[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #2996
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2996/changes&gt;
Changes:
[andrea.aime] Compensating minor color differences due to change in color ramp setup in geotools
[...truncated 31986 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.179 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.451 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.425 s]
[INFO] Main Module ........................................ SUCCESS [03:59 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.546 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 30.503 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.997 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.341 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 57.683 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [01:04 min]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:57 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:56 min]
[INFO] Web Map Service Module ............................. FAILURE [04:33 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:33 min
[INFO] Finished at: 2016-06-20T17:10:41+02:00
[INFO] Final Memory: 111M/434M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\wms\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
  at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
  at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
  at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 2 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2997/changes&gt;
Changes:
[andrea.aime] Simplify and generalize dynamic legend generation, so that it works with all env variables and also supports get legend against groups.
[...truncated 31957 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.805 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.913 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.418 s]
[INFO] Main Module ........................................ SUCCESS [03:55 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.624 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 30.081 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 17.029 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.451 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 57.558 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [01:03 min]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:52 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:55 min]
[INFO] Web Map Service Module ............................. FAILURE [04:51 min]
[INFO] Total time: 17:40 min
[INFO] Finished at: 2016-06-20T21:13:43+02:00
[INFO] Final Memory: 113M/513M
[ERROR]
[ERROR] -> [Help 1]
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2998/changes&gt;
