See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2571/changes>
Changes:
[groldan] Set slf4j dependencies version in root pom.
[...truncated 204975 lines...]
[INFO] Main Module ....................................... SUCCESS [3:51.639s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.639s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.115s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [21.943s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.434s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.501s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:10.600s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:03.857s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:52.466s]
[INFO] Web Map Service Module ............................ SUCCESS [4:33.837s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.018s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:49.623s]
[INFO] REST Support Module ............................... SUCCESS [25.156s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:18.735s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.327s]
[INFO] Core UI Module .................................... SUCCESS [2:06.900s]
[INFO] WMS UI Module ..................................... SUCCESS [42.130s]
[INFO] GWC UI Module ..................................... SUCCESS [1:08.450s]
[INFO] WFS UI Module ..................................... SUCCESS [16.841s]
[INFO] Demos Module ...................................... SUCCESS [30.522s]
[INFO] WCS UI Module ..................................... SUCCESS [22.832s]
[INFO] Security UI Modules ............................... SUCCESS [0.640s]
[INFO] Security UI Core Module ........................... SUCCESS [2:32.172s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:45.123s]
[INFO] Security UI LDAP Module ........................... SUCCESS [25.211s]
[INFO] REST UI Module .................................... SUCCESS [20.033s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.294s]
[INFO] Community Space ................................... SUCCESS [0.437s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.359s]
[INFO] Application Schema Support ........................ SUCCESS [0.328s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:29.688s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [16.979s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.386s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.487s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.437s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.436s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.437s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.421s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.236s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.748s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.515s]
[INFO] OGR parent ........................................ SUCCESS [0.327s]
[INFO] OGR CORE .......................................... SUCCESS [4.012s]
[INFO] OGR WFS ........................................... SUCCESS [16.311s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.327s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:39.644s]
[INFO] OGR WPS ........................................... SUCCESS [17.621s]
[INFO] Excel Output Format ............................... SUCCESS [22.005s]
[INFO] Chart external graphics support ................... SUCCESS [0.530s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.045s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.499s]
[INFO] OWS request flow controller ....................... SUCCESS [19.853s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.699s]
[INFO] Web Processing Service GUI ........................ SUCCESS [41.537s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [26.217s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.113s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.655s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.894s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.768s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.734s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [12.052s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.733s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.126s]
[INFO] XLST based WFS output format ...................... SUCCESS [31.028s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [40.837s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [23.861s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.546s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [16.997s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [16.377s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:05.227s]
[INFO] CSW UI Module ..................................... SUCCESS [17.797s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.312s]
[INFO] DXF WFS output format ............................. SUCCESS [21.209s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [16.857s]
[INFO] Printing Module ................................... SUCCESS [21.895s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.343s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [36.700s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [21.680s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [16.755s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.843s]
[INFO] Importer Core Module .............................. SUCCESS [1:11.839s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:07.987s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [31.131s]
[INFO] Importer Web UI Module ............................ SUCCESS [25.655s]
[INFO] GRIB Coverage Format .............................. FAILURE [18.776s]
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 53:39.810s
[INFO] Finished at: Mon Feb 01 20:57:11 CET 2016
[INFO] Final Memory: 110M/394M
[JENKINS] Archiving disabled
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-grib: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\grib\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-grib: There are test failures.
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:117)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:329)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:239)
at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:178)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
at hudson.remoting.UserRequest.perform(UserRequest.java:121)
at hudson.remoting.UserRequest.perform(UserRequest.java:49)
at hudson.remoting.Request$2.run(Request.java:325)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
... 30 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-grib
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 1 second
