[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #3222
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3222/changes&gt;
Changes:
[jody.garnett] Use $port correctly for manual install
[...truncated 80134 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 18.658 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.745 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.774 s]
[INFO] Main Module ........................................ SUCCESS [02:58 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.422 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 20.090 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.093 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.983 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 43.221 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 49.523 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:20 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:56 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:24 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.299 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 13.989 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:21 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.171 s]
[INFO] Core UI Module ..................................... SUCCESS [01:36 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 28.807 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 49.387 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.100 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.896 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.129 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.406 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:49 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:13 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.930 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.891 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 22.189 s]
[INFO] Community Space .................................... SUCCESS [ 0.795 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 3.884 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.764 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:55 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.942 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.071 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.809 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.359 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.374 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.266 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.234 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 12.162 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.222 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.468 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.171 s]
[INFO] OGR CORE ........................................... SUCCESS [ 5.322 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.636 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.202 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:35 min]
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 29:13 min
[INFO] Finished at: 2016-10-28T08:01:38+02:00
[INFO] Final Memory: 137M/742M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
  at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
  at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
  at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 3 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3223/changes&gt;
Changes:
[jody.garnett] Fix quote so module and port are included in filewrite call
[...truncated 79869 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.412 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.197 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.934 s]
[INFO] Main Module ........................................ SUCCESS [02:50 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.359 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 21.020 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 9.993 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.546 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 41.958 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 47.402 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:19 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:55 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:12 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.908 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:07 min]
[INFO] REST Support Module ................................ SUCCESS [ 12.910 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:16 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.187 s]
[INFO] Core UI Module ..................................... SUCCESS [01:26 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 25.156 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.475 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.962 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.133 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.456 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.374 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:45 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:11 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.233 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.912 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 11.862 s]
[INFO] Community Space .................................... SUCCESS [ 0.561 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.528 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.436 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:34 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.694 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.898 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.840 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.795 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.186 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.374 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.746 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.347 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.358 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.156 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.124 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.492 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.187 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:34 min]
[INFO] Total time: 27:20 min
[INFO] Finished at: 2016-10-28T11:20:44+02:00
[INFO] Final Memory: 137M/740M
[ERROR]
[ERROR] -> [Help 1]
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3224/changes&gt;
Changes:
[andrea.aime] [GEOS-6154] Layer groups and/or their component layers appear multiple times in capabilities document
[...truncated 73342 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 21.185 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.464 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.383 s]
[INFO] Main Module ........................................ SUCCESS [03:08 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.452 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 24.104 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.250 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.796 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 44.562 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 51.474 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:29 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:00 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:44 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.109 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:11 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.440 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:24 min]
[INFO] Core UI Module ..................................... SUCCESS [01:39 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 25.718 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.021 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.821 s]
[INFO] Demos Module ....................................... SUCCESS [ 19.868 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.082 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.344 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:52 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:12 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.311 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.472 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 17.743 s]
[INFO] Community Space .................................... SUCCESS [ 0.780 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 2.137 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.421 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:51 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.129 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.820 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.309 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.343 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.250 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.827 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.359 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.320 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.050 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.561 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.203 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.028 s]
[INFO] OGR WFS ............................................ SUCCESS [ 11.709 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.265 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:36 min]
[INFO] Total time: 29:35 min
[INFO] Finished at: 2016-10-28T15:23:02+02:00
[ERROR]
[ERROR] -> [Help 1]
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3225/changes&gt;
