See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3203/changes>
Changes:
[tbarsballe] [GEOS-7692] Add error checking to Style Editor Layer Attrubtes tab
[tbarsballe] [GEOS-7693] Do not allow WMS layers for Style Page Layer Preview / Attributes
[...truncated 79902 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.789 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.636 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.276 s]
[INFO] Main Module ........................................ SUCCESS [02:54 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.593 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 20.288 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.079 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.765 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 43.736 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 50.288 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:20 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:55 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.841 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 13.081 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:19 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.172 s]
[INFO] Core UI Module ..................................... SUCCESS [01:28 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.810 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 46.610 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.664 s]
[INFO] Demos Module ....................................... SUCCESS [ 19.478 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.160 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.374 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:45 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:10 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.937 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.815 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 17.681 s]
[INFO] Community Space .................................... SUCCESS [ 1.981 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.998 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.702 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:40 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.631 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.071 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.043 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.328 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.203 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.234 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.296 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.586 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.926 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.390 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.172 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.858 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.135 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.172 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:33 min]
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 27:47 min
[INFO] Finished at: 2016-10-20T19:20:24+02:00
[INFO] Final Memory: 132M/521M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
at hudson.remoting.UserRequest.perform(UserRequest.java:121)
at hudson.remoting.UserRequest.perform(UserRequest.java:49)
at hudson.remoting.Request$2.run(Request.java:325)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
... 31 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 1 second
