[Geoserver-devel] Build failed in Jenkins: geoserver-master #3015
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3015/&gt;
[...truncated 22239 lines...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-kmlppio ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/kmlppio/target/gs-kmlppio-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-kmlppio ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/kmlppio/target/gs-kmlppio-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/kmlppio/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/kmlppio/target/gs-kmlppio-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/kmlppio/target/gs-kmlppio-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/kmlppio/target/gs-kmlppio-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-kmlppio ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 0.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543.jar (9 KB at 19.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543.pom (2 KB at 7.2 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/maven-metadata.xml (365 B at 6.5 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 17.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/maven-metadata.xml (365 B at 3.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543-tests.jar (12 KB at 33.2 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 18.0 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543-sources.jar (4 KB at 10.4 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 16.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543-test-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/gs-kmlppio-2.10-20160827.211736-543-test-sources.jar (9 KB at 22.6 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-kmlppio/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 17.3 KB/sec)
[INFO]
[INFO] Building DownloadProcess 2.10-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-wps-download ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-download ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-download ---
[INFO] Compiling 16 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-download ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-download ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wps-download ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-download ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-download ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-download ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-download ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-download ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wps-download/2.10-SNAPSHOT/gs-wps-download-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wps-download/2.10-SNAPSHOT/gs-wps-download-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wps-download/2.10-SNAPSHOT/gs-wps-download-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wps-download/2.10-SNAPSHOT/gs-wps-download-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wps-download/target/gs-wps-download-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wps-download/2.10-SNAPSHOT/gs-wps-download-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-wps-download ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wps-download/2.10-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.community:gs-wps-download:2.10-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [08:30 min]
[INFO] Core Platform Module ............................... SUCCESS [ 3.085 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.867 s]
[INFO] Main Module ........................................ SUCCESS [ 13.558 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.145 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 2.671 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.710 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.760 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 3.800 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.459 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 3.044 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.329 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.424 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 3.308 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 6.570 s]
[INFO] REST Support Module ................................ SUCCESS [ 2.382 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.992 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 1.538 s]
[INFO] Core UI Module ..................................... SUCCESS [ 6.249 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 2.515 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 2.818 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 2.463 s]
[INFO] Demos Module ....................................... SUCCESS [ 3.395 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 3.589 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.897 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 3.129 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.901 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 2.654 s]
[INFO] REST UI Module ..................................... SUCCESS [ 2.546 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 35.375 s]
[INFO] Community Space .................................... SUCCESS [ 0.753 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.062 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.222 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 34.785 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.481 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.219 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.849 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.811 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 5.683 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.774 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 8.133 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.991 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 6.262 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 23.838 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.988 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 11.897 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 9.463 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 6.082 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.403 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.723 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.518 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.166 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.876 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.725 s]
[INFO] REST plugin community module ....................... SUCCESS [ 7.046 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.545 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 20.832 s]
[INFO] DownloadProcess .................................... FAILURE [01:08 min]
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15:37 min
[INFO] Finished at: 2016-08-27T21:18:47+00:00
[INFO] Final Memory: 159M/441M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-wps-download: Failed to retrieve remote metadata org.geoserver.community:gs-wps-download:2.10-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.community:gs-wps-download:2.10-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-download
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3016/&gt;
[...truncated 17073 lines...]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.889 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.415 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.083 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.19 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [464 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.war
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.125 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.805 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.507 s]
[INFO] Main Module ........................................ SUCCESS [10:40 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.151 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 42.452 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:10 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.226 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [02:38 min]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [01:29 min]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.213 s]
[INFO] Web Feature Service Module ......................... SUCCESS [02:45 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:14 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.235 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:11 min]
[INFO] REST Support Module ................................ SUCCESS [ 14.462 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:18 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.095 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.931 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 45.172 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.901 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.976 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.415 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.093 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:20 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:10 min]
[INFO] REST UI Module ..................................... SUCCESS [ 14.517 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.051 s]
[INFO] Printing Module .................................... SUCCESS [ 13.442 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.148 s]
[INFO] Community Space .................................... SUCCESS [ 0.060 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.054 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.670 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [02:18 min]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.047 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.148 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.860 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.402 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.101 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.966 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... FAILURE [03:11 min]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 15.868 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.056 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.914 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.953 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.047 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:39 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.745 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.299 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.765 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 10.869 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.740 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 14.965 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.022 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.164 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.309 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [01:04 min]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.091 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.397 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.734 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.135 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.061 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.073 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.549 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.094 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.754 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 26.223 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.082 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.699 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.179 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.131 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.900 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.052 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.884 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.472 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.028 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.307 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.369 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.164 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.071 s]
[INFO] Importer Core Module ............................... SUCCESS [ 52.863 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 42.893 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.707 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.018 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.871 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.976 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 33.061 s]
[INFO] Total time: 33:40 min (Wall Clock)
[INFO] Finished at: 2016-08-28T08:42:28+00:00
[INFO] Final Memory: 114M/294M
[ERROR] Failed to execute goal on project gs-gdal: Could not resolve dependencies for project org.geoserver.extension:gs-gdal:jar:2.10-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-imageio-ext-gdal:jar:16-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-imageio-ext-gdal:jar:16-SNAPSHOT: Could not transfer artifact org.geotools:gt-imageio-ext-gdal:pom:16-20160828.065210-236 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gdal
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3017/changes&gt;
Changes:
[jody.garnett] [GEOS-7667] Fixed a REST request URL issue. (#1784)
[jody.garnett] Donating YSLD reference from Boundless Suite
[...truncated 17122 lines...]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.812 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.36 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.986 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.333 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.188 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.454 s]
[INFO] Main Module ........................................ SUCCESS [02:37 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.053 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.736 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:36 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.825 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 58.949 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.986 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.157 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:54 min]
[INFO] Web Map Service Module ............................. SUCCESS [08:31 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.747 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:46 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.589 s]
[INFO] REST Configuration Service Module .................. SUCCESS [02:13 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.066 s]
[INFO] Core UI Module ..................................... SUCCESS [01:27 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.567 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 46.914 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.134 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.395 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.140 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.059 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:47 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.504 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.046 s]
[INFO] Printing Module .................................... SUCCESS [ 13.456 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.103 s]
[INFO] Community Space .................................... SUCCESS [ 0.063 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.108 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:50 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [01:14 min]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.426 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.269 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.229 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.508 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.553 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.241 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.362 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.732 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.265 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.049 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.862 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [05:44 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.778 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.215 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.509 s]
[INFO] Feature Generalization Extension ................... SUCCESS [01:04 min]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.079 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.909 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.919 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.298 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.212 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 5.215 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.574 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.198 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.179 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.512 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.286 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.092 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.160 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [02:15 min]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.344 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.761 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.681 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.024 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.319 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.982 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.489 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.579 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.198 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.052 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.879 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 40.922 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 22.896 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.994 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.121 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.187 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [02:06 min]
[INFO] Total time: 31:09 min (Wall Clock)
[INFO] Finished at: 2016-08-28T10:25:48+00:00
[INFO] Final Memory: 114M/325M
[ERROR] Failed to execute goal on project gs-netcdf-out: Could not resolve dependencies for project org.geoserver.extension:gs-netcdf-out:jar:2.10-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-jts-wrapper:jar:16-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-jts-wrapper:jar:16-SNAPSHOT: Could not transfer artifact org.geotools:gt-jts-wrapper:pom:16-20160828.095115-235 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3018/&gt;
