See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2795/changes>
Changes:
[rini.angreani] Revert "Merge branch 'master' of
[rini.angreani] Revert "GEOS-7062: fix app-schema online test with Oracle. "
[...truncated 24607 lines...]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.448 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 8.050 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.082 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.980 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.944 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.849 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.527 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.468 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.061 s]
[INFO] REST plugin community module ....................... SUCCESS [ 6.041 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.952 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.400 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.716 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 2.326 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 13.535 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.827 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 15.546 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.967 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.897 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.662 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 8.127 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.338 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.654 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.875 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.275 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.670 s]
[INFO] Importer Core Module ............................... SUCCESS [ 3.645 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 6.987 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.888 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.724 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.776 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.939 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.662 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.401 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.613 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.502 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.674 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.871 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.185 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.201 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 6.799 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:35 min
[INFO] Finished at: 2016-07-29T02:22:10+00:00
[INFO] Final Memory: 171M/429M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[27,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[28,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[29,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[30,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[31,40\] error: package org.locationtech.geogig.api.hooks does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[32,40\] error: package org.locationtech.geogig.api.hooks does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[33,40\] error: package org.locationtech.geogig.api.hooks does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[34,43\] error: package org.locationtech.geogig.api.plumbing does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[35,43\] error: package org.locationtech.geogig.api.plumbing does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[58,53\] error: cannot find symbol
[ERROR] class CommandHook
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[70,45\] error: cannot find symbol
[ERROR] class TruncateTilesOnUpdateRefHook
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[75,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[76,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[100,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[150,40\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[151,21\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[151,45\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[164,61\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/TruncateTilesOnUpdateRefHook.java>:\[202,65\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/data/store/geogig/BranchSelectionPanel.java>:\[21,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryInfo.java>:\[13,43\] error: package org.locationtech.geogig.api.plumbing does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[32,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[33,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[34,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[35,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[36,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[37,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[38,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[39,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[40,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryCache.java>:\[17,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[117,11\] error: cannot find symbol
[ERROR] class RepositoryManager
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[305,16\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[311,11\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[347,18\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[368,34\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryManager.java>:\[368,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryCache.java>:\[32,39\] error: cannot find symbol
[ERROR] class RepositoryCache
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/config/RepositoryCache.java>:\[88,11\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[9,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[10,40\] error: package org.locationtech.geogig.api.hooks does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[11,40\] error: package org.locationtech.geogig.api.hooks does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[21,40\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[24,45\] error: cannot find symbol
[ERROR] class SecurityLogHook
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[29,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[30,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogHook.java>:\[37,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RemoteInfo.java>:\[15,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RemoteInfo.java>:\[16,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RemotesListPanel.java>:\[33,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RemotesListPanel.java>:\[34,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RemoteInfo.java>:\[87,11\] error: cannot find symbol
[ERROR] class RemoteInfo
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RemoteInfo.java>:\[98,36\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RemoteInfo.java>:\[116,54\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[9,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[10,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[11,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[12,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[13,43\] error: package org.locationtech.geogig.api.plumbing does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[14,48\] error: package org.locationtech.geogig.api.plumbing.diff does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[40,39\] error: cannot find symbol
[ERROR] class AbstractGeoGigOp
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/gwc/MinimalDiffBounds.java>:\[84,12\] error: cannot find symbol
[ERROR] class MinimalDiffBounds
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[28,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[29,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[30,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[31,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[32,43\] error: package org.locationtech.geogig.api.plumbing does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[33,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[34,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[35,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/web/repository/RepositoryEditFormPanel.java>:\[200,31\] error: cannot find symbol
[ERROR] class RepositoryEditFormPanel
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitRequestHandler.java>:\[19,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitRequestHandler.java>:\[235,20\] error: cannot find symbol
[ERROR] class InitRequestHandler
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[9,60\] error: package org.locationtech.geogig.api.porcelain.ConfigOp does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[9,0\] error: static import only from classes and interfaces
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[10,60\] error: package org.locationtech.geogig.api.porcelain.ConfigOp does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[10,0\] error: static import only from classes and interfaces
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[25,43\] error: package org.locationtech.geogig.api.plumbing does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[26,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[18,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[19,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[20,40\] error: package org.locationtech.geogig.api.hooks does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[21,40\] error: package org.locationtech.geogig.api.hooks does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[22,43\] error: package org.locationtech.geogig.api.plumbing does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[23,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[24,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[25,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[35,50\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[38,22\] error: cannot find symbol
[ERROR] class NetworkSecurityHook
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[39,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[72,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[78,45\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/NetworkSecurityHook.java>:\[83,58\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogger.java>:\[19,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogger.java>:\[20,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogger.java>:\[21,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogger.java>:\[22,34\] error: package org.locationtech.geogig.api does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogger.java>:\[23,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogger.java>:\[24,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/security/SecurityLogger.java>:\[25,44\] error: package org.locationtech.geogig.api.porcelain does not exist
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
