See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3208/changes>
Changes:
[github] Rename LICENSE to LICENSE.txt
[...truncated 81028 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 39.515 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.145 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 22.912 s]
[INFO] Main Module ........................................ SUCCESS [03:19 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.858 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 21.050 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 14.761 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.653 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 48.010 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 50.538 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:20 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:49 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:24 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.193 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:16 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.653 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:23 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.171 s]
[INFO] Core UI Module ..................................... SUCCESS [01:29 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.480 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.646 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.601 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.673 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.957 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.375 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:50 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:11 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.281 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.836 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 14.389 s]
[INFO] Community Space .................................... SUCCESS [ 2.090 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.872 s]
[INFO] Application Schema Support ......................... SUCCESS [ 2.824 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.051 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.610 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.104 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.935 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.265 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.466 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.498 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.445 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.736 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.638 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.218 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.452 s]
[INFO] OGR WFS ............................................ SUCCESS [ 11.040 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.265 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:36 min]
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 29:56 min
[INFO] Finished at: 2016-10-24T09:23:35+02:00
[INFO] Final Memory: 137M/700M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
at hudson.remoting.UserRequest.perform(UserRequest.java:121)
at hudson.remoting.UserRequest.perform(UserRequest.java:49)
at hudson.remoting.Request$2.run(Request.java:325)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
... 31 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 3 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3209/changes>
Changes:
[andrea.aime] [GEOS-7811] More WFS 2.0 NPE due to XSD schema corruption under load
[...truncated 79827 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 24.398 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.324 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.007 s]
[INFO] Main Module ........................................ SUCCESS [03:14 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.029 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 23.015 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.176 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.964 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 43.190 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 51.801 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:40 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:30 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:04 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.262 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:20 min]
[INFO] REST Support Module ................................ SUCCESS [ 18.089 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:27 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.187 s]
[INFO] Core UI Module ..................................... SUCCESS [01:32 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 25.328 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.567 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.021 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.944 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.312 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.437 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:52 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:13 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.793 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.223 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 17.666 s]
[INFO] Community Space .................................... SUCCESS [ 1.529 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 2.730 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.842 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:55 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.507 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.836 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.043 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.390 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.234 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.250 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.266 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.725 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.003 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.687 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.234 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.324 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.057 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.172 s]
[INFO] Total time: 31:07 min
[INFO] Finished at: 2016-10-24T18:24:48+02:00
[INFO] Final Memory: 133M/554M
[ERROR]
[ERROR] -> [Help 1]
... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3210/changes>
Changes:
[Alessio Fabiani] JIRA GEOS-7802 - Add a URL Mangler injecting Bearer type access tokens to Services
[andrea.aime] [GEOS-7811] following up with some cleanups
[...truncated 80004 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.171 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.498 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.426 s]
[INFO] Main Module ........................................ SUCCESS [03:11 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.359 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 20.482 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 10.461 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.593 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 43.969 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 50.054 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:26 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:54 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:18 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.400 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.360 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:24 min]
[INFO] Core UI Module ..................................... SUCCESS [01:38 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.699 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.429 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.931 s]
[INFO] Demos Module ....................................... SUCCESS [ 19.665 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.784 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.343 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:10 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.689 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.742 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 13.312 s]
[INFO] Community Space .................................... SUCCESS [ 1.638 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.811 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.873 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:39 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.098 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.086 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.903 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.359 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.203 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.717 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.195 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.410 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.546 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.203 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.746 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.727 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.250 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:37 min]
[INFO] Total time: 29:13 min
[INFO] Finished at: 2016-10-24T20:23:06+02:00
[INFO] Final Memory: 137M/750M
[ERROR]
[ERROR] -> [Help 1]
... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3211/changes>
Changes:
[Alessio Fabiani] PR (GEOS_7785) - Implement a REST Based Role Service for GeoServer
[Alessio Fabiani] [GEOS-7803] GeoFence Embedder does not check for plain Rule Services
[...truncated 80815 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 20.764 s]
[INFO] Core Platform Module ............................... SUCCESS [ 17.981 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.470 s]
[INFO] Main Module ........................................ SUCCESS [03:18 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.374 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 20.893 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.391 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.577 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 48.962 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 53.623 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:21 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:55 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:25 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.516 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:18 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.904 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:30 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.172 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.933 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.600 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.024 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.145 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.077 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.359 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:51 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:09 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.329 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.269 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 20.364 s]
[INFO] Community Space .................................... SUCCESS [ 0.812 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.967 s]
[INFO] Application Schema Support ......................... SUCCESS [ 1.139 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:54 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.472 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.409 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.402 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.450 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.405 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.061 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.154 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.570 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.940 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.264 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.156 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.871 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.730 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.171 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:34 min]
[INFO] Total time: 29:39 min
[INFO] Finished at: 2016-10-25T19:49:26+02:00
[INFO] Final Memory: 135M/561M
[ERROR]
[ERROR] -> [Help 1]
... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3212/changes>
Changes:
[tbarsballe] Document the GeoServerSystemTestSUpport data dir
[tbarsballe] [GEOS-7691] Update OL preview on save without reloading page
[...truncated 80623 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 16.661 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.999 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.598 s]
[INFO] Main Module ........................................ SUCCESS [03:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.232 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 21.676 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 10.774 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.917 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 44.422 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 50.053 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:58 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:21 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.361 s]
[INFO] REST Support Module ................................ SUCCESS [ 15.812 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:22 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.156 s]
[INFO] Core UI Module ..................................... SUCCESS [01:31 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.696 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.363 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.661 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.118 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.926 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.468 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:45 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.701 s]
[INFO] REST UI Module ..................................... SUCCESS [ 12.489 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 20.535 s]
[INFO] Community Space .................................... SUCCESS [ 0.842 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.045 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.327 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:38 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.052 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.491 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.980 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.687 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.561 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.546 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.058 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.441 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.187 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.714 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.156 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:35 min]
[INFO] Total time: 28:49 min
[INFO] Finished at: 2016-10-26T01:25:30+02:00
[INFO] Final Memory: 138M/815M
[ERROR]
[ERROR] -> [Help 1]
... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
