[Geoserver-devel] Build failed in Jenkins: geoserver-master #3173
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3173/&gt;
[...truncated 16600 lines...]
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-app ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target&gt;
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configClean) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
   [delete] Deleting directory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-app ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/java&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-app ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/test-classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.183 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [328 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.836 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.297 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.236 s]
[INFO] Main Module ........................................ SUCCESS [02:27 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.061 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 52.032 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:47 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.946 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.375 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 32.033 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.757 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:09 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.793 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:09 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.970 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:15 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 1.011 s]
[INFO] Core UI Module ..................................... SUCCESS [01:16 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.221 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.832 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.349 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.532 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.498 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.044 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:22 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:44 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.980 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 14.039 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.535 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:47 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.652 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.711 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.219 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.171 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.505 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.297 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.241 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.561 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.279 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.185 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.029 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.873 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.077 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:32 min]
[INFO] Excel Output Format ................................ SUCCESS [ 14.689 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.096 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.068 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.810 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 14.855 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.558 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.990 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.053 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.277 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.376 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.211 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.560 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.890 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.468 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.761 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.950 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.739 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.204 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.582 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.351 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.794 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.026 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.002 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.550 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.067 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.055 s]
[INFO] Importer Core Module ............................... SUCCESS [ 47.618 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 42.032 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.265 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.680 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.050 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.817 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 34.792 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:02 min (Wall Clock)
[INFO] Finished at: 2016-09-04T23:35:49+00:00
[INFO] Final Memory: 113M/312M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3174/&gt;
[...truncated 16589 lines...]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.809 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.334 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.082 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.186 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Webapp assembled in [333 msecs]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.219 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.190 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.012 s]
[INFO] Main Module ........................................ SUCCESS [02:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.113 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:45 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.110 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.052 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.359 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.423 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:40 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:10 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.326 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:13 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.186 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.039 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.173 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.822 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.802 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.294 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.308 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.042 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:21 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:43 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:14 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.282 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 13.411 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.808 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.030 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.147 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.276 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.678 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.494 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.237 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.279 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.640 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.492 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.320 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.021 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.822 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:34 min]
[INFO] Excel Output Format ................................ SUCCESS [ 14.791 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.543 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.162 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.557 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.277 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.273 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.290 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.042 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.197 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.270 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.011 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.735 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.613 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.485 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.504 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.412 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.096 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.171 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.291 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.034 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.914 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.476 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.782 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.877 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.060 s]
[INFO] Importer Core Module ............................... SUCCESS [ 48.740 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 41.607 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 22.626 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.954 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.919 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.619 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.387 s]
[INFO] Total time: 19:56 min (Wall Clock)
[INFO] Finished at: 2016-09-05T00:20:26+00:00
[INFO] Final Memory: 115M/329M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3175/&gt;
