INFO] Solr Module ........................................ SUCCESS [ 6.418 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.824 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.220 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.723 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.652 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.653 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 1.157 s]
[INFO] Importer Core Module ............................... SUCCESS [ 4.016 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.096 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.344 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 4.643 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.475 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.880 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.500 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.898 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.532 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.812 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.966 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 2.686 s]
[INFO] Total time: 08:55 min
[INFO] Finished at: 2016-05-01T19:38:41+00:00
[INFO] Final Memory: 196M/450M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2432/changes&gt;
