[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #2647
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2647/changes&gt;
Changes:
[andrea.aime] Clean up repo since we have broken jars into it
[...truncated 57635 lines...]
[INFO] Main Module ....................................... SUCCESS [3:54.553s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.640s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.577s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.413s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.844s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.611s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.179s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.025s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:07.879s]
[INFO] Web Map Service Module ............................ SUCCESS [4:40.766s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.145s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:50.518s]
[INFO] REST Support Module ............................... SUCCESS [25.868s]
[INFO] REST Configuration Service Module ................. FAILURE [2:20.196s]
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:25.207s
[INFO] Finished at: Thu Feb 18 11:35:14 CET 2016
[INFO] Final Memory: 58M/449M
[JENKINS] Archiving disabled
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\restconfig\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
  at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:117)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:329)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:239)
  at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:178)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 2 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2648/changes&gt;
Changes:
[andrea.aime] wps-remote GeoServer contribution
[andrea.aime] Use ExtensionPriority instead of custom sorting
[andrea.aime] Simplify names management
[alessio.fabiani] - add support for applicazion/zip mime types
[alessio.fabiani] - Remote WPS RST Documentation first draft
[alessio.fabiani] - minor improvements to the Java Docs
[andrea.aime] Some fixes to the docs
[alessio.fabiani] - Updating the Remote WPS Community module documentation
[alessio.fabiani] - logging reference documentation
[daniele.romagnoli] [GEOS-7431]: Updating the GRIB Zip's included dependencies
[daniele.romagnoli] [GEOS-7396]: ClassCastException fix
[alessio.fabiani] - fix Python Remote WPS Git repo URL
[...truncated 57542 lines...]
[INFO] Main Module ....................................... SUCCESS [3:50.254s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.593s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.414s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.703s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.346s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.910s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.456s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.758s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:03.840s]
[INFO] Web Map Service Module ............................ SUCCESS [4:29.469s]
[INFO] KML support for GeoServer ......................... SUCCESS [50.629s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:59.907s]
[INFO] REST Support Module ............................... SUCCESS [26.782s]
[INFO] REST Configuration Service Module ................. FAILURE [2:19.672s]
[INFO] Total time: 23:14.071s
[INFO] Finished at: Thu Feb 18 13:02:29 CET 2016
[INFO] Final Memory: 59M/452M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2649/&gt;
[...truncated 57943 lines...]
[INFO] Main Module ....................................... SUCCESS [3:47.089s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.624s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [31.843s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.757s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.316s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:05.417s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.445s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.129s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:07.948s]
[INFO] Web Map Service Module ............................ SUCCESS [4:56.315s]
[INFO] KML support for GeoServer ......................... SUCCESS [50.665s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:06.236s]
[INFO] REST Support Module ............................... SUCCESS [25.540s]
[INFO] REST Configuration Service Module ................. FAILURE [2:20.751s]
[INFO] Total time: 24:06.547s
[INFO] Finished at: Sat Feb 20 03:54:55 CET 2016
[INFO] Final Memory: 61M/499M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2650/&gt;
[...truncated 57525 lines...]
[INFO] Main Module ....................................... SUCCESS [3:59.093s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.579s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.250s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.711s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.384s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:04.679s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.807s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.563s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:56.145s]
[INFO] Web Map Service Module ............................ SUCCESS [4:34.568s]
[INFO] KML support for GeoServer ......................... SUCCESS [50.074s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:51.869s]
[INFO] REST Support Module ............................... SUCCESS [25.297s]
[INFO] REST Configuration Service Module ................. FAILURE [2:22.001s]
[INFO] Total time: 23:20.872s
[INFO] Finished at: Sat Feb 20 04:43:00 CET 2016
[INFO] Final Memory: 61M/494M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2651/&gt;
[...truncated 57480 lines...]
[INFO] Main Module ....................................... SUCCESS [3:42.585s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.509s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.328s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.693s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:04.148s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.004s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.735s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:10.262s]
[INFO] Web Map Service Module ............................ SUCCESS [4:45.507s]
[INFO] KML support for GeoServer ......................... SUCCESS [51.573s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:51.861s]
[INFO] REST Support Module ............................... SUCCESS [25.335s]
[INFO] REST Configuration Service Module ................. FAILURE [2:23.693s]
[INFO] Total time: 23:27.613s
[INFO] Finished at: Sat Feb 20 11:51:31 CET 2016
[INFO] Final Memory: 61M/534M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2652/changes&gt;
Changes:
[dtucker] Updating the ResourcePool to use non-deprecated method for style retrieval
[...truncated 57645 lines...]
[INFO] Main Module ....................................... SUCCESS [3:56.971s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.660s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.428s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.372s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.067s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.394s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.045s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.800s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:12.374s]
[INFO] Web Map Service Module ............................ SUCCESS [5:02.438s]
[INFO] KML support for GeoServer ......................... SUCCESS [51.442s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:52.993s]
[INFO] REST Support Module ............................... SUCCESS [25.900s]
[INFO] REST Configuration Service Module ................. FAILURE [2:23.003s]
[INFO] Total time: 24:23.878s
[INFO] Finished at: Sat Feb 20 12:29:26 CET 2016
[INFO] Final Memory: 57M/429M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2653/&gt;
[...truncated 125972 lines...]
[INFO] Main Module ....................................... SUCCESS [3:46.904s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.686s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [34.086s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.885s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.465s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.418s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.326s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.911s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:08.204s]
[INFO] Web Map Service Module ............................ SUCCESS [4:41.950s]
[INFO] KML support for GeoServer ......................... SUCCESS [53.311s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:51.031s]
[INFO] REST Support Module ............................... SUCCESS [25.381s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:24.454s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.421s]
[INFO] Core UI Module .................................... SUCCESS [2:09.493s]
[INFO] WMS UI Module ..................................... SUCCESS [41.800s]
[INFO] GWC UI Module ..................................... SUCCESS [1:12.053s]
[INFO] WFS UI Module ..................................... SUCCESS [17.363s]
[INFO] Demos Module ...................................... SUCCESS [32.692s]
[INFO] WCS UI Module ..................................... SUCCESS [23.289s]
[INFO] Security UI Modules ............................... SUCCESS [0.673s]
[INFO] Security UI Core Module ........................... SUCCESS [2:31.560s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:45.484s]
[INFO] Security UI LDAP Module ........................... SUCCESS [25.235s]
[INFO] REST UI Module .................................... SUCCESS [21.055s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.946s]
[INFO] Community Space ................................... SUCCESS [0.375s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.546s]
[INFO] Application Schema Support ........................ SUCCESS [0.343s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:28.463s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [17.376s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.154s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.387s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.484s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.422s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.475s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.468s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.522s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.875s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.593s]
[INFO] OGR parent ........................................ SUCCESS [0.343s]
[INFO] OGR CORE .......................................... SUCCESS [3.351s]
[INFO] OGR WFS ........................................... SUCCESS [16.336s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.344s]
[INFO] Web Processing Service Module ..................... FAILURE [2:42.212s]
[INFO] Total time: 40:59.287s
[INFO] Finished at: Sat Feb 20 14:09:18 CET 2016
[INFO] Final Memory: 80M/489M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2654/changes&gt;
