[Geoserver-devel] Build failed in Jenkins: geoserver-master #315
See <http://ares.opengeo.org/jenkins/job/geoserver-master/315/changes&gt;
Changes:
[surzhin.konstantin] Attribute name "type" associated with an element type "style" must be followed by the ' = ' character
[...truncated 73018 lines...]
262144/?
266240/?
270336/?
274432/?
278528/?
282624/?
286720/?
290816/?
294912/?
299008/?
303104/?
307200/?
311296/?
315392/?
319488/?
323584/?
327680/?
331776/?
335872/?
339968/?
344064/?
348160/?
352256/?
356352/?
360448/?
364544/?
368640/?
372736/?
376832/?
380928/?
385024/?
389120/?
393216/?
397312/?
401408/?
405504/?
409600/?
413696/?
417792/?
421888/?
425984/?
430080/?
434176/?
438272/?
442368/?
446464/?
446817/?
[INFO] Building Web Processing Service GUI
[INFO] task-segment: [deploy]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #487 from Konstantin-Surzhin/AuthenticationFilterPanel_html
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.02.2014 @ 13:06:12 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Feb-2014 13:43
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2014 @ 13:53:18 UTC
[INFO] [GitCommitIdMojo] build.branch = 2752db500a96700da36135abb2bda99b601bff7a
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2752db5
[INFO] [GitCommitIdMojo] build.commit.id = 2752db500a96700da36135abb2bda99b601bff7a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #487 from Konstantin-Surzhin/AuthenticationFilterPanel_html
I've added "="
[INFO] Copying 10 resources
[INFO] Copying 7 resources
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/11-SNAPSHOT/gt-wms-11-SNAPSHOT.jar
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/src/test/resources&gt;
[INFO] Tests are skipped.
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/gs-web-wps-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT-test-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
57344/?
61440/?
65536/?
69632/?
73728/?
77824/?
81920/?
83538/?
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:gs-web-wps'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:gs-web-wps:2.5-SNAPSHOT'
[INFO] Uploading project information for gs-web-wps 2.5-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT-tests.jar
4096/?
8192/?
9701/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
37832/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-web-wps/2.5-SNAPSHOT/gs-web-wps-2.5-SNAPSHOT-test-sources.jar
4096/?
5328/?
[INFO] Building GeoServer Layer Querying filter functions
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2014 @ 13:53:20 UTC
I've added "="
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/src/test/resources&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/gs-querylayer-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/gs-querylayer-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/gs-querylayer-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-querylayer/2.5-SNAPSHOT/gs-querylayer-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/gs-querylayer-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-querylayer/2.5-SNAPSHOT/gs-querylayer-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/gs-querylayer-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-querylayer/2.5-SNAPSHOT/gs-querylayer-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/gs-querylayer-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-querylayer/2.5-SNAPSHOT/gs-querylayer-2.5-SNAPSHOT-test-sources.jar
[ERROR] BUILD ERROR
[INFO] Error retrieving previous build number for artifact 'org.geoserver.extension:gs-querylayer:jar': repository metadata for: 'snapshot org.geoserver.extension:gs-querylayer:2.5-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/gs-querylayer/2.5-SNAPSHOT/maven-metadata.xml. Return code is: 408
Couldn't get file
[INFO] Total time: 10 minutes 54 seconds
[INFO] Finished at: Wed Feb 19 13:53:54 UTC 2014
[INFO] Final Memory: 101M/299M
See <http://ares.opengeo.org/jenkins/job/geoserver-master/316/&gt;
