[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #2494
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2494/&gt;
[...truncated 129553 lines...]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [15.315s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.372s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.190s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.914s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:12.397s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:19.824s]
[INFO] Web Map Service Module ............................ SUCCESS [4:27.733s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:01.906s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:57.916s]
[INFO] REST Support Module ............................... SUCCESS [31.321s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:29.372s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.349s]
[INFO] Core UI Module .................................... SUCCESS [1:58.686s]
[INFO] WMS UI Module ..................................... SUCCESS [41.473s]
[INFO] GWC UI Module ..................................... SUCCESS [1:14.726s]
[INFO] WFS UI Module ..................................... SUCCESS [21.034s]
[INFO] Demoes Module ..................................... SUCCESS [35.464s]
[INFO] WCS UI Module ..................................... SUCCESS [28.135s]
[INFO] Security UI Modules ............................... SUCCESS [0.725s]
[INFO] Security UI Core Module ........................... SUCCESS [2:23.644s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:42.630s]
[INFO] Security UI LDAP Module ........................... SUCCESS [28.455s]
[INFO] REST UI Module .................................... SUCCESS [22.614s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.950s]
[INFO] Community Space ................................... SUCCESS [0.829s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.301s]
[INFO] Application Schema Support ........................ SUCCESS [0.317s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:48.180s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [20.098s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [21.083s]
[INFO] GeoSearch Index Module ............................ SUCCESS [22.954s]
[INFO] H2 DataStore Extension ............................ SUCCESS [18.413s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.457s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.439s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.465s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.468s]
[INFO] ImageMap Output Format ............................ SUCCESS [16.869s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.047s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.500s]
[INFO] OGR parent ........................................ SUCCESS [0.323s]
[INFO] OGR CORE .......................................... SUCCESS [3.869s]
[INFO] OGR WFS ........................................... SUCCESS [19.013s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.315s]
[INFO] Web Processing Service Module ..................... FAILURE [6:16.330s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 46:46.735s
[INFO] Finished at: Tue Dec 29 18:06:57 CET 2015
[INFO] Final Memory: 89M/593M
[JENKINS] Archiving disabled
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
  at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:117)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:329)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:239)
  at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:178)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2495/&gt;
[...truncated 129545 lines...]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [15.830s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.629s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.703s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:21.029s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:13.275s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:16.290s]
[INFO] Web Map Service Module ............................ SUCCESS [4:26.628s]
[INFO] KML support for GeoServer ......................... SUCCESS [59.808s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:59.286s]
[INFO] REST Support Module ............................... SUCCESS [29.533s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:33.444s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.644s]
[INFO] Core UI Module .................................... SUCCESS [1:55.226s]
[INFO] WMS UI Module ..................................... SUCCESS [43.645s]
[INFO] GWC UI Module ..................................... SUCCESS [1:16.214s]
[INFO] WFS UI Module ..................................... SUCCESS [20.098s]
[INFO] Demoes Module ..................................... SUCCESS [38.985s]
[INFO] WCS UI Module ..................................... SUCCESS [28.458s]
[INFO] Security UI Modules ............................... SUCCESS [0.670s]
[INFO] Security UI Core Module ........................... SUCCESS [2:22.306s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:37.717s]
[INFO] Security UI LDAP Module ........................... SUCCESS [28.225s]
[INFO] REST UI Module .................................... SUCCESS [21.898s]
[INFO] GeoServer Web Application ......................... SUCCESS [16.399s]
[INFO] Community Space ................................... SUCCESS [1.082s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.321s]
[INFO] Application Schema Support ........................ SUCCESS [0.337s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:53.754s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [20.639s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [21.515s]
[INFO] GeoSearch Index Module ............................ SUCCESS [23.311s]
[INFO] H2 DataStore Extension ............................ SUCCESS [17.529s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.499s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.432s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.527s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.438s]
[INFO] ImageMap Output Format ............................ SUCCESS [15.178s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.238s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.576s]
[INFO] OGR parent ........................................ SUCCESS [0.417s]
[INFO] OGR CORE .......................................... SUCCESS [4.097s]
[INFO] OGR WFS ........................................... SUCCESS [18.129s]
[INFO] Web Processing Service Module ..................... FAILURE [3:15.952s]
[INFO] Total time: 43:43.703s
[INFO] Finished at: Tue Dec 29 19:08:18 CET 2015
[INFO] Final Memory: 97M/586M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2496/changes&gt;
Changes:
[ben] Update list of Project Steering Committee members
[...truncated 129287 lines...]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [18.818s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.686s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.866s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.498s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:12.746s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:14.314s]
[INFO] Web Map Service Module ............................ SUCCESS [4:25.934s]
[INFO] KML support for GeoServer ......................... SUCCESS [58.956s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:54.310s]
[INFO] REST Support Module ............................... SUCCESS [29.419s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:27.072s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.538s]
[INFO] Core UI Module .................................... SUCCESS [1:57.448s]
[INFO] WMS UI Module ..................................... SUCCESS [43.036s]
[INFO] GWC UI Module ..................................... SUCCESS [1:13.945s]
[INFO] WFS UI Module ..................................... SUCCESS [21.364s]
[INFO] Demoes Module ..................................... SUCCESS [34.803s]
[INFO] WCS UI Module ..................................... SUCCESS [31.082s]
[INFO] Security UI Modules ............................... SUCCESS [0.697s]
[INFO] Security UI Core Module ........................... SUCCESS [2:28.086s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:39.898s]
[INFO] Security UI LDAP Module ........................... SUCCESS [28.998s]
[INFO] REST UI Module .................................... SUCCESS [21.766s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.833s]
[INFO] Community Space ................................... SUCCESS [0.482s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.568s]
[INFO] Application Schema Support ........................ SUCCESS [0.366s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:51.460s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [19.832s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [20.949s]
[INFO] GeoSearch Index Module ............................ SUCCESS [24.044s]
[INFO] H2 DataStore Extension ............................ SUCCESS [17.020s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.535s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.420s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.932s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.732s]
[INFO] ImageMap Output Format ............................ SUCCESS [16.100s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.903s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.548s]
[INFO] OGR parent ........................................ SUCCESS [0.350s]
[INFO] OGR CORE .......................................... SUCCESS [4.113s]
[INFO] OGR WFS ........................................... SUCCESS [19.711s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.332s]
[INFO] Web Processing Service Module ..................... FAILURE [3:17.527s]
[INFO] Total time: 43:40.296s
[INFO] Finished at: Tue Dec 29 21:36:54 CET 2015
[INFO] Final Memory: 84M/595M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2497/&gt;
