[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #2861
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2861/changes&gt;
Changes:
[tbarsballe] Updated version to 2.10-SNAPSHOT, updated GeoTools dependency to 16-SNAPSHOT, updated GeoWebCache dependency to 1.10-SNAPSHOT, and related changes
[...truncated 35818 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 55.427 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.725 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 36.560 s]
[INFO] Main Module ........................................ SUCCESS [04:51 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.593 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 33.195 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.234 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.250 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [01:05 min]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [01:07 min]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:59 min]
[INFO] Web Feature Service Module ......................... SUCCESS [03:06 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:51 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 47.990 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 18.564 s]
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 21:18 min
[INFO] Finished at: 2016-04-30T00:48:51+02:00
[INFO] Final Memory: 136M/516M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal on project gs-gwc: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.10-SNAPSHOT: The following artifacts could not be resolved: org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.10-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.10-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.10-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.10-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.10-SNAPSHOT: Could not find artifact org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project gs-gwc: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.10-SNAPSHOT: The following artifacts could not be resolved: org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.10-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.10-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.10-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.10-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.10-SNAPSHOT: Could not find artifact org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/)
  at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.getDependencies(LifecycleDependencyResolver.java:221)
  at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.resolveProjectDependencies(LifecycleDependencyResolver.java:127)
  at org.apache.maven.lifecycle.internal.MojoExecutor.ensureDependenciesAreResolved(MojoExecutor.java:245)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:199)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
  at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
  at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
  at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.project.DependencyResolutionException: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.10-SNAPSHOT: The following artifacts could not be resolved: org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.10-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.10-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.10-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.10-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.10-SNAPSHOT: Could not find artifact org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/)
  at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:211)
  at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.getDependencies(LifecycleDependencyResolver.java:195)
  ... 34 more
Caused by: org.eclipse.aether.resolution.DependencyResolutionException: The following artifacts could not be resolved: org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.10-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.10-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.10-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.10-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.10-SNAPSHOT: Could not find artifact org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/)
  at org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveDependencies(DefaultRepositorySystem.java:384)
  at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:205)
  ... 35 more
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException: The following artifacts could not be resolved: org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.10-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.10-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.10-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.10-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.10-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.10-SNAPSHOT: Could not find artifact org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/)
  at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:444)
  at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:246)
  at org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveDependencies(DefaultRepositorySystem.java:367)
  ... 36 more
Caused by: org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact org.geowebcache:gwc-georss:jar:1.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/)
  at org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:39)
  at org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:355)
  at org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:67)
  ... 3 more
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 3 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2862/&gt;
