[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #2718
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2718/&gt;
[...truncated 34751 lines...]
[INFO] Main Module ....................................... SUCCESS [3:57.587s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.640s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [35.971s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [15.047s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.792s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:05.139s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.472s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.106s]
[INFO] Web Feature Service Module ........................ FAILURE [3:04.362s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Demos Module ...................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 13:43.730s
[INFO] Finished at: Thu Mar 10 18:17:17 CET 2016
[INFO] Final Memory: 59M/584M
[JENKINS] Archiving disabled
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
  at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:117)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:329)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:239)
  at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:178)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 3 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2719/&gt;
[...truncated 34715 lines...]
[INFO] Main Module ....................................... SUCCESS [4:03.402s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.905s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [36.313s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.839s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.087s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.502s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.925s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.901s]
[INFO] Web Feature Service Module ........................ FAILURE [3:05.884s]
[INFO] Total time: 13:27.929s
[INFO] Finished at: Thu Mar 10 18:55:49 CET 2016
[INFO] Final Memory: 55M/472M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 2 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2720/&gt;
[...truncated 35112 lines...]
[INFO] Main Module ....................................... SUCCESS [3:48.613s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.639s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [30.536s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.300s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.570s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.243s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.186s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.816s]
[INFO] Web Feature Service Module ........................ FAILURE [2:49.190s]
[INFO] Total time: 13:24.328s
[INFO] Finished at: Sat Mar 12 11:33:00 CET 2016
[INFO] Final Memory: 58M/585M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2721/&gt;
[...truncated 34561 lines...]
[INFO] Main Module ....................................... SUCCESS [3:36.258s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.577s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.992s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.361s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.790s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:05.530s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:13.095s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.506s]
[INFO] Web Feature Service Module ........................ FAILURE [3:09.611s]
[INFO] Total time: 13:06.037s
[INFO] Finished at: Sat Mar 12 11:57:38 CET 2016
[INFO] Final Memory: 55M/504M
[ERROR]
[ERROR] -> [Help 1]
  ... 30 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2722/&gt;
