See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2992/changes>
Changes:
[andrea.aime] [GEOS-7457] Stop using System.out.println, use logger instead
[...truncated 1419 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.210 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.834 s]
[INFO] Open Web Service Module ............................ FAILURE [01:08 min]
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 02:02 min
[INFO] Finished at: 2016-06-18T15:54:29+02:00
[INFO] Final Memory: 107M/449M
[ERROR] Failed to execute goal on project gs-ows: Could not resolve dependencies for project org.geoserver:gs-ows:jar:2.10-SNAPSHOT: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed: Premature end of Content-Length delimited message body (expected: 532393; received: 48484 -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project gs-ows: Could not resolve dependencies for project org.geoserver:gs-ows:jar:2.10-SNAPSHOT: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed
at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.getDependencies(LifecycleDependencyResolver.java:221)
at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.resolveProjectDependencies(LifecycleDependencyResolver.java:127)
at org.apache.maven.lifecycle.internal.MojoExecutor.ensureDependenciesAreResolved(MojoExecutor.java:245)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:199)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
at hudson.remoting.UserRequest.perform(UserRequest.java:121)
at hudson.remoting.UserRequest.perform(UserRequest.java:49)
at hudson.remoting.Request$2.run(Request.java:325)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.project.DependencyResolutionException: Could not resolve dependencies for project org.geoserver:gs-ows:jar:2.10-SNAPSHOT: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed
at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:211)
at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.getDependencies(LifecycleDependencyResolver.java:195)
... 34 more
Caused by: org.eclipse.aether.resolution.DependencyResolutionException: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed
at org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveDependencies(DefaultRepositorySystem.java:384)
at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:205)
... 35 more
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:444)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:246)
at org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveDependencies(DefaultRepositorySystem.java:367)
... 36 more
Caused by: org.eclipse.aether.transfer.ArtifactTransferException: Could not transfer artifact org.geotools.ogc:net.opengis.ows:jar:16-20160618.040933-34 from/to boundless (https://repo.boundlessgeo.com/main/): GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed
at org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:43)
at org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:355)
at org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:67)
at org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:581)
at org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:249)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:520)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:421)
... 38 more
Caused by: org.apache.maven.wagon.TransferFailedException: GET request of: org/geotools/ogc/net.opengis.ows/16-SNAPSHOT/net.opengis.ows-16-20160618.040933-34.jar from boundless failed
at org.apache.maven.wagon.AbstractWagon.getTransfer(AbstractWagon.java:363)
at org.apache.maven.wagon.AbstractWagon.getTransfer(AbstractWagon.java:316)
at org.apache.maven.wagon.AbstractWagon.getTransfer(AbstractWagon.java:285)
at org.apache.maven.wagon.StreamWagon.getIfNewer(StreamWagon.java:97)
at org.apache.maven.wagon.StreamWagon.get(StreamWagon.java:61)
at org.eclipse.aether.transport.wagon.WagonTransporter$GetTaskRunner.run(WagonTransporter.java:560)
at org.eclipse.aether.transport.wagon.WagonTransporter.execute(WagonTransporter.java:427)
at org.eclipse.aether.transport.wagon.WagonTransporter.get(WagonTransporter.java:404)
at org.eclipse.aether.connector.basic.BasicRepositoryConnector$GetTaskRunner.runTask(BasicRepositoryConnector.java:447)
at org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:350)
... 43 more
Caused by: org.apache.maven.wagon.providers.http.httpclient.ConnectionClosedException: Premature end of Content-Length delimited message body (expected: 532393; received: 48484
at org.apache.maven.wagon.providers.http.httpclient.impl.io.ContentLengthInputStream.read(ContentLengthInputStream.java:180)
at org.apache.maven.wagon.providers.http.httpclient.conn.EofSensorInputStream.read(EofSensorInputStream.java:137)
at org.apache.maven.wagon.AbstractWagon.transfer(AbstractWagon.java:531)
at org.apache.maven.wagon.AbstractWagon.getTransfer(AbstractWagon.java:353)
... 52 more
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 2 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2993/>
[...truncated 1356 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 18.330 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.721 s]
[INFO] Open Web Service Module ............................ FAILURE [01:10 min]
[INFO] Total time: 02:10 min
[INFO] Finished at: 2016-06-18T17:11:24+02:00
[INFO] Final Memory: 106M/466M
... 34 more
... 35 more
... 36 more
... 38 more
... 43 more
... 52 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2994/changes>
Changes:
[andrea.aime] [GEOS-7530] Style editor does not escape style replacement confirmation errors, fails in languages using single quote
[...truncated 284 lines...]
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 4.883 s]
[INFO] Core Platform Module ............................... SKIPPED
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Total time: 20.780 s
[INFO] Finished at: 2016-06-19T17:11:14+02:00
[INFO] Final Memory: 61M/332M
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.10-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-api:jar:16-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-api:jar:16-SNAPSHOT: Could not find artifact org.geotools:library:pom:16-20160618.040610-34 in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.10-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-api:jar:16-SNAPSHOT
Caused by: org.apache.maven.project.DependencyResolutionException: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.10-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-api:jar:16-SNAPSHOT
at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:180)
... 34 more
Caused by: org.eclipse.aether.collection.DependencyCollectionException: Failed to collect dependencies at org.geotools:gt-api:jar:16-SNAPSHOT
at org.eclipse.aether.internal.impl.DefaultDependencyCollector.collectDependencies(DefaultDependencyCollector.java:291)
at org.eclipse.aether.internal.impl.DefaultRepositorySystem.collectDependencies(DefaultRepositorySystem.java:316)
at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:172)
... 35 more
Caused by: org.eclipse.aether.resolution.ArtifactDescriptorException: Failed to read artifact descriptor for org.geotools:gt-api:jar:16-SNAPSHOT
at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.loadPom(DefaultArtifactDescriptorReader.java:329)
at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.readArtifactDescriptor(DefaultArtifactDescriptorReader.java:198)
at org.eclipse.aether.internal.impl.DefaultDependencyCollector.resolveCachedArtifactDescriptor(DefaultDependencyCollector.java:535)
at org.eclipse.aether.internal.impl.DefaultDependencyCollector.getArtifactDescriptorResult(DefaultDependencyCollector.java:519)
at org.eclipse.aether.internal.impl.DefaultDependencyCollector.processDependency(DefaultDependencyCollector.java:409)
at org.eclipse.aether.internal.impl.DefaultDependencyCollector.processDependency(DefaultDependencyCollector.java:363)
at org.eclipse.aether.internal.impl.DefaultDependencyCollector.process(DefaultDependencyCollector.java:351)
at org.eclipse.aether.internal.impl.DefaultDependencyCollector.collectDependencies(DefaultDependencyCollector.java:254)
... 37 more
Caused by: org.apache.maven.model.resolution.UnresolvableModelException: Could not find artifact org.geotools:library:pom:16-20160618.040610-34 in boundless (https://repo.boundlessgeo.com/main/)
at org.apache.maven.repository.internal.DefaultModelResolver.resolveModel(DefaultModelResolver.java:177)
at org.apache.maven.repository.internal.DefaultModelResolver.resolveModel(DefaultModelResolver.java:226)
at org.apache.maven.model.building.DefaultModelBuilder.readParentExternally(DefaultModelBuilder.java:1000)
at org.apache.maven.model.building.DefaultModelBuilder.readParent(DefaultModelBuilder.java:800)
at org.apache.maven.model.building.DefaultModelBuilder.build(DefaultModelBuilder.java:329)
at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.loadPom(DefaultArtifactDescriptorReader.java:320)
... 44 more
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException: Could not find artifact org.geotools:library:pom:16-20160618.040610-34 in boundless (https://repo.boundlessgeo.com/main/)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:223)
at org.apache.maven.repository.internal.DefaultModelResolver.resolveModel(DefaultModelResolver.java:173)
... 49 more
Caused by: org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact org.geotools:library:pom:16-20160618.040610-34 in boundless (https://repo.boundlessgeo.com/main/)
at org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:39)
... 52 more
[ERROR]
[ERROR]
channel stopped
