See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3221/>
[...truncated 17488 lines...]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.574 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT-tests.jar
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.835 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.329 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.378 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.295 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.750 s]
[INFO] Main Module ........................................ SUCCESS [02:27 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.070 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.007 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:56 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.588 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.964 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.558 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.635 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:44 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:17 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.502 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:11 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.265 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:18 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.078 s]
[INFO] Core UI Module ..................................... SUCCESS [01:16 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.349 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.073 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.549 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.858 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.093 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.109 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:22 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:45 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.254 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] Printing Module .................................... SUCCESS [ 14.130 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.291 s]
[INFO] Community Space .................................... SUCCESS [ 0.077 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.047 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.198 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.090 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.491 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.705 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.278 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.316 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.044 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.650 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.090 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.764 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.736 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:35 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.569 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.131 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.748 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.998 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.784 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 16.208 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.160 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 27.338 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.725 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.005 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.394 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.493 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.057 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.641 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.054 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.307 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.983 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 29.042 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.047 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.365 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.213 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 38.291 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.022 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.071 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.076 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.041 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.724 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.836 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.678 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.134 s]
[INFO] Importer Core Module ............................... SUCCESS [ 50.859 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 44.016 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.658 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 18.315 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.691 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 14.925 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 34.154 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:54 min (Wall Clock)
[INFO] Finished at: 2016-09-07T05:12:56+00:00
[INFO] Final Memory: 115M/309M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-core
