[Geoserver-devel] Build failed in Jenkins: geoserver-master #3150
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3150/&gt;
[...truncated 6881 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.10-SNAPSHOT/gs-dxf-wps-2.10-SNAPSHOT-test-sources.jar
Sep 03, 2016 8:51:14 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is STARTED
Sep 03, 2016 8:51:14 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Sep 03, 2016 8:51:14 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Initializing cluster partition table first arrangement...
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTTING_DOWN
Sep 03, 2016 8:51:14 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Master Address[127.0.0.1]:5009 left the cluster. Assigning new master Member [127.0.0.1]:5010 this
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Removing Member [127.0.0.1]:5009
Members [1] {
Sep 03, 2016 8:51:14 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Destroying node initializer.
Sep 03, 2016 8:51:14 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 24 ms.
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTDOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
Sep 03, 2016 8:51:15 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
Sep 03, 2016 8:51:15 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 12 ms.
Sep 03, 2016 8:51:15 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Sep 03, 2016 8:51:15 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
Sep 03, 2016 8:51:15 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Sep 03, 2016 8:51:15 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Sep 03, 2016 8:51:15 PM com.hazelcast.cluster.ClusterService
Members [2] {
  Member [127.0.0.1]:5012
Members [2] {
  Member [127.0.0.1]:5012 this
Sep 03, 2016 8:51:16 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Sep 03, 2016 8:51:16 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Sep 03, 2016 8:51:16 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Sep 03, 2016 8:51:21 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Sep 03, 2016 8:51:21 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Sep 03, 2016 8:51:21 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Sep 03, 2016 8:51:21 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 18 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 12 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.832 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.636 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.112 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.382 s]
[INFO] Main Module ........................................ SUCCESS [02:25 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.053 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.271 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:48 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.249 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.479 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.772 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.680 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. FAILURE [06:18 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 15.568 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.052 s]
[INFO] Core UI Module ..................................... SUCCESS [01:16 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.086 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.045 s]
[INFO] Printing Module .................................... SUCCESS [ 13.404 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 43.780 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.090 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.992 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.242 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.548 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.662 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.924 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.314 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.036 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.996 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.549 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:37 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.230 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.174 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.546 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.034 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.537 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.871 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.204 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.078 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.784 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [08:13 min]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.391 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.996 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.138 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.029 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.902 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.722 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.608 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.882 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.887 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.655 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.076 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:51 min (Wall Clock)
[INFO] Finished at: 2016-09-03T20:51:21+00:00
[INFO] Final Memory: 101M/362M
[ERROR] Failed to execute goal on project gs-wms: Could not resolve dependencies for project org.geoserver:gs-wms:jar:2.10-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-process-feature:jar:16-SNAPSHOT -> org.geotools:gt-grid:jar:16-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-grid:jar:16-SNAPSHOT: Could not transfer artifact org.geotools:gt-grid:pom:16-20160903.195546-370 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3151/&gt;
