See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2750/>
[...truncated 51671 lines...]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 27:39.767s
[INFO] Finished at: Wed Mar 23 22:56:26 CET 2016
[INFO] Final Memory: 84M/270M
[JENKINS] Archiving disabled
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GWCGeoServerRESTConfigurationProvider.java:[8,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[34,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[35,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[36,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[26,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[27,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[1225,73] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[13,20] error: package javax.servlet does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[16,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[88,38] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[88,69] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[113,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[190,48] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[214,61] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[195,32] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[200,15] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[18,20] error: package javax.servlet does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[19,20] error: package javax.servlet does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[20,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[22,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[27,40] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[47,12] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[49,68] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[53,68] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[71,11] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[135,11] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[139,11] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[187,11] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletRequest.java:[252,11] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[17,20] error: package javax.servlet does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[18,25] error: package javax.servlet.http does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[26,48] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[30,57] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[49,17] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[57,11] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[73,26] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[170,11] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GWCGeoServerRESTConfigurationProvider.java:[94,49] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GWCGeoServerRESTConfigurationProvider.java:[104,57] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GWCGeoServerRESTConfigurationProvider.java:[113,57] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GWCGeoServerRESTConfigurationProvider.java:[124,49] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[778,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[779,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[1234,36] error: incompatible types: FakeHttpServletRequest cannot be converted to HttpServletRequest
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[1239,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\GWC.java:[1258,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[427,61] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[621,12] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[622,12] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[99,50] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[199,8] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[204,8] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[218,8] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\dispatch\GwcServiceProxy.java:[223,8] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\wms\CachingWebMapService.java:[119,45] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\wms\CachingWebMapService.java:[166,53] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[28,50] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[58,37] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[58,69] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\FakeHttpServletResponse.java:[75,36] error: cannot find symbol
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:117)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:329)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:239)
at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:178)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
at hudson.remoting.UserRequest.perform(UserRequest.java:121)
at hudson.remoting.UserRequest.perform(UserRequest.java:49)
at hudson.remoting.Request$2.run(Request.java:325)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.CompilationFailureException: Compilation failure
at org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:656)
at org.apache.maven.plugin.CompilerMojo.execute(CompilerMojo.java:128)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
... 30 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 3 second
