See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2566/changes>
Changes:
[tbarsballe] GEOS-7567 GSIP-143 Module Status for GRIB
[...truncated 139069 lines...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-resource ---
[INFO] Copying 0 resource
[INFO] Copying 23 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-resource ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-resource ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-resource ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-resource ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-resource ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-web-resource ---
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 20.3 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-20160627.220434-37.jar
2/70 KB
4/70 KB
6/70 KB
8/70 KB
10/70 KB
12/70 KB
14/70 KB
16/70 KB
18/70 KB
20/70 KB
22/70 KB
24/70 KB
26/70 KB
28/70 KB
30/70 KB
32/70 KB
34/70 KB
36/70 KB
38/70 KB
40/70 KB
42/70 KB
44/70 KB
46/70 KB
48/70 KB
50/70 KB
52/70 KB
54/70 KB
56/70 KB
58/70 KB
60/70 KB
62/70 KB
64/70 KB
66/70 KB
68/70 KB
70/70 KB
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-20160627.220434-37.jar (70 KB at 321.3 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-20160627.220434-37.pom
2/2 KB
[WARNING] Failed to upload checksum org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-20160627.220434-37.pom.sha1: repo.boundlessgeo.com: unknown error
[WARNING] Failed to upload checksum org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-20160627.220434-37.pom.md5: repo.boundlessgeo.com
Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-20160627.220434-37.pom (2 KB at 0.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-web-resource/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.community:gs-web-resource/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): repo.boundlessgeo.com
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.894 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.020 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.470 s]
[INFO] Main Module ........................................ SUCCESS [ 12.743 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.861 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.765 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.413 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.109 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.862 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.756 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.401 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 2.278 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.984 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.906 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.230 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.480 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 9.410 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.689 s]
[INFO] Core UI Module ..................................... SUCCESS [ 6.740 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.858 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 4.602 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.445 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.918 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.934 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.803 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.214 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.260 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.714 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.516 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 37.304 s]
[INFO] Community Space .................................... SUCCESS [ 0.713 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.084 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 10.160 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.889 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.785 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.596 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.631 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.610 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.238 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 1.210 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 13.130 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.188 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.298 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 38.601 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.512 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 15.556 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.493 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.226 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.657 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.403 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 17.194 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 8.853 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.235 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.002 s]
[INFO] REST plugin community module ....................... SUCCESS [ 8.550 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.454 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.353 s]
[INFO] DownloadProcess .................................... SUCCESS [ 15.376 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 3.033 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 18.114 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.874 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 16.955 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.294 s]
[INFO] Solr Module ........................................ SUCCESS [ 18.577 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.752 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.797 s]
[INFO] GeoFence Server .................................... SUCCESS [ 12.879 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.749 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.230 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.853 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.744 s]
[INFO] Importer Core Module ............................... SUCCESS [ 9.227 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.094 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.972 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.753 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 11.141 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.693 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.127 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.690 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.659 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 11.541 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.980 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 8.049 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 2.229 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.689 s]
[INFO] GeoServer Resource Browser ......................... FAILURE [ 15.387 s]
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 09:26 min
[INFO] Finished at: 2016-06-27T22:04:45+00:00
[INFO] Final Memory: 173M/450M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-web-resource: Failed to retrieve remote metadata org.geoserver.community:gs-web-resource/maven-metadata.xml: Could not transfer metadata org.geoserver.community:gs-web-resource/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): repo.boundlessgeo.com: Unknown host repo.boundlessgeo.com -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-resource
