[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #2667
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2667/changes&gt;
Changes:
[niels] GEOS-7407 / GSIP 137 ResourceStore Rest API: fix percent escaping
[niels] GEOS-7407 / GSIP 137 ResourceStore Rest API: fix percent escaping - fixes after review
[niels] GEOS-7407 / GSIP 137 ResourceStore Rest API: fix percent escaping - move to ResponseUtils
[...truncated 57647 lines...]
[INFO] Main Module ....................................... SUCCESS [3:54.321s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.608s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.753s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.583s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.265s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.885s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.619s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.388s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:05.849s]
[INFO] Web Map Service Module ............................ SUCCESS [4:31.438s]
[INFO] KML support for GeoServer ......................... SUCCESS [51.463s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:49.799s]
[INFO] REST Support Module ............................... SUCCESS [25.264s]
[INFO] REST Configuration Service Module ................. FAILURE [2:26.072s]
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:23.218s
[INFO] Finished at: Tue Feb 23 23:01:34 CET 2016
[INFO] Final Memory: 61M/500M
[JENKINS] Archiving disabled
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\restconfig\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
  at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:117)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:329)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:239)
  at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:178)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 2 second
Niels,
this new build failure on Windows can be reproduced on Linux by invoking Maven with -Djvm.opts="-Dfile.encoding=windows-1252" :
Tests in error:
   testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest): Invalid byte 2 of 3-byte UTF-8 sequence.
http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2667/consoleText
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2668/&gt;
[...truncated 57710 lines...]
[INFO] Main Module ....................................... SUCCESS [3:53.385s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.586s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.473s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.040s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:04.190s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.738s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:03.434s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:09.876s]
[INFO] Web Map Service Module ............................ SUCCESS [4:41.489s]
[INFO] KML support for GeoServer ......................... SUCCESS [48.723s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:41.248s]
[INFO] REST Support Module ............................... SUCCESS [22.920s]
[INFO] REST Configuration Service Module ................. FAILURE [2:12.848s]
[INFO] Total time: 22:57.325s
[INFO] Finished at: Tue Feb 23 23:48:03 CET 2016
[INFO] Final Memory: 60M/469M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
I have a fix in testing.
Kind regards,
Ben.
On 24/02/16 11:23, Ben Caradoc-Davies wrote:
Niels,
Tests in error:
Kind regards,
Director
New Zealand
Niels,
[GEOS-7435] Inconsistent encoding assumptions in GeoServerSystemTestSupport cause build failure on Windows
https://osgeo-org.atlassian.net/browse/GEOS-7435
Fix (I hope) pushed to master:
https://github.com/geoserver/geoserver/commit/ff6dace5809a538c64f4010b323f917d74fd6c55
Kind regards,
Ben.
Kind regards,
Ben.
Niels,
Tests in error:
Kind regards,
Director
New Zealand
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2669/changes&gt;
Changes:
[ben] [GEOS-7435] Inconsistent encoding assumptions in GeoServerSystemTestSupport cause build failure on Windows
[...truncated 58344 lines...]
[INFO] Main Module ....................................... SUCCESS [4:04.509s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.644s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.874s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [15.078s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.269s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:04.318s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:13.209s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.521s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:07.627s]
[INFO] Web Map Service Module ............................ SUCCESS [4:46.057s]
[INFO] KML support for GeoServer ......................... SUCCESS [49.570s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:48.999s]
[INFO] REST Support Module ............................... SUCCESS [23.944s]
[INFO] REST Configuration Service Module ................. FAILURE [2:14.095s]
[INFO] Total time: 23:51.604s
[INFO] Finished at: Wed Feb 24 01:17:15 CET 2016
[INFO] Final Memory: 61M/583M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 3 second
OK, the fix worked for testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest), now just the Resource.lastmodified discrepancy to resolve.
Kind regards,
Ben.
On 24/02/16 12:46, Ben Caradoc-Davies wrote:
Niels,
Kind regards,
Ben.
Kind regards,
Ben.
Niels,
Tests in error:
Kind regards,
Director
New Zealand
Niels,
I think I have the Windows Resource.lastmodified failure fixed:
[GEOS-7436] Invalid directory timestamp assumptions in ResourceTest break build on Windows
https://osgeo-org.atlassian.net/browse/GEOS-7436
In a nutshell, testDirectory* should compare against myRes.parent().lastmodified() not myRes.lastmodified() as it is the parent's timestamp being requested. Perhaps filesystem metadata updates are slower on Windows? Anyway, I do not think there is any guarantee that these are the same. Maybe Linux is just too fast to notice the difference. :slight_smile:
https://github.com/geoserver/geoserver/commit/dc131378e28b7a0e2241f90db425cad1990e70b9
Kind regards,
Ben.
Kind regards,
Ben.
Director
New Zealand
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2670/changes&gt;
Thanks for these fixes, Ben!
On 24-02-16 02:12, Ben Caradoc-Davies wrote:
Niels,
Kind regards,
Ben.
Kind regards,
Ben.
